Computer will not turn on, the fan kicks on and then nothing the fan keeps running
    Genius:
  • 1,913 Answers
Check your num lock is on off when u press num lovk key.if it on /and off then your ram is ok other wise u have to refix your ram.
clean dust from it and refix again in its slot.
reset your bios put your cmos cell flr 15 minutes then refix it.bios is reset then.
then check u get any display.
also disconnect all cables then reconnect.
check your power supply and earthing.
followthis step by step.
Posted on Nov 15, 2008
SS w/3.8l engine. What would cause the first electric fan not run but when temp rises the second fan will come on?
The coolant fan should kick on when temp reaches 192 degrees. Have you changed your thermostat? The 2nd fan is for the a/c. If car is running hot, it's probably thermostat or cooling fan
Apr 05, 2016 | 2001 Chevrolet Monte Carlo
My 1998 lexus e300 is running hot and I noticed the cooling fans are both running but at low speed. what controls the fan speed
The PCM(computer) controls the fan speed. Low speed comes on around 200 degrees, high speed kicks on at around 225 degrees. If they come on when you first start the engine, the coolant sensor is bad. PCM is in default mode and runs the fans all the time. Since it doesn't read the 225 mark, it won't kick on the high speed. Turning on the A/C will also kick on the high speed fans. That's if your A/C works.
Jun 21, 2015 | Lexus Cars & Trucks
I changed the thermostat and temp sensor and now the car runs hot and the fan will not kick on. even if i over ride it with defrost!!
I think yu have air trapped in the system. You need to burp the air. Try leaving the cap loose and running till it warms up, then tighten the cap and keep the reservoir full.
Oct 24, 2011 | 1993 Ford Taurus
2000 grand am overheats when the car is idle when
If you have A/C, turn it on. The fan(s) should come on immediately. If nothing happens, check that the fan(s) turn freely by hand and don't make any noise (from a bad bearing). Also check the fan relay and fuse. If the computer has a problem, it should show that it has one when a scanner is hooked up to it. The temperature sensor sends a signal to the computer and the computer tells the relay to turn on the fan(s).
Oct 20, 2009 | 2000 Pontiac Grand Am GT
Casablanca fan only runs at highest speed
When I turn on any of the fan speeds fan does not come on. When I remove the blades and turn on the ceiling fan on and give it a push the fan stays running. What could it be?
Aug 30, 2009 | Casablanca Fan Panama II 50" Ceiling
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
Blows low volt fuse comp and cond fan wont run only supply fan runs
you check the fan motor and the compressor winding and terminal you have a short
Apr 27, 2009 | Heating & Cooling
2002 Chevrolet Impala overheating while idling
the thermostates on the 3400 engines are late because the fans kick in at the last moment. if you run your ac on you will notice that the gauge stays in front of the half mark or right on the half mark. that is because when you turn on your ac your fans will kick in earlier and stay on the whole time the ac is on. if you run your car with the heat on or nothing on that leaves the late thermostate to kick in verus you turning on your ac and it by passes the thermostates and runs the fans once the engine gets at at lest 120 deg. i use to have a 2002 and i had the same problem. this will keep your engine cooler. also if you don't want your air on just turn on your windshield defrosters (not the back windshield) and that helps keep your engine cool because your defrosters use your air compressor which is really your ac. so it still kicks the fans on earlier.
Dec 11, 2008 | 2002 Chevrolet Impala
Dayton blower fan repeatedly kicks on and off
chech the air filter is clean and the fan limit switch look to change fan limit
Nov 01, 2008 | Dayton Gas Furnace Heater
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
