Question about Compaq A4000 All-In-One InkJet Printer
Wireless printing i have a gateway m360 laptop and would like to print wirelessly to my compaq a4000 printer. how do i do this? the printer does not have wireless capability installed but i know the laptop has wireless modem.what product should i buy that will be compatible? i also want to go wireless for internet access but only have dial up - what product should i buy to act as my WAP with the Gateway laptop? is there a product that can support both the wirelss internet access via dial up AND the wireless printing to the A4000?
  • smchydro Nov 15, 2008
    i dont have a router. thats what im trying to figure out - do i need to buy a router?
    Genius:
  • 1,913 Answers
Access your router with following link
http://192.168.0.1
then type user name:admin
password is:admin or blank
then enable DHCP.then u can get ip automatically.
then all network members get ip from this router.
configure your router as wep.not wap
dhcp is on.
and dont give advanced security
Posted on Nov 15, 2008
  • kishor khatri
    kishor khatri Nov 16, 2008
    yes u need to buy router like linksys or else.
    then u can setup easily wireless network.
Wifi laptop will not print to printer - not a wifi printer
Check if the printer has a wireless option. Actually this issue is complex. First thing first, you can print wirelessly from your laptop within the WIFI range in a case that your printer do have wireless on in. It is impossible to print wirelessly from the wired printer through LAN.
One thing, I guess you don't have a wireless router. You need to have a wireless router like LINKSYS that is easy to setup then try to connect wirelessly to the wired printer. There I am not too sure if your can do a printing option from your laptop wirelessly.
Lastly, check if you have a ROUTER and need to set it up on your laptop and on the network LAN. You may now have a NETWORK printer in this regards. Thank you.
Oct 06, 2009 | HP Compaq Presario V6000T Notebook
Printing wirelessly from my macbook
Can you check to be sure there is a relationship between the laptop, printer and access point? All on the same SSID?
Jul 06, 2009 | Gateway 802.11g Wireless DSL/Cable Router...
Wireless printing does not work
For an effective wireless connection, the printer should be connected to one of the LAN ports of a configured wireless router. This way, every pc(mostly laptops with wireless capability) can print to the printer. You will need a wireless adapter for desktop pcs to access any resource made available wirelessly ok. Good luck
Jun 02, 2009 | Canon PIXMA MX850 Multifunction Printer
Problem with connection to my wireless printer'
print out your config settings on the printer.
go to add a printer, set it as a local attached printer, and set the port to TCP/IP. From there enter in the IP Address of the printer that you are trying to print to from the config page i had you print out.
After that is completed install the print drivers and you are good to go.
Jan 07, 2009 | Gateway Wireless-B Router (wbr-100)
I need to print from my laptop, will I have to buy an wireless adapter?
No reason why you should. Run printer software on laptop and connect cable between lapptop and printer when told to do so. Cable needs to be connected everytime you want to use printer.
Apr 26, 2008 | Compaq Presario 700 470024-192 Notebook
Print from laptop wirelessly
Yes there is NO reason why you can't. You must simply install the Printer Drivers on BOTH PC's. Using the Software supplied, first Setup/Install the printer on your Desktop PC, FIRST, as a LOCAL printer. Then 2nd, from ya lappy setup your printer as a "Networked" printer.. locate and connect.. the driver will install, & ya can then print a Test Page, to see if it is all OK. After the Drivers are installed at BOTH locations you will be able to print from your laptop through your desktop to ya printer... no worries..
Sep 04, 2007 | Intel Pro 1000XT Server Adapter...
Compaq A4000 All-In-One InkJet Printer Logo
70 people viewed this question
Top Compaq Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Tony
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
