Question about Brother SE-270D Computerized Sewing Machine
My needle is hitting the face plate and breaking
How can I adjust the needle bar?
    Problem Solver:
  • 9 Answers
Make sure the needle is all the way up in the shaft/bar. It can work loose and slip down. Make sure you're installing the needle correctly.
Posted on Nov 26, 2008
How do you adjust the needle position.
Do you have the needle facing the correct direction when installed in the machine? Consult the owner's manual. The flat side of the needle needs to face a particular direction.
Feb 21, 2016 | Sewing Machines
Feed dogs are hitting the needle plate
Needle is bent replace with new needle. You may need to adjust feed speed so that needle doesn't bend. Good luck
Jun 06, 2015 | Sewing Machines
I have a Singer Quantum XL-1. After replaceing the needle bar stopper, now the machine will start to embroidery, but when the need goes to the right, it stops going up and down. Is there something that...
Hi
Take off the bulb cover and check that the buffer at the end of the on the curved spring above the needle bar. It deteriorates like the needle bar stopper you just replaced. If it is still there and in good condition then your machine probably now needs adjustment/service.
Sep 22, 2013 | Singer Sewing Machines
How do i move the needle bar to the back on a bernina 1008. It is not in the middle of the pressure plate hole and I am breaking a lot of needles. thank you
Is the needle in the center of the foot? If it is then you should adjust the plate. There should be a nut inside the bobbin case area under the plate that you can adjust the plate position with.
Sep 05, 2013 | Bernina Sewing Machines
Needle hitting stitch plate on my Viking Lilly 545 recently had it serviced, was sewing fine
try a new needle
if the needle is still hitting the needle plate, then it's possible that the machine is out of time and needs to be adjusted, or there is something wrong with the needle bar.
Nov 13, 2012 | Husqvarna Sewing Machines
Needle hitting plate and breaking thread
It sound as though the needle shaft is bent. Using a plyer to gently adjust the needle shaft so the needle hits the center of the opening it's supposed to go through. Test. If it continues to hit something after going below the plate then it could very well be a timing issue. Refer to your owners manual on timing related issues.
Feb 11, 2011 | Olde Thompson PW-500
Keep breaking needles
Here are some solutions to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate and make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
Hope this helps.
Sep 20, 2009 | Singer 132QRFB Mechanical Sewing Machine
When i use my janome overlocker the needle is hitting the lower looper, and therefore breaking. This is happening with both needles. I have taken the covers off and the needles are hitting the metal. Is it...
Here are a few things to try.
* When you insert anew needle, make sure it’s positioned correctly. Usually with the flat side
away from the bobbin, but consult your manual. Make sure that it goes all the way into the holder, and that the screw is securely tightened.
Make sure it’s attached securely.
A needle that hits a pin can break. Always remove the pins from your fabric before they reach
your needle.
Make sure it's securely in position.
pressure foot.
I hope one of these solutions help you.
Sep 14, 2009 | Sewing Machines
Brother SE-270D Computerized Sewing Machine Logo
198 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
