I have a 3-yr-old HE3t. It is not completely spinning clothes dry at end of cycle. Clothes are still very wet at end of cycle. Last load I did I was watching it and with 5 seconds left it just shut off without doing the higher speed spin after the rinse cycle. If I hit the drain and spin button after the wash cycle ends,it will spin them out the way it used to but won't do it as part of the normal wash cycle. I even hit the extended spin option as part of the wash cycle but doesn't help. Also, at times there has been water left in the drum when I go to do another load. I haven't seen any code numbers show up on the error code lights. Any help would be apprecitated. Overall, happy with the machine but dreading an expensive repair after only 3 years.
-   have a whirlpool washer model #LSQ9564MQ0. Will not spin clthes dry unless I put back on high spin and loosen basket, close door until I hear it spinning. I have to repeat 2 or 3 times. Whats the problem?-   Guest
Dec 24, 2007
-   My Maytag washer is not spinning out all the water, on the final cycle. It seems to happen mainly when there is a heavy load such as a blanket or bedspread. The washer nor the load is not out of balance.Thank You in advance for any help with this matter.-   Drip Dry
dskbob, the first thing to do is remove the lower panel. Right in front you will see the pump filter. Get some towels and a bucket and unscrew the filter cap and pull the filter out. See if you have a bunch of lint and stuff in there. If you do, clear it out and give the washer another shot. See if this corrects your problem...Catriver..post back
I was having a similair problem, in the high spin cycle. Water wqs not completely draining. medium and low spin were ok. I followed the advice posted by Catriver, and it seems to have fixed the problem. Thanks for posting. This is what the 'net was inteded for!
Was this helpful?
Yes
No
Popular Solutions for Kenmore 3.8 cu. ft. HE3t King
was washing clothes and heard beeping sound...on spin cycle and flashing letter F...now cannot open...
(More)
was washing clothes and heard beeping sound...on spin cycle and flashing letter F...now cannot open door...this all occured with about 3 or 6 mins left to wash
getting F02 on my kenmore front loader.what i did so far,new pump,cleaned hoses,no clogs or blockage...
(More)
getting F02 on my kenmore front loader.what i did so far,new pump,cleaned hoses,no clogs or blockage anywhere.at end of cycle tub is not completely drained.seems like something is preventing water from getting from tub to pump.could the ball check valve be causing the problem.oh yeah was getting f06,replaced mcu and fixed solved it.any help greatly appreciated.Ed
