Question about Asko T701 Electric Dryer
Rythmic thumping sound
My dryer has developed a rythmic 'thump' - apparently once per drum revolution - as if there were a shoe in the dryer, though it still makes the sound when I run it empty. It is gradually getting worse. The dryer otherwise is functioning normally.
    President:
  • 1,462 Answers
Probably the rear bearing or the drum shaft
Posted on Nov 16, 2008
Kenmore dryer making a thumping noise
Your dryer has rolls on the drum and they are going bad and need to be replaced
Mar 22, 2014 | LG DLG3788W Gas Dryer
My new sold f80 thumps when it runs, 2 thumps per revolution
Need LUBE or wax, see your owner manual, and Do it right now. use 100% silicones LUBe.
2) Lube the rollers bearint use WD-40 for rollers bearing only.
God bless you
Nov 14, 2012 | RTO Sole F80 Treadmill
Creda simplicity TVU1 tumble dryer is making a thumping noise while drying
Hi dave hemming.
I do not believe it is a bearing that is causing your thumping noise
No...you do not need a new drum...all you need is new drum rollers
You probably have a flat spot on one of the rollers, it will make the thumping sound when the drum rotates.
Go to the following webpage and get your drum rollers and install them and that should take care of the noise you are hearing
Please take time to rate me
Bud
http://www.appliancepartspros.com/index.aspx
Oct 13, 2012 | Dryers
Maytag dryer tha-thumps
It is safe to use the dryer, I don't see any foreseen future to other parts. But the idler definately is flat(tening). It should be replaced asap.
May 24, 2012 | Maytag Dryers
I have an electric frontload dryer. If I turn it on with nothing in it, it sounds like there is a shoe tumbling around. If I open the door and spin the drum by hand, each revolution the drum makes, there...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Nov 22, 2010 | GE Dryers
Dryer makes clunking noise when it starts and stops. Also noisy during the drying cycle. It's a Maytag
May need a new blower wheel.
The wheel is mounted to the motor and if it is stripped out it will not move air past the heat element.
Have it checked before the heat element fails.
Jan 16, 2010 | LG DLE2515S Gas Dryer
LG DLE3777W dryer thumps when running . It sounds like there are tennis shoes in the drum.
Probable cause is the bearing on the wheel that turns the drum is worn out. They are easy to replace and should cost less than $25. for the part.
Remove the front of the dryer and turn the drum by hand, you should be able to tell which side is worn.
Be sure and unplug first.
Mar 16, 2009 | LG DLE3777 Electric Dryer
My new dryer is makeing thumping noises when its runningsounds likr a pair of shoes are in it
Depending upon the model the drum rests on a set of rollers or glode strips. If the drum has a flat spot or overly large seam then it will thump. If the thump is about once a second.
I have seen this a number of times on the Performa line. The drum needed to be replaced to correct it.
Alternately if there is a flat spot on a roller it will sound faster than once a second.
This is usually covered under a manufacturers warranty.
Jul 28, 2008 | Maytag Dryers
LG ELECTRIC DRYER
Henry, its going to be 1 of 2 things. Check inside your drum, see if the vent in the rear has burning or discoloration around it. If it does, it sounds as if your vent is restricted causing the unit to overheat, so clean/fix/replace the venting and your support pulleys will need to be repalce ie flat spots from overheat. If there is no scoarching marks and you know its not the vent or heat issue, the drum seam may have parted causing the thump as every revolution is made.
Apr 04, 2008 | LG DLE2514 Electric Dryer
Asko T701 Electric Dryer Logo
486 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
