Question about HP Computers & Internet
I am trying to hook my computer up to my tv and i am not getting picture or sound
  • 300 Answers
You need to make sure that your PC is capable of displaying video output other than a monitor. It sounds like your TV or PC isnt capable of doing this. You will need to check the manual for your PC and/or your video card to see if they both allow this feature.
If you can reply with the model numbers of your equipment, Ill try to assist you further.
Hope this helps. Please remember to rate this information.
Thanks
Posted on Nov 15, 2008
Cant get sound via HDMI HOOK UP TO SONY TV
Some HDMI don't carry sound signals and you have to hook up the headphone jack to the TV with a headphone to RCA adapter.Sometimes you can go to control panel on your computer and turn on the HDMI sound but sometimes not.
Apr 18, 2015 | Toshiba Computers & Internet
Hooked game system PS3 to tv-cannot get picture or sound
What input are you trying?
Banana Pins or HDMA Cable
Nov 28, 2013 | Televison & Video
Xbox elite connected to TV thru HDMI works fine, but connected via bcs-fs500 receiver = no audio or video Cable tv through receiver works fine Have tried cable tv through receiver inputs HDMI 1 and 2...
Hook your Xbox to tv via HDMI, then hook TV to reciever through digital optical or composite cables. If you try to get your picture through receiver first, you may get picture and sound but, sound may be delayed and picture might not be the best. Bettter to run through tv first then provide sound to receiver.
Mar 31, 2011 | Pioneer Audio Players & Recorders
We have our cable box hooked up to the tv and get a great picture but no sound. The previous owners had a stereo system hooked up to the tv and we are simply trying to get any sound at all. We went into...
Ok, I need more verifications:
1) Your TV is Fujitsu Siemens PlasmaVision P42VHA40 Monitor which does not have tuner? If not, please provide the make and model of the TV.
2) What kind of cables you are using to hook between the cable box and the TV? HDMI? Component video (Red, Blue, and Green cables withe RCA plugs)? Composite video cable with Yellow RCA plugs?
3) Are you trying to get the sound to come out off the TV speakers or through the stereo system?
Feb 03, 2011 | Fujitsu Siemens PlasmaVision P42VHA40...
My insignia lcd37 is hooking the comcast modem and works at times. Other times the sound is on, but the picture is blank. Is it worth fixing or just start over.
Okay you TV is hooked to a comcast modem? or do you mean My tv is hooked to the comcast converter box? A no picture but sound you want to first check you cables also try hooking up a dvd to the tv and see if that picture comes on if not and you got no pic and sound this would mean the backlight on this tv is dead or you got a bad inverter not converter, inverter inside the tv. Meaning it needs the repairshop but try and hook up a dvd to it and see if you got picture if so you cable box might be the issue call comcast!
Thanks and please leave valuable feeback and ratings today!
Dec 11, 2009 | Insignia 37" LCD Flat-Panel HDTV
No sound on atari 800? tv works I don't have the 300 ohm screws so i hooked the wires on the switch box to the box itself only way I got a picture. then hooked the cable wire to box then computer. Games...
Go back to square 1. Unhook the wires from the switch box. Get the 300 ohm screws and hook up the wires the normal way. Try changing the sound card.
Aug 18, 2009 | Computers & Internet
Connected pc to logik 32in lcd tv, getting picture but no sound
Need clarification. Do you have speakers hooked up to your computer? Or did you just plug in a VGA cable from your computer to the TV? The sound can't magically go from your computer to the TV, because VGA cables don't transmit sound. So if you are indeed using speakers, which I doubt, it's a computer problem.
Basically, describe exactly what components you have and how they are hooked up.
Jun 27, 2009 | Compaq Presario SR1010NX (DW254A#ABA) PC...
Not to computer saavy so please keep it simple. I have a Sony Vaio VGC RA840G desktop with 5.1 surround sound. Also have a Samsung LN46A850 S1F HDTV. Also a home theater system. This is hooked up to cable...
From the looks of the TV manual you have everything right, so it's very odd you're running into this problem.
Have you tried swapping through the sources? I find with one of the TVs we have on display at work that any time I'm having some troubles with it I will change the source from PC to something else, then back to PC.
If that doesn't work then I'd suggest you try reseting the sound settings back to factory default. The instructions are on page 45 of the TV manual. From the TV menu select "Sound", then "Sound Reset", then either "Reset All" or "Reset Sound Mode". I would suggest reseting all.
Last option would be to try using the headphone jack in the side of the TV, though this is a last resort kind of thing since you would have to unplug it every time you wanted to use the cable box.
Hope this helps :)
Apr 16, 2009 | Sony Computers & Internet
Toshiba CF36G40 36" TV (picture snowy)
you have a bad tuner you can replace it or use vcr if you still have one around. hook it up with av cable like your ps2 and hook your cable to it and use it to change channels. If you want to replace the tuner it will require soldering and you will have to order it somewhere. i would try partsore.com. The tuner is the metal can the cable goes into inside the tv.
May 12, 2007 | Toshiba CF36G40 36" TV
Computers & Internet Logo
22 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
