Question about Kenmore 22422 Top Load Washer
Washers and there spinners
How do i remover th spinner to get what is underneath it
    President:
  • Kenmore Master
  • 2,651 Answers
Theres a7/16 screw down the center shaft of the agitator, with the palm of your hand "smack " off the fabric dispensor, or other agaitor cover, then youll see the bolt inside there
Posted on Nov 26, 2008
How to take washer spinner off
Remove the top of the agitator, remove the bolt that holds the agitator down and lift the agitator off.
Nov 23, 2012 | GE WBSR3140DW Top Load Washer
Maytag model dwu9200aax pieces of plastic and cloth clog some of the rinse holes on the spinning rinse part..how to take apart rinse arm to clean it?
The top spinner part can simply be pulled off by grasping it near its hub and pulling downward. Push it back on and push in the locking clip in the center. The bottom spinner can be removed, First unscrew the center column. Hold the spinner with one hand, turn the base of the center column counter clockwise. Then lift column off. Then the spinner should lift off of the keyed white plastic base. Underneath it, on the neck off of which you lifted it, are two plastic washers that form a seal (supposedly). Good to clean these to make spinner rotate freely, but be careful not to break them taking them off. If you want to go farther in, there is the point of a strange shaped plastic nut sticking up into the base of the column. If you remove this, and the 6 torx screws holding the strainer cap, you can get it all out to clean it up (I had bits of plastic bag in the slots of a 4-armed thing that apparently sprays the filter screen), and scrub the washer in the bottom. Remarkably yucky down there in a 10 year old installation...
Nov 11, 2009 | Maytag MDB6650A Built-in Dishwasher
Apron stuck under the spinner
Hello blubear0105 ,
Download the Service Manual and take a look at Page 37 “Tumbler Removal” You will need a #20 Torx driver to remove the tumbler the SM doesn’t call that out. It’s easy to remove, post back if you have any questions. Rich
The Service Manual for reference. Sears Parts Direct for reference.
Oct 02, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Water won't go to the top spinners
there is probably food stuck in the spinner,
ive had to remove the spinners on my mind one a year, and use the pressure washer on them, to get out the small chucks of food, and or plastic pieces.
Yes i know we can rinse more, but hey no one is perfect :)
Aug 21, 2009 | Kenmore Dishwashers
Hot point washer heavy duty 7 cycle jewelry caught under spinner
if the unit is just a few months old the agitator has not seised the the shaft. the very top of the agitator should unscrew and with a little effert you should be able the lift the agitator off the shaft collect the jewlry and put it back together all should be find
Aug 10, 2009 | GE WBSR3140DW Top Load Washer
Replace tub seal in top load neptune
I‘ll be watching your progress real close with the Tub Seal replacement. I’m going to run this machine into the ground and I’m sure I will develop a Tub Seal leak down the road. I have nothing to offer other then the mention in the SM on page 49 about making sure “”When installing a new seal, make sure the sleeve from the previous seal has been removed and discarded.””. Did you purchase or borrow this tool to remove the spinner nut Spinner Tool $25, or is there another way to remove the Spinner Nut? Good luck. Rich
Jun 05, 2009 | Maytag Neptune FAV6800AW Top Load Washer
The metal spinner piece inside seems to be out of alignment.
When you say out if alignment, does it move up and down inside the tub. If it seems to be hanging down, then most likely a shock is broken underneath. If you can lift the metal basket up and down and hear a clunk sound the the rear bearing may be out.
Apr 09, 2009 | Frigidaire GLTF2940ES Front Load Washer
Taking the spinner off
if you are calling the washplate the spinner pry off the dome then take out the six or eight bolts holding it down.
Oct 25, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
GE Washing Machine
I dont kow what you mean about a spinner? If your talking about the part in the middle thats caled a agitator. If your washer is the model with the plastic tub the agitator pulls up from the bottom. And I have to tell you it is not a easy thing to pull out. The hard gritty substance could be from your water. You might want to have your water checked. Hope this helps you.
Jul 13, 2007 | GE WDSR2080D Top Load Washer
The "spinner, 3rd level wash" kept falling off. Ordered new part, no instructions with it.
I had the same problem, the 3rd level spinner falling off. Without getting into my saga story, save yourself some $$$.
-You will need a screw & washer to replace the plastic thumbtack. The screw will have to be able to screw into the female part of the spinner; the washer will keep the screw from falling out of the hole in the flat hose on the ceiling of the dishwasher.
-If you look closely at the spinner(the part that keeps falling off), you will notice it comes apart. With a flat head screwdriver, separate the 2 parts. (there are 3 parts all together; Keep the round center piece sticking out of the top peice)
--Remove the top drawer of the dishwasher to give you some room to work
-Remove the screw on the "ceiling" of the dishwasher(it is located further back from where the spinner goes) to allow the flat pastic tube to come down low enough for you to get in behind it.(set that screw aside in a safe place; you will put it back later)
-Remove the pastic thumbtack from the hole in the flat plastic tube if it is there & replace with a washer and screw.
-Take the top 2 peices of the spinner, together as assembled & screw the screw into the female portion of the spinner.
-snap on the 3rd piece of the spinner
-replace the screw you took out earlier, securing the flat plastic tube.
-place top drawer
Voila, you are done!! You just saved yourself $20+
May 12, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
Kenmore 22422 Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
