Question about Frigidaire CWS3600AS Top Load Washer
Smelled a burning smell ,clothes very wet when taken out of washer took belt off but belt didnt look bad but not very tight frigidaire washer #FWX133RBS2
  • vonvon591 Nov 18, 2008
    Ok I changed the belt with no problem but i think it was still good,but it is loose so I'm trying to replace the idler arm and torsion spring but I can't get the SOB off it's suppose to have a c clip but I can't find it 'there is two washers on the bottom but no clip or ring. HELP!!!!!!!!
  • 903 Answers
You can't really tighten a belt, I suggest that you change it, although it is extremely hard to replace a a new belt yourself. Have you checked the carbon brushes in the motor do not need changing, this could also generate a burning smell and leave you clothes wet if they are worn.
Posted on Nov 15, 2008
Washer does not spin, has a burning smell. took off front panel. motor pulley feels hot, so does belt. replaced belt 6/09. only wash one load per week. where is the burning smell coming from?
This sounds like a frigidaire washer. If it is, the belt must be the original equipment manufacturers belt. ANY other belt will just slip and burn. The fact that the pulley and the belt were both hot tells me that either the belt is the issue or your main tub bearing is starting to seize.
Mar 18, 2010 | Washing Machines
Smell like burning rubber
if it smell's like rubber it likley is .. smell's like a belt driven and it needs a replacment belt & idler .. remove the two screws at the bottom of front panel an remove .. in the front center at the bottom .is the motor / belt and pump .. if there is black rubber in bottom / wala . the belt is burning . / look for pump leakage / this would get belt wet and slip.. thanks mm .
Dec 02, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Washer was pouring out smoke and smelled liked burnt rubber
You most likelyhave burned a drive belt. Could be a couple things. If the machine was loaded to the max and a bit more, it is possible that a small article of clothes may have been flung into the outer tub and into the pump... this can freeze it up and the motor will keep trying to turn the belt against a frozen pulley.
You'll need to open the machine and check the pump for blockage and change the belt... let us know if we can help with procedures..
Jun 25, 2009 | Frigidaire FWSB5700DS Top Load Washer
My frigidaire dryer had burning rubber smell now wont turn on
soulds like the fuse in the unit overloaded, fluff or oter items may have fallen onto the element, or the unit was overloaded, and the belt was slipping on the motor drive pulley. check for rubber drive belt debri. replace damaged items as required.
Jan 25, 2009 | Frigidaire GLER642A Electric Dryer
Washer has burning smell and does not spin.
It sounds like your belt has burnt off. take the front off the washer or tip the washer back to check it. easy fix.
Nov 17, 2008 | Washing Machines
Dryer not working
The smell was your belt burning into. (If it smelled like rubber) Take the bottom of your back panel off and you will see your belt just hanging in there. Cost $15 to replace and eazzzy to do.
Oct 27, 2008 | Frigidaire GLWS1339CS Top Load Washer
Smoking burning rubber smell from machine
pls help - is the machine done with- it set the smoke alarms off ???
Sounds like the belt is loose and smelled like rubber burning from spinning fast!
Change belt
Let me know.
Please remember to leave a rating
Oct 06, 2008 | Frigidaire GLWS1339CS Top Load Washer
Frigidare top loading washer 6 cycle - 10 years old
you may want to inspect the bottom part and see if it still uses fan belt. it could be that the belt is loose and the motor is spinning but can not drive the transmission. so the rubber burning smell is coming from the slipping belt.
the solution is to tighten the belt or replace it if necessary.
tnx 4 using fixya,
Sep 20, 2008 | Frigidaire CWS3600AS Top Load Washer
Frigidaire CWS3600AS Top Load Washer Logo
558 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
