Dimmers
Problem for Pass & Seymour Dimmers
Generic problem for all Pass & Seymour Dimmers
T600WV dimmer fails when a 25 watt bulb in ...
By wth_gera on Nov 15, 2008
This fixture has six 25 watt candelabre bulbs. When one of them burns out, the dimmer fails and all that is left is an on- off function. This has happened on four different occasions. Each time I have had to replace the dimmer with a new one. Is there anything I can do to keep the dimmer from going bad when an individual bulb fails?
Comments:
Nov 21, 2008
- The ground wire is continuous from source to dimmer and fixture. Thanks for trying.
Best Solution
posted on Mar 06, 2009
Very Helpful)
hansonsux
Rank: Guru
Rating: 90%, 68 votes
I have had my fair share of this happening. Light dimmers use a solid state semiconductor piece of electronics called a "Triac". The Triac works by switching on and off about 120 times per second so the lightbulbs will be receiving a pulsating voltage. Lowering the knob makes the off time longer so the lights dim. What can happen is the Triac is faily sensitive to current spikes that blowing bulbs can cause the Triac to fail. Triacs often fail closed so that it will not dim the lights any more. The manufacturer can better protect the triac from spikes, but they don't to cut costs. They work most of the time for a while until a blowing bulb takes it out. I am just attributing it to cheapness, and I have had good luck with the box stores and manufacturers giving me a replacement. Please do try and get refund/replacement.
Was this helpful?
Yes
No
Solution #2
posted on Nov 21, 2008
Somewhat Helpful)
kcmetal9901
Rank: Guru
Rating: 87%, 179 votes
You don't have a ground (bare) wire hooked up at the fixture and it need to be hooked up at the dimmer as well
Was this helpful?
Yes
No
Questions and Unsolved Problems for Dimmers
Answer
I had an ETC Unison DR rack with house lights and spot lights, wall controls and a DMX input dimmer... (More)
Answer
when my dimmer switch is turned on, the light comes on at full strenght then about 5 seconds later... (More)
Answer
Need to replace a prescolite ht10u-3p 3way touch slide dimmer 8.3 amp 120 volt 60 hz 1000 watt max.... (More)
Answer
Trying to install pass & seymour / legrand d703p harmony single pole. the old light switch... (More)
Answer
why do dimmer switches make my lights flicker/change in intensity and how can i fix it?...I am using... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dimmers Experts
Top Garden & Power Tool Repair
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
