Question about Refrigerators
Compressor to kenmore refrigerator keeps clicking on and off.
My Kenmore 596.72822200 keeps humming and clicking on and off and it seems to be affecting the temp of my freezer and fridge.
I have thoroughly cleaned the coils and back of the refrigerator.
  • 1 more comment
  • mrslamberti Nov 15, 2008
    I was afraid of that. Is a compressor hard to replace or should I get professional help? THis makes sense as the compressor is HOT to the touch.
    Thank you for your reply! What a great service this is, I will be sure to pass it along!!
  • mrslamberti Nov 16, 2008
    Thank you....
  • Anonymous Jan 11, 2009
    when mine kicks on the compressor rattles untill it kicks off,and has done so for about 10 days.
    Scholar:
  • 44 Answers
Before giving up on the compressor you should do the following:
1. The compressor is evidently not running. You can try to start it manually instead of allowing the refrigerator start unit to do so. If it then runs you need a new start/overload unit...about $20 to $60 depending on where you get it. Do not continue to allow the unit to cycle off and on with the overload as that can eventually cause compressor harm. To start it manually the best way is to unplug the frige and completely unhook everything from the 3 compressor terminals. If your unit has a start capacitor you should then short it with a wire or screwdriver to discharge the capacitor to prevent you from being shocked with the fridge even unplugged. Then make up a test setup with wire so that you can apply 120 vac between the run (R) and common (C) terminals. The test set up wiring should include a push button switch to make momentary connection between the start(S) and run(R) terminals. Then with your wiring connected as described plug the test wiring into an outlet and push the button for 2 or 3 seconds and then release. Do not hold the button down longer. The compressor should start and run. If it starts your compressor is ok. If it does not start to run then your compressor may be bad...or...it may be stuck internally with a speck of grit or something and it may still be possible to get it unstuck with additional procedures. If the compressor runs starting it manually you can turn your thermostat to very cold and the compressor will continue to run perhaps long enough for you to buy the start/overload replacement parts and keep your food from thawing.
2. If the compressor will not start manually then according to "Modern Refrigeration & Air Conditioning" bookby althouse/Turnquist/Bracciano you can perhaps start the stuck compressor by:
A."Connect the 120 vac motor compressor into a 240 vac power circuit using a starter cord. One must be careful. Press the push-button switch for only a second at a time or the motor will be damaged. the extra voltage may break the stuck compressor loose."
B. "An extra torque method is to connect a 240 V, 100 mfd(microfarad) start capacitor across the terminals of the run capacitor for no more than one second. (Count "one thousand one.") This may free the compressor.
If none of the above starts your compressor it will need to be replaced.
Posted on Aug 21, 2009
    Scholar:
  • 66 Answers
This is probably due to a bad compressor. Humming and clicking noise comming from the compressor is typical of a bad or over heated compressor. Since you said that you cleaned the condensor coil and fan I would bet that the compressor is bad. This will affect temp of the fridge.
Posted on Nov 15, 2008
  • Charles Caldwell Nov 15, 2008
    The compressor is somewhat of a little trouble to change. There are alot of repaire services out there that will not even start to replace a compressor. It takes considerable knowledge and expierience to do a good job of it. Not to mention the specialized equiptment like a recovery machine and you also , by law, have to be EPA cirtified to handle the refrigerant. You can`t even buy it without an EPA cirtification. To truely help you with your problem, you can find a service repair company in your area right from this site. It will lead you to the professional that you need to do the job correctly. I hope everything was helpfull to you. I am here if you need anymore assestance.
That is so true. But when you know it's right to consider them your everything, that's when you gotta take a chance.
Posted on Sep 26, 2010
Kenmore elite bottom freezer 3 yrs old. buzzes, clicks and hums, stops and resumes the noise, runs through that cycle 2-3 times each time it comes on. It works well, but seems to be keeping things colder...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 01, 2011 | Kenmore Refrigerators
My Kenmore Mod 596.516 is running, but all of a sudden stopped being cold. The vertical fan in the freezer compartment is running. The fan in the back is running. I am pretty sure the compressor is...
The fan is running means compressor is running, But the compressor just keeps on running.The problem is weak compressor.------- Click this link below and follow the troubleshooting:--
http://technoanswers.blogspot.com/2011/07/kenmore-side-by-side-refrigerator.html ---------- this will help.Thanks.Helpmech.
Jul 08, 2011 | Kenmore Side by Side Refrigerator
Kenmore hum click sound
Bad overload relay or bad compressor. You can change your overload relay to test, usually fairly cheap, (55.00 from Sears) however if it is your compressor, it is out of it's five year warrantee and is not worth repair. 900 to 1100.00 to repair in my area.
Jan 18, 2010 | Refrigerators
Compressor motor won't start. Hums and clicks
Most likely the problem is either the condenser coil is very dirty or the condenser fan isn't working causing the compressor motor to overheat and cycle off on its internal thermal limit or the compressor capacitor is defective causing the compressor to overheat and cycle off.
Nov 10, 2009 | Kenmore 57029 Side by Side Refrigerator
Noise & Clicking at regular intervals on working Kenmore 72214
yea that is the compressor relay, you will start to notice your food to thaw out and get bad. try to unplug for about an hour. if then it still does that call www.whirlpoolpartssurplus.com and get a relay kit.
May 06, 2009 | Kenmore 72212 / 72214 / 72219 Bottom...
Kenmore top freezer fridge does not cool but freezer works
Turned refrigerator off for 8 hours, let the frost melt and the fan in the freezer worked again. The compressor now only has a soft clunk when it goes off.
Jan 30, 2009 | Kenmore 64823 Top Freezer Refrigerator
KENMORE TRIO 2004 59675523400 REEFER/FREEZER NOT COOLING
It is the compressor that has failed. The hum is it trying to start and the following click is the overload protector opening. What is the temperature where the refrigerator is located? Allow the compressor to cool down before trying to restart it. If it still does not restart after it has cooled off it is done.
May 17, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite Trio 596 73503200
Did you ever get the problem fixed with the compressor noise
Nov 05, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore not freezing nor cooling. humming noise
DONT SAY THAT COMPRESSORS BAD YET !!!! TECHCUMSE AND COPELAND ALL HAVE THE SAME COMPONENTS FOR STARTING THE COMPRESSOR. ALL COMPRESSORS HAVE EITHER A "PIN-TYPE PLUG-IN START RELAY, OR CAPACITOR START ASSIST RELAY" TO GET THE COMPESSOR TURNING.( FROST-FREE REFRIGERATORS ALMOST ALWAYS HAVE A START-CAPACITOR, RELAY, AND T-STAT COMBO ON ALL MAKES. THE IN LINE BI-METAL TYPE T-STAT THAT PREVENTS THE COMPRESSOR FRON OVER HEATING... THEY CAN GO WEAK. THIS IS THE "CLICKING SOUND YOU ARE HEARING !!! CALL A REPUTABLE DEALER THAT IS "FACTORY CERTIFIED" FOR YOUR MAKE AND MODEL AND GET A "FLAT-RATE" DIAGNOSTIC CHECK PERFORMED. NEVER LET A REPAIRMAN TAKE DEFECTIVE PARTS OUT OF YOUR HOUSE FOR ANY REASON. BY LAW THEY HAVE TO LET YOU KEEP THEM UNLESS THEY ARE REPLACING THEM COVERED UNDER WARRANTY FOR EXCHANGE. UNFORTUNATELY HUNDREDS OF CONSUMERS ARE "BILKED" BY THE " DOI-IT-ALL REPAIR-MAN. MOST MANUFACTURES ONLY HAVE 1 YEAR ON COMPRESSORS FOR REFRIGERATORS 5-10 YEARS ON A/C COMP. DONT BE AFFRAID TO WATCH AND ASK QUESTIONS TO REPAIRMEN YOU LET "INTO YOUR HOME".
Apr 27, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Refrigerators Logo
2,819 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
