Question about Sewing Machines
Kenmore Sewing machine Model 158-15030
Tension assembly diagram or instructions needed - I have the original instruction booklet, but there is no solution to fix the tension assembly.
  • 106 Answers
SOURCE: Tension disc assembly - sewing machine
Sorry but there is no way to explain how to re-assemble the tension mech on here, you need to be actually shown or have someone do it for you. It is very fiddly and needs to be exact, can I suggest you get in touch with a sewing machine tech who(at cost) will sort you out.
Sorry I cannot be of any further help.
Rob
Posted on Mar 29, 2008
SOURCE: Kenmore 10 Sewing Machine
kenmore sewing machines relics
Posted on Jul 13, 2008
SOURCE: users manual for OLD kenmore sewing machine(158
I need the instruction manual for a Kenmore sewing machine 158.19141
Posted on Jul 12, 2009
  • 255 Answers
SOURCE: how to "tune-up" mechanical Kenmore sewing machine
Sure! Jenny at http://blog.sew-classic.com/categories/Sewing%20Machine%20Repair.aspx has several very good, in-depth articles about servicing your own machine, but here are the basic steps:
1. Take out the bobbin case and bobbin holder.
2. Take the needle plate off.
3. Brush out all the old lint in the bobbin area and under the needle plate. Remove any loose bit of thread.
4. Open the head of the machine (should swing open). Clean any lint or thread that's caught in there.
5. Locate your machine's oil ports and put one drop of sewing machine oil (only use sewing machine oil) in each of them. One drop is sufficient. General rule of thumb: Put one drop of oil wherever metal moves against metal.
6. Using unwaxed dental floss, floss the tension disks.
7. Put everything back together.
If you need a manual, I found one at http://pages.sewing-machine-manuals.com/173/InventoryPage/1834489/1.html.
Hope this is useful!
Robbie
Posted on Jul 30, 2010
SOURCE: Manual for older kenmore sewing machine
Manual Here: http://www.managemylife.com/mmh/lis_pdf/OWNM/1006108L.pdf
Posted on Dec 23, 2010
Need diagram for threading and tension
search for instruction manual on Google
Jan 19, 2016 | Sewing Machines
Assembly instructions for Singer Merritt 4525
The service manual for that machine can probably show you, and I would make sure and get the parts list as well. I just checked Sewing Parts Online, and it was not listed, but if you send an email to them (they give the address at the top of the page), they can and will purchase it for you. Usually takes about 2 weeks. However, I just saw a used one in nice shape on eBay for $72.99 and $27 shipping in the original box, so you might consider just buying another one. I also noticed that a new tension assembly is being sold for $18.95 including shipping, and if you write to them, they may include replacement instructions. Just do a search on Singer 4525 on ebay--they have all kinds of bobbins, foot pedals, and parts for it.
Jul 09, 2014 | Singer Sewing Machines
How do i fix sewing machine tension?
#1 rule in dis-assembly of anything is to lay out the parts in the order they came off. I do this with a piece of tape turned sticky side up on my table. (for future reference)
As for your machine.. since you did not provide a model number the best I can offer is this parts page which has some diagrams under each model. Please locate model from the several pages listed... and view the diagrams.
http://parts.sears.com/partsdirect/getProductType.pd?parentCategory=Laundry+%26+Garment+Care&productType=Sewing-machine-Parts
Aug 19, 2012 | Kenmore Sewing Machines
Need instructions on how to reassemble my tension adjuster on Kenmore model 385.1551. Please help.
If you go to www.searspartsdirect.com you can type in the model of you sewing machine and it will pull up a parts breakdown of your machine. Just look for the section that contains the tension unit. You might be able to reassemble the tension unit once you see all the parts in an exploded view.
Apr 26, 2011 | Kenmore Sewing Machines
Need instruction manual for Riccar 888.
Found the instruction booklet to my machine, and ordered it.
Feb 24, 2010 | Riccar Sewing Machines
Can't balance top/bottom thread tension-model 158.Bottom thread is a straight line. Have increased top tension to the stop. No effect.Have reduced bobbin tension until bobbin and case fall freely when held...
I disassembled the top thread tension controller consisting of 12-13 pieces, including 2 springs. Since they all fell out on the table I spent about 2 hours learning the proper stacking order on the central shaft.
With a combination of reasoning based on each unique piece shape and trial and error I put it back together, adjusted top and bottom tensions according to the instruction booklet for the machine, tested some stitching, made final adjustments and all worked well.
I don't know what was changed in the process but it worked.
Don
Sep 03, 2009 | Kenmore Sewing Machines
Instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Jun 05, 2008 | Kenmore Sewing Machines
Sewing Machines Logo
338 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
