Bought this g8 camera in Jan 06. Understand about charging batteries fully before using and did this. Ever since I got camera a put battery in after fully charging it gives me very little life. Usually after putting battery in and taking a few photos, switching off and then next time I use it is says "not enough power charge batter" or something like that. But I have just charged it. It is very frustrating as I can't rely on it being available to use without charging the battery. Honestly I get one or two photos taken with a new charge and next time I put it on it comes up with this message. If I physically take out the battery from the camera and put it back in again it might work ok and not show the message. I guess I want to know if I buy a new battery will that solve it or is it something wrong with the camera?
First, make sure you are using the right type of battery. LiMh re-chargeables are the best to use. Brand is your preference. In time you'll find a brand you like the best. Get 1800mAh or larger if you can.
Second, look through the menu on the camera and check to see what battery "type it is set for. "Alkaline" for self bought, Ni cad for rechargeable. This tells the camera how to regulate the power from the batteries. Also using the wrong off the self batteries will give you the same result you mentioned. Make sure it is for "photo" or "cameras".
Third, look into the battery compartment. Look to see if there is any contamination on the brass/copper contacts. A "green" color is a bad sign. Can be cleaned with baking soda and a tooth brush but very difficult. Steel wool wrapped around a cotton swab works but leaves behind small particles (desperate method). Also, sometimes they put a plastic liner inside the battery compartment to protect the contacts during shipment. Is it still there?
Fourth, maybe the battery charger is faulty. It may show the batteries charged but they are not. Try using another charger.
If all these items I have mentioned are OK and check out, then there is really no other simple fix you can do as a consumer and you need to take the camera back. It is an internal problem. You have had it lees than a year so it should be covered by warrentee. I'd push the issue if they say "no"
Good luck and please let me know if this solved you problem, thank you..
Posted on Oct 22, 2007
Aug 20, 2013 | Canon Cameras
Nov 10, 2010 | Canon Cameras
Jan 29, 2010 | Canon PowerShot SD630 Digital ELPH / IXUS...
Dec 20, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Mar 03, 2009 | Canon Digital SD900 / IXUS 900 Ti Digital...
Dec 06, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Nov 01, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Mar 24, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Jan 05, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
97 people viewed this question
