Question about Honda Pressure Washer PSI 3000
Pressure washer stalls
I have a honda gx340 with a cat 45 pump pressure washer. With water running engine starts sounds good then spits and sputters and cuts out. I took to local engine repair they said fuel was dirty and cleaned the carb. I still have same problem. I took gas tank off drained flushed and flushed carb cleaned filter in tank and it still does the same. I was told by cat the unloader seals might be bad but I took that apart and everything looks good, seals tight. There is a lever on engine that moves when engine starts sputtering maybe a minute after starting. Oil is full, gas is new, hydralic oil is full. Fuel ine looks okay. Spark plug looks good, cap seems good.Any clues? Looks like I'll be renting a pressure washer for my job Monday. Thanks much for any insight.
  • 1 more comment
  • derekd_tds Dec 01, 2008
    After all that it seems to have been a fouled plug. FYI cleaning a plug sometimes isn't enough try replacing it!
  • Wilf Blum Aug 20, 2012
    Just loosen the gas cap You won't believe it!
    Just loosen your gas cap! You won't believe it
    President:
  • Honda Master
  • 1,388 Answers
Pressure washers work under very dirty conditions, no wonder they encounter engine problems. Here are a few pointers from a former pressure pump tech. The unloader is a source of engine overloading however this can easily be checked with a pressure guage attached to the gun with a tee fitting having the guage and the normal tip used for the unit. The pressure should never rise over rated pressure. The pressure should drop considrably when trigger is released. The life of the pump and engine can be increased by setting max pressure to 75% of rating. Most engine problems are from following conditions:
Leaking or misadjusted valves; clogged muffer /spark arrester; weak spark coil that is about to fail completely; kill switch/oil sensor wiring and or sensor mal function; gas cap not venting properly causing vacuum in tank and wet or dirty air filter.
All these problems easy to check, fastest repair is to disconnect oil sensor wire to check oil safety system. Then temp replace coil with known good coil. Loosen muffer bolts to check for clogged muffler. Temp run engine without gas cap to check for vacuum. Finally if everything fails, run the engine with carb cleaner spraying directly into the intake. If the engine continues to run with carb cleaner then the problem is fuel delivey and faulty carb. enjoy
Posted on Dec 01, 2008
What RPMis the max torque
the chart shows figures of 10.7 hp-8.0kw with a torque of 19.5 ft/lbs- 26.4nm at 2500rpms ( max net torque)
the chart shows gx390 is 11.7hp (8.7kw) but the torque is the same as the gx340
you can get these figures from world. honda com or by going google and typing in--torque range of honda gx 340 motor at max rpms
10 hp engines running at 2500 rpms will be good for gensets of 5kw continuous out put as most makes run that size engine
Apr 20, 2016 | Honda Gx340 Gas Engine 11hp Motor Pressure...
Why is it stalling?
Mass airflow sensor ? Is the check engine light lit ? What engine - 3.8 or 4.6 ? TPS - throttle postion sensor
Mar 19, 2016 | 2004 Pontiac Bonneville
My pressure washer stops running when i let off the trigger
hi there sal rick85
sounds like the unloader valve is not working or stuck closed , check the setting of the unloader valve may be set too high, the unloader must open in odrder to cycle water back to inlet side of pump - if not builds up heaps of pressure , stalls the engine - service the un loader valves on the pressure head
take look and let me know - what brand your blaster unit is i know its honda but what pump
comet - axd, lw/zw, - in line or axial cam
in the mean time here is good web site on power washers
http://www.the-power-washer-advisor.com/
or go to
http://www.the-power-washer-advisor.com/pressure-washer-pump-trouble-shooting.html
cheers pauly46
May 30, 2011 | Honda Pressure Washer PSI 3000
I have a Honda GX340 power washer and would like to know what types of oil and quantities I need for the engine and pump
The Honda engine will use standard 30W. the pump will use 30W non-detergent.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
Mar 09, 2011 | Honda Pressure Washer PSI 3000
Motorturns over hard with pullstarter on my gx340 pressurewasher
You have a nice setup, lots of power. The honda gx340 has a compression release built into the engine so it should be relatively easy to start. With the pressure pump under load however, it will be very hard to pull the rope. With water connected hold spray gun open so water is running out tip and pull rope to start (for easy start, remove tip from gun) . If it still feels very hard to pull rope while holding gun open, most likely problem with lubrication in pump or engine valves are not adjusted correctly preventing compression release. If you suspect problem, go to store where you purchased the unit or any store that sells gx340 and pull the rope to get a feel of what force is required to start engine and compare to yours. Good luck.
Feb 15, 2011 | Honda Pressure Washer PSI 3000
I want to remove the 4gpm pump on my pressure washer.
HI, It sounds like it is just stuck on the keyway as these can be very tight. You need to force the pump of evenly on either side and should come of if patient.
Feb 05, 2010 | Honda Maxus Prosumer MX5223 Pressure...
97 nissan altima just started runs fine when cold when it gets warn it starts to spit and sputters giving it gas wont help, i checked plugs and there fine checked cap and rotor and they look good i even...
Sounds like plugged catalytic converter, Disconnect exhaust in front of Cat. and see what happens. Check to see if you are losing fluid from radiator.
Jan 11, 2010 | 1997 Nissan.5 Altima
Car spits and sputters and stalls after driving a while
sounds like a fuel pump problem,with fuel pumps u can have pressure but not enough volume,try goin up a steeper hill in 2nd gear and get about 3000 rpms on the engine and see if it really drops out bad and is really gutless,if that happens without a check engine light coming on it might be yur pump and u should also replace the fuel filter at the same time,hope this helps
Jun 29, 2009 | 1991 Oldsmobile Cutlass Supreme
When spray starts engine stops
sounds like unit is drawing air into system or has a low water supply ,you will need to check the litres per minute supply to m/c,also could be grit stcking a valve or worn piston seals (common on m/cs that **** the water rather than being fed from mains supply) hope this helps, this is also very common to cat pumps
Mar 28, 2009 | Garden
I have NorthStar 2000 psi pressure washer with a
1999 campbell hausfield 1800 psi--2.2gpm. weak pressure at the nozzle. water sprays out, but with the pressure of a garden hose.
Mar 20, 2009 | Garden
Honda Pressure Washer PSI 3000 Logo
1,232 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
