Question about GE Dishwashers
Kenmore dishwasher mod # 363.14375791 hums, wont fill or run
I replaced the fill valve several years ago, no problem. this time, it just hums.
  • 240 Answers
Are you sure the valve is what is humming? If so, it may have went bad again. Its not unusual for that to happen. You could possibly have a timer going bad, or a ground issue. If it is the valve humming, check your water supply, and be sure you dont have a clogged line. Also, some valves have inlet screens over the end of the inlet valve (would be just inside the fitting where it goes into the valve). These can become clogged as well. Let me know what you find out.
Posted on Nov 15, 2008
Dishwasher Mod 587.14419400 no power to fill valve
Check the float (make sure it's free to move up and down) and check the float switch.
Jul 25, 2012 | Kenmore Dishwashers
I have a Kenmore dishwasher, not sure of the model or year (less than 10 years old) but water constantly flows into the dishwasher. So much so that it leaked all over the floor because the bottom filled up...
Hello.
If it's filling all the time when dishwasher is not even running? The water inlet valve that the house water supply connects to at the dishwasher,is sticking open and needs to be replaced..what you can do now to stop it from constantlu filling is turn off water supply to the d/w from under the kitchen sink.
Typically the model number is on a label on the egde of the door inside or on the rim of the tub..it would be needed to order a water valve
Gene
Aug 24, 2011 | Dishwashers
Dishwasher wont fill with water
Hi
Thanks for using FixYa. To start with check the water inlet valve which is located behind the lower access panel on the left or right side of the Dishwasher. If the water inlet valve is bad you have to replace it, also check the main water line for clogs/obstructions. If still the issue is not resolved then it’s a bad float switch and needs to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 25, 2010 | Kenmore 17252 Free-standing Dishwasher
My Kenmore dishwasher starts to fill and then stops
I've got the same dishwasher....mine is 2 years old and used only 3 times a week and now the motor is burnt out. I understand that this unit is a Frigidaire and is one of the worst ..quality speaking. I guess that why they only provide an one year warranty. Unfortunately, we got a LEMON
Oct 04, 2009 | Kenmore Dishwashers
Dishwasher wont take water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 12, 2009 | Kenmore 24 in. 15252 / 15254 / 15259...
Humming noise after water fill and will not wash
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
Jun 11, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Engine is humming but the water does not make it into the dish washer
Replace the water solenoid valve, but try opening it up first, and seeing if there is any build up inside the valve. This is normal in solenoids just remove the obstruction and water should fill.
Apr 27, 2009 | Frigidaire 24 in. FDB750RCC Stainless...
Dishwasher starts to fill then just hums
Sounds like a motor problem. Behind the chopper is an access to the impeller, try turning the impeller or the chopper blade and see if the motor will rotate. If it doesn't, then something is stuck preventing the motor from running.
Mar 07, 2009 | Dishwashers
While not in operation dishwasher slowly fills up.
water valve is clogged try to turn your valve to dishwasher under sink
Nov 29, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Kitchenaide KUDM24SE1 dishwasher will not fill with water
It may be the water inlet valve or the electronic control board. To check, remove the bottom toe panel. The valve will be on the left side. There will be live power, so use extreme CAUTION. Start the DW, 1. if you can hear the valve humming or the valve coil is getting warm, replace the valve. 2. Using a device with wires to check the power at plugs, connect to valve power connection, if power is present, replace valve else replace electronic control board.
Jun 07, 2008 | KitchenAid KUDM24SE Built-in Dishwasher
Open Questions:
Dishwashers Logo
113 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
