Whirlpool Dryer Model # LE8500SXW3 will not heat, blower works.
This is an older style whirlpool dryer and it will not heat on any setting. It still blows air, although its cold air. The exhaust vent and pipe are clear of lint as is the lint trap. I would like to know what internal parts may be causing this error in operation (I.e. Thermostat, ect.)
  • 147 Answers
Heating element would be your problem
Posted on Nov 15, 2008
Lost ring inside washer/dryer
I am betting it is in the dryer. Here is a video to show you how to open it. Please let me know if you find it in there. Look thru the COMPLETE duct work and blower. I doubt it is in the washer. If it is, it is under the agitator.
If you should need any further help, please visit http://appliancecafe.com/phpbb/ and register to login to the forum.
Good Luck!
Oct 30, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
My whirlpool duet dryer works but it appears that the air is not evacuating from the baril. The heat and humidity built up and the clothes don't dry. Do I need to replace the fan and if so, how
YOU NEED TO CLEAN THE VENT ON YOUR HOUSE IF THE BLOWER WHEEL IS BAD ON THE DRYER YOU WOULD HERE THE NOISE AFTER THE DRY STOPS THE BLOWER WHEEL WILL STILL TURN AND MAKE A NOISE
Oct 29, 2012 | Whirlpool Duet Steam WFW9700V Front Load...
When washing Machine goes into spin cycle, , it starts making a grinding noise and never goes to full momentum and starts to slow down, after the grinding noise. The clothes aren't fully dry as they...
Sometimes, a Whirlpool dryer may not function as you'd like.Although specific details vary by model, the company offers several generalguidelines to troubleshooting your Whirlpool dryer and getting it back intoworking order.
Verify that thedryer is connected to its power source if it won't turn on. Whirlpool alsosuggests checking your home's circuit breaker, as the high power needs of thedryer may have tripped the circuit. If the circuit has been tripped, reset itby flipping it back into the "On" position. Push the door of the dryer. Whirlpool designed its appliances to not turn onif the dryer isn't secured and notes that the dryer door may not be fullyclosed even if it appears shut. Push firmly at the top and bottom of the door,as some Whirlpool models have two latches. Press the "Start" button again. Whirlpool reports that some modelsrequire you to press and hold the button for five seconds to fully start themachine. Depending on the model, the button may be labeled "Hold toStart," "Start" or "Push to Start." Check that the dryer's settings knob is set to an actual drying mode and notsimply "Air" or "Tumble." On most Whirlpool models, themanufacturer states that the settings knob should be set to"Accudry," "Timed Dry" or "Automatic Dry." Clean the lint trap, typically located at the top of the dryer and removedby pulling its plastic handle. Over time, lint and dust builds up here. Thethicker the trapped layer of lint, the slower your dryer performance. Whirlpoolrecommends removing built up lint after every dryer load. Remove some of the wet clothes inside the dryer if it's taking an unusuallylong time to dry your clothes. Whirlpool warns that placing too much clothinginside the dryer reduces hot air circulation, which also reduces dryingcapabilities. Recommended dryer load s vary, with compact Whirlpool modelsholding approximately 3.4 cubic feet while extra large Whirlpool dryers holdingmore than 7 cubic feet.
Jun 07, 2011 | Washing Machines
My whirlpool duet gas dryer will not heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool front loader dryer is not heating
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 28, 2010 | Whirlpool Washing Machines
I have a stackable washer/dryer whirlpool model #WET3300SQ1. Heating element in dryer is not heating. We have replaced the heating element and it is still not working.
heatman101
Aug 18, 2010 | Whirlpool LTE6234D Top Load Stacked...
Changed burner ignitor and still no heat, what next?
Hi, Normal 0 UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it. If there is no rear panel, remove the front lower half and you will see the fuse there on the blower housing. Most models have a sensor on the side of the burner for the ignition too. The fust is the most common problem.
However, if the ignitor glows, you will need to change the coils on top the gas valve.
Please let me know if this help or if I can assist you further.
Thanks
Vic
May 22, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
It runs, but no heat
i dont believe at this time its anything mentioned at top most people dont realize that dryers are split cuircuts
is this a 220 setup
and if its a 220
the cuircuit breaker for this is set by 110 each one for the heating element one 110 for the guages and motor
goto circuit breaker and flip the breakers this should return your dryer working ability
other thing is are the guages working properly
dryer doesnt have to run to test guages turn to the highest setting and let them run completly threw cycle if they stop on a particular setting for a long length of period then the guages are bad
May 29, 2008 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool LTE5243D Top Load Stacked Dryer heats sometimes and not others
couple things this could be lets start obvious
faulty door switch even though door latches doesnt mean its working properly
bad guages easy to check dont have to run dryer just guages
turn on setting let run threw cycle if it stops on cycle and dont move for a length of time this will be the problem
these 2 things are main causes of why a machine wont work or partcially works at times everything else is easy
Nov 27, 2007 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool Dryer not heating
If it was taking longer to heat it probably has a restricted vent. Check for lint build-up. May also have blower cage full of lint.
UNPLUG UNIT FIRST!!
To access blower cage, remove rear panel. Remove four screws holding duct on left side in place at bottom. Remove two screws at filter area on top. Pull duct out at bottom and reach inside and remove lint.
Also ohm out all thermos. Check thermos on side of heater. Check white one to right of duct you cleaned. Check between larger two wires on four wire thermo. All should show zero resistance.
Check between two outside blades of plug. Should have about 220 volts. Pull plug out slightly and carefully check for power between outside blades. Then check for 110 volts from center to either outside blade. It only requires one 11o volt circuit to run, but both to heat.
Nov 08, 2007 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Open Questions:
Kenmore Elite HE4T Washing Machine Diagnostic Test Didn't complete and clothes aren't spun as dry as in the past I have a Kenmore Elite HE4T washing machine and I noticed that recently it isn't getting all of the clothes completely dry from the final spin cycle. Thus, the dryer has to run through two cycles to get the clothes dry. I did a bunch of research and made sure there weren't any kinks or blockages in the drain lines; and opened up the bottom of the washer and cleaned out the drain cleanout. I found a few pennies, but everything seemed to be working ok. I ran a load and had the bottom open so that I could make sure the motor, drain and belt were all working properly. The drain does get the water out of the washer, so the clothes aren't sitting in water, they just don't seem to be spun as fast or as long as they used to. I always put it on the "extra high" spin setting no matter which type of load I run. So, I found a way to run the diagnostic test on the washer and it went through C0-C5 (the agitation step) and all worked great, until it wouldn't come out of C5 after at least 10 minutes and go thru C6-C8. I had to cancel the diagnostic test and hit the "drain and spin" button to get all of the water back out of the washer. BTW, the "drain and spin" seems to get the clothes a bit drier than when I have it run through the "normal" cycle with the "extra high" spin. If anyone has any other thoughts, I would really appreciate it. This unit is in a small space with the dryer attached so to take it out and do repairs is a pretty big hassle. It has had a new control board and two new fill valves in the 10+ years that I have owned it. Questions I have: 1.should I remove the entire drain pump to make sure there isn't anything lodged in it? 2. could it be the belt slipping slightly and keeping the spin from reaching its 1200 RPMs? 3. Anything else I may be missing???
Jan 17, 2017 | Kenmore Washing Machines
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
Richard Roth
Richard Roth
