Question about Delta 2402 Classic Single Handle Kitchen Faucet with Side Spray Chrome...
Faucet/sprayer coordination How do you get the water to stop flowing through the faucet when you use the side spray? Our old faucet shut off while the sprayer was on but my husband installed the new one and water flows through both the faucet and the sprayer at the same time giving less pressure to the sprayer.
  • 2 more comments
  • Anonymous Mar 16, 2014
    no pressure at faucet but pressure at sprayer
  • Anonymous Mar 24, 2014
    need replacement sprayer drop
    I need instructions on how to adj the faucet to shut off when sprayer is in use
  • Anonymous Mar 31, 2014
    vegie sprayer has very low water flow.
  • 33 Answers
If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)(this is not your faucet but works the same)
Faucet/sprayer coordination - 3cafbb5.jpg
Here are the instructions:
  1. Turn off water to faucet.
  2. Remove handle.
  3. Remove top cap.
  4. Turning spout back and forth gently lift and remove.
  5. Remove and replace diverter.
Hope this helps and please remember to rate this!
Posted on Dec 09, 2008
Kitchen faucet sprayer I have a Delta classic single kitchen faucet and I have a side sprayer too. When I try to use the side sprayer the water stops at the faucet and barely trickles out the sprayer and...
There could be a clog anywhere between the diverter and the sprayer. Sometimes the line collapses from age and has to be replaced. Look under the sink to check for leaks.
Jan 20, 2014 | Plumbing
I have a brand new moen muirfield high arc faucet with low pressure at spout but good pressure at side spray what can i do to get better pressure at spout
clevine336-
The design of a hand sprayer is meant to provide a higher pressure spray (the smaller outlet size means greater velocity in the water coming out of the sprayer head). That said, there could be something constricting the water flow in your faucet. If you unscrew the aerator on the end of the faucet do you get better pressure? Is the screen in the aerator clogged with sediment or mineral deposits? If this is the case you may have water requiring periodic cleaning of the aerator.
Hope this helps.
Regards,
DIYpro
May 01, 2011 | Moen Muirfield Kitchen Faucet with Side...
When we squeeze the handle of the side sprayer, only about half of the water flow is diverted through the sprayer. The remainder continues to flow through the faucet. I replaced the cartridge but the...
yes.
there is a "diverter" under the spout. you have to remove it to replace the diverter. should also replace the o rings at the same time. make sure everything is clean when you put everything back together and use a non silicone lubricant on all the parts and o rings.
Aug 15, 2010 | Price Pfister 34-3LC Genesis Kitchen...
I just installed a blanco faucet with sprayer. Turned water back and then tried faucet but no water comes out. Help
Turn water back off loosen supply lines from faucet turn water back on slowly with supply lines draining into bucket so as to flush them out.If water flowed ok reattach lines to faucet turn both angle stops on full and turn faucet on pivoting handle in all directions.If it still doesn't work take the sprayer line loose from the spout try turning the faucet on again with the line in a bucket. By now you have narrowed it down and the problem should be obvious.Also make sure a shipping plug was not left in line. Hope this helps
Jun 24, 2010 | Blanco Classic Single Handle Faucet with...
We are trying to replace our Moen Adler Faucet and we need to know how to remove it.
first off swhut the water off under the sink,if no shut off valves under the sink then shut the main water valve off.next turn the old faucet on to make sure water is off.now get a light and look up and behind the underneath side of sink,disconnect the water supply lines now way up high there is 2 threaded tubes undo the nuts and the old unit will come out.
Jan 11, 2010 | Porter Cable Moen Legend, Single-Handle...
Water running in Moen single-handle kitchen faucet suddenly stops
There is a small diverter valve on the faucet underneath where the hose connects too it needs to be replaced depending on the age of the faucet I usually recommend replacing the entire faucet with another Moen product
Oct 18, 2009 | Moen Plumbing
My Moen kitchen faucet stopped working suddenly in that only a thin stream of water would flow at most when I turned on the hot water handle or the cold water handle to the maximum positions. I replaced...
wow... I wish you hadn't gone thru the expense of replacing the faucet... it's perfectly good... your problem was the aerator, it unscrews at the tip of the water spout and had collected too much sediment which eventually blocked water flow. Often happens quickly after your water is shut off at the main valve. Aerators cost about 50 cents...
Aug 30, 2009 | Moen Chateau Loop-Handle Kitchen Faucet...
Moen kitchen faucet set wsprayer can't shut sprayer.
there is always water pressure on the sprayer when water is on. if sprayer is leaking check if trigger is stuck in . best to just change the sprayer handle it comes off at the base of the handle
Jul 20, 2009 | Plumbing
Delta Faucet (Series 2467) Sprayer doesn't work
Yes, the diverter assembly is probably corroded or clogged shut. Garunteed its the problem on a 10 year old delta kitchn faucet.The diverter routes water from the spout to the sprayer when the sprayer is triggered.
Jun 02, 2009 | Delta Faucet Delta 2457 Orleans Two Handle...
Kitchen spray not working completely.
Make sure the sprayer is clean of debris. IF YOU HAVE HARD WATER, soak in CLR overnight. If sprayer is clear then its the diverter which is more indepth thru the stem.
Phil
Oct 22, 2008 | Delta 2402 Classic Single Handle Kitchen...
Delta 2402 Classic Single Handle Kitchen Faucet with Side Spray Chrome... Logo
844 people viewed this question
Top Delta Plumbing Experts
bwbconstruct
Level 1 Expert
john h
Craig Butler
Craig Butler
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
