Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Kenmore dishwasher 16022 sprayer are moves no water
Sprayer are doesn't move,dishes in top dirty
SOURCE: Kenmore 587 model dishwasher produces water but won't spray or move from bottom
top washer arm not turning
Posted on Sep 29, 2008
SOURCE: Where is the filter on a Kenmore Quiet Guard 2 dishwasher?
not a dumb question,
is the bottom dishes coming out clean? there is a chopper that breaks and will trap food and not clean the top rack.it is not easy to replace.but not impossible.
Posted on Oct 31, 2008
  • 9 Answers
I have a Quiet Guard 4. Same problem so will describe my solution.
1. Remove bottom basket. Remove top basket.
2. Remove bottom washing arm. Unscrew (Gently but firmly) the centre post. Lift arm assembly up and out.
3. Remove overhead conduit. One screw at back, one at top (Philips #2 bit). Rotate whole assembly 45 deg right (Clockwise) and lift off of centre post.
4. Remove centre post (Pull straight up). Remove 4 screws (Star T-20 bit). Lift whole assembly out. Pop off screen and clean.
5. Remove cap over cutter/chopper. There is a single screw at front left (under assembly removed in 4). Remove screw (Star T-15 bit) and cap (Needs some wiggling to free it up). Remove cutter and filter. It is on a spring loaded pin. Pull the cutter blade foreward and then the filter disc straight up. Clean thoroughly as it may be the cause of your problems.
Reassimble. Good luck!
Posted on Jan 02, 2009
Kgt1962
  • 59 Answers
SOURCE: dishwasher that leaves dishes dirty
Your drain could be blocked, remove the drain from the trap below the sink and try running the unit on drain, into a bucket. Also check the connection at the trap to ensure it is free from blockage
Posted on Mar 19, 2009
  • 28 Answers
SOURCE: Asko1585 sprayer arm not working
Most likely the circulation pump. On this pump there is mounted a condensator. This will help the pump to get started. If this is broken, it wont circulate the water up to the sprayers.
Posted on Jul 27, 2009
I had the same problem I own a Kenmore Elite dishwasher. Diverter motor needs to be replaced. The diverter motor is connected to a plate that controls the flow of water to each washer arm. When the plate moves it has holes that align to the proper tube that supplies water to a washer arm. When the diverter motor is broken it is unable to rotate and cannot direct flow of water. When this happens water will only be able to come out of one spray arm in my case the back sprayer or turbo wash. The diverter motor is located under the dish washer and the diverter plate is located under the bottom sprayer arm.
Dec 01, 2011 | Kenmore Dishwashers
I have a Kenmore dishwasher, purchased in 2000, it is not cleaning the dishes on the top rack, just happened all the sudden.
You should check to make sure that the lower sprayer is extending to spray the bottom of the top rack and that water is being pumped up to the top sprayer. You will need to take the dishwaher out of the cabinet to test.
Jul 15, 2011 | Kenmore Dishwashers
The dishes on the topshelf come out dirty
Check to verify that your top water sprayer is operating. It could either be blocked prohibiting movement or not spraying at all. Usually this is a problem with washer overloading. You may want to scale back on how many dishes you put in.
Mar 03, 2011 | Kenmore Dishwashers
I have a Kenmore model 1374 (ultrawash quiet guard). Recently I've noticed a lot of dirty residue left on the top rack dishes. I looked in the back of the dishwasher and noticed something with the little...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Dec 26, 2010 | Kenmore 13742 / 13744 / 13749 Built-in...
My whisper quiet dishwasher is not cleaning the top rack dishes
I'm having the same problem. Did some testing and found that the sprayer on the top rack is not even moving and hence not getting any water. Not sure what to do.
Sep 07, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
It is filling and running but the water is not
Could be two different things -- either the pump is not moving water through the sprayer arm, or the sprayer arm isn't free to spin around.
I've fixed one of each in the past year, so either is reasonable.
First, check the easy one -- the sprayer arm.
Open the dishwasher and pull the bottom tray forward so you can reach the sprayer arm.
Reach in and try to spin it around by hand. It should move freely, and if you flick it around, it should spin a full turn around before stopping.
If it's unable to move at all, then look for something stuck like a fork or plastic bag.
If it moves, but very quickly stops spinning, it might be a foreign object or it might need a new sprayer arm assembly. The one I got this year was $38 including shipping.
If the sprayer arm is free and easy to move, then check the water pump:
Start the dishwasher and listen. When it's done filling and sounds like the wash cycle, quickly unlock and open the door.
It shouldn't spray water in your face, but there should be lots of water dripping from the racks and the top (and the dishes, if it's loaded when you do this test!)
If not, then the problem is either a failed main pump or a blocked pump, and the repair will be a bit more money and a lot more time.
If this helps, be sure to click the thumbs-up to tell me so!
Sep 01, 2009 | Maytag Dishwashers
My kenmore dishwasher model66516034401 does not
do you have a sprayer on top portion of dishwasher? if you do make sure it turns when dishwasher is running. check to see if holes in sprayer are open and not colgged up. you can clen it by pacing it in vinegar.
Aug 20, 2009 | Kenmore Dishwashers
Dishwasher sprayer arms not working
you are not getting enough water inside of dishwasher.you can pour 1gal of water inside. to see if arm work better should be 3 or 4 inches of water in side of dishwasher. water valve maybe bad or dirty screen inside of valve.ck to see if enough water is in bottom of dishwasher.ck to see if flote switch in left front corner of dish washer is moving up and down.
Aug 12, 2009 | Kenmore Dishwashers
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
29 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
