Question about Kenmore 22422 Top Load Washer
Stuff stuck under my spinner
How do i remove the spinner to get all the stuff that is stuck under it.
  • 203 Answers
Top or front loader
Posted on Nov 23, 2008
Badger garbage disposal
All garbage disposals should have an on/off switch or best can be unplugged before trying to repair. Once you're positive that it has no power you can insert a screwdriver and remove stuck food item. Sometimes there is nothing stuck and you may just have to reset a small button at the bottom of most disposals. Good luck!
Jan 13, 2014 | Electrical Supplies
Satin sheet stuck under the middle [spinner]. how can I remove it?
A similar question was asked here a while ago.
Macmarkus has your answer on how to remove the spinner here
Aug 21, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
The clutch assembly is stuck although the cluthch
It sounds like the Spinner Shaft Coupler is severely rusted into the Clutch One-Way Roller clutches bearing in the Clutch Pulley and the Spinner Shaft. And if your machine is using the Upper One-Way Roller clutches bearing ring that may be severely rusted to the Spinner Shaft also.
Did you read my Clutch Fix post to disassemble and remove the clutch pulley assembly?
As you can see it’s a tight work area. You may have to rotate the Outer Tub out of the machine to ease removal. I suspect you could have a Tub Seal leak issue. I would lay the machine on it’s back protecting the drain hose exit and tap lightly with a hammer and see if you can free.
Let me know if I can help……Rich
May 10, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Apron stuck under the spinner
Hello blubear0105 ,
Download the Service Manual and take a look at Page 37 “Tumbler Removal” You will need a #20 Torx driver to remove the tumbler the SM doesn’t call that out. It’s easy to remove, post back if you have any questions. Rich
The Service Manual for reference. Sears Parts Direct for reference.
Oct 02, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Sounds like change grinding in spin cycle
This machine is prone to getting stuff down into drain pump. Pull unit away from wall, disconnect plug, hoses etc... Pull back steel panel of of rear of machine, facing rear of machine, drain pump on lower left, rinse pump on lower right, take needle nose pliers or spring pliers and remove hose to tub and drain pipe hose, tilt machine forward, take 5/16 nut driver and remove three screws holding pump, drop pump down, replace pump. Install in reverse order. Then, remove center nut in center of tub, pull center spinner out, then lift top to machine, remove inner tub and clean out metal, money or other stuff from bottom of outer tub, reinstall in reverse order.Once money has gotten into pump it can damage it, so replace it even though it looks good.
Oct 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Water won't go to the top spinners
there is probably food stuck in the spinner,
ive had to remove the spinners on my mind one a year, and use the pressure washer on them, to get out the small chucks of food, and or plastic pieces.
Yes i know we can rinse more, but hey no one is perfect :)
Aug 21, 2009 | Kenmore Dishwashers
Hot point washer heavy duty 7 cycle jewelry caught under spinner
if the unit is just a few months old the agitator has not seised the the shaft. the very top of the agitator should unscrew and with a little effert you should be able the lift the agitator off the shaft collect the jewlry and put it back together all should be find
Aug 10, 2009 | GE WBSR3140DW Top Load Washer
A t-shirt is stuck under agitator/spinner thing. How do I lift off the spin assembly?
yes, remove the softener dispenser at the top of the agitator and there is a bolt there that is holding the agitator assembly. if you remove that bolt, the whole piece can be pull out and you can remove the clothe that was stuck in there.
tnx 4 using fixya,
Sep 06, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag washer top load
good the washer balanced? That can make the spin cycle work ineffectively.
Feb 15, 2008 | Washing Machines
Kenmore 22422 Top Load Washer Logo
104 people viewed this question
Sal De
 Brian Main
Brian Main
