Question about Linksys Wireless-G WRT54G Router
HI, I am unable to connect wirelessly using the Kinksy router.
I have removed Linksys from my programs in the control panel and I have no problem connecting directly to my modem. I have tried everything. I was hoping I can re-install Linkysys with your help. Thanks
  • Linksys Master
  • 4,338 Answers
Router setup
You do not have to use the cd. Go to the control panel and un-install the program that the cd installed. then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 15, 2008
Want to uninstall home defender
It's really complicated to remove Windows Defender. The best solution is to simply disable it: Control Panel->in the search bar type "defender"->Click on Windows Defender->Tools->Options 1. Automatic Scanning->Uncheck 2. Real time protection->Uncheck all 3. Administrator->Uncheck "Use this program"
Mar 15, 2010 | Linksys WRT160N Wireless Router
Tip
How do I set up the wireless network key on my linksys router?
Hi.
This tip applies to any Linksys wireless router.
First you need to access the router control panel , and check wireless settings.
Therouter control panel is accessed connecting a computer to the router.This is done using an Ethernet cable, and entering router IP address in Internet Explorer address bar.
Here the cable:
Here the procedure.
Connect router to computer using a network cable (LAN cable with RJ45 connector).
On computer open Internet explorer and type router IP in the address bar (where you use to typewww.this.that ).The IP address is indicated on router user manual. Ifit has not been changed, 192.168.1.1 is the default for LinkSys brand home broadband routers. Press enter after typing the IP.
Enter router user name and passord. On older LinkSys routers, the default username is blank and the default password is "admin." On newer LinkSys routers, both the default usernameand the password are "admin". If that does not work, then defaultsettings had been changed. In that case you will need to reset therouter. See: Reset a LinkSys Router Password.
After entering right ID and password you will open the router control pane as HTML page in Internet Explorer.
In the router control panel choose the wireless setting tab to see or modify the password:
If you do not need to change wireless settings, then write down the encryption key, and set the same key on the laptop. Once the right key is set on the laptop, the connection will start automatically.
If more computersare connecting to this network, then do not reset or change thewireless settings. Simply write down the key on paper and setup thelaptop.
Remember that WAP encryption keys are case sensitive, Wep encryption keys are not.
The simplest encryption to choose is WEP.
WEP means wireless encryption key.
Open the router panel, go to wireless, and find key settings or set your own key.
If you have to set the key:
If you choose WEP 64, then the key that you need to set will be 10 characters key made by numbers and letters from A to F.
Close Internet Explorer to get out of the Linksys control panel.
Regards.
on Mar 16, 2010 | Linksys Wireless-G WRT54GS Router...
I want to remove the home defender that came with the linksys
goto the add/remove programs section of the control panel and select remove when you find the home defendor and uninstall it
Sep 28, 2009 | Linksys WRT160N Wireless Router
We used to have Linksys wireless on our computer, We now have another wireless. But we turn the computer on Linksys error pops up over & over again. I looked to see if it was still installed on our...
Uninstall the Linksys under Control Panel remove programs. That's why you learn to never install a manufacturer's driver over the windows driver for routers.
Mar 28, 2009 | Linksys WRT160N Wireless Router
Device password????
Device ownership password:
Control Panel->add or remove programs-> Intel(R) PROSet/Wireless Software -> Modify -> Unmarked WI-FI PROTECTED SETUP
Dec 15, 2008 | Linksys WRT160N Wireless Router
No internet with wireless laptop
Check to be sure that your network connections are set to automatic(control panel->network connections then right click on your wireless connection go to properties- tcp/ip click on that and check there.
Oct 29, 2008 | Linksys Wireless-G Broadband Router
Cannot get online with Wireless G WRT54G router. Can get online by pressing Cisco Systems button but only temporarily.
Do U see the router signal on the wireless network connection search?
Sometimes the linksys systems cd does not want to work on some pc's. try using the control panel - add/remove programs and uninstall all programs for the linksys. Then goto the control panel - system - hardware and uninstall the linksys card. Leave the actual card installed and reboot. After it detects your card use the linksys cd to load only the driver.
In the properties of the wireless connection, let windows manage it.
The above is based upon the factory defaults of the router. Any keys to access the router would have to be used on the pc.
Jun 02, 2008 | Computers & Internet
Linksys Wireless N adapter Missing Hardware.ID
Hi Kathy,
Please do this first. go to control panel>add/remove programs, uninstall the Linksys Wireless N adapter.DO NOT UNPLUG THE WIRELESS ADAPTER FROM THE PC. Insert the Linksys wireless N adapter cd(DO NOT RUN THE SET UP). If the set up wizard shows up CLICK exit or cancel.Restart the pc with the disc in and the wireless adapter connected. When the pc boots up you will see the found new hardware wizard. Continue with the wizard, Select No not this time, Select install software automatically. If this is successful, your pc should be able to detect your wireless network
Mar 10, 2008 | Linksys WRT300N Wireless Router
How to Configure D-link dwl-510 WiFi Card
To configure your linksys, access point, we need more information, the ipaddress oif your dlink router and the wireless settings on your dlink router..,
for more informations, check this link http:kb.linksys.com
for more details contact linksys; 18005465797
Dec 14, 2007 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
49 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
