Question about Pioneer PRO-200 60" Rear Projection Television
Tv turn itself off after a couple of hours
My pioner tv 6 years old turn itself off after 2 or 3 hours, I have to get up and turn it back on, that happen a few times while watching tv.any solutions.
    President:
  • 3,130 Answers
Your problem is bad solder connections on the sweep or power supply board. In some rare cases I have seen the regulator IC with ring cracks arounfd the leads and causing the set to shut off all by itself. If you know how to solder and work on solid state printed circuit boards, you should not have too much problems finding bad connections or monitoring the B+ voltage to see if thats what is cutting off the set. If you have no circuit experience with TV's play it safe and call in a pro to assist you in this repair, as it should not cost too much to find this problem, if it is just bad or cold solder connections. Good Luck Please do not forget to rate this thread.
Posted on Dec 10, 2006
Why Intermitant Power Loss
Its probably a Power Supply failure replacing it will mostly fix your problem
Jun 20, 2014 | LG 42LD550 42 in. TV
Sony 42 inch plazma display on screen ...fan problem powering down
if the fans are stopping you will need to replace them
Apr 29, 2014 | Televison & Video
50v710 turns off by itself then on
Have you check the power supply,that's what it seems to me.
Jun 29, 2009 | Hitachi 50V710 50" Rear Projection...
My sony wega keeps cutting off then coming back .
a couple of years old can be a long time:
has the TV been on 24\7
It's the amount of hours that matters..
electrolytic capacitors typically last 3000 to 5000 hours....
Special "long life" caps last close to 7000
but the caps in most consumer electronics, even broadcast equipment 3-5K hours.
Jun 16, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv just turns off and on by itself
there is a problem of power supply unit?check all 4.7uf capacitor or replace
Dec 10, 2008 | Mitsubishi WS-48311 48" Rear Projection...
Samsung dlp hdtv turns itself off
Have a 46 inch behaving the same way. I have the extended service contract, so they are getting a calll tomorrow. I ll post what they say
Dec 27, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung 1080p turns itself off
Probably a bad Inverter board. I have a Dell 32" LCD TV but it has a Samsung Panel inside, found a burnt transformer on the inverter board, Still trying to find a replacement.
My TV comes on for a second then goes black, power still shows on but no picture. 1.5 years old
If you are not a tech person, take it in for service.
Dec 27, 2007 | Samsung HL-R5678W 56" Television
TV WILL NOT TURN ON
i HAVE THE SAME TV, SEEMS LIKE THE LAMP IS OUT. BUT ONLY TWO YEARS USE? WOW. iVE HAD MINE FOR 3 YEARS WITH ATLEAST 6 HOURS PER DAY USE. WELL GOOD LUCK AND DONT LET A TECHNICIAN CHARGE YOU 200 FOR LABOR TO TAKE OUT A FEW SCREWS
Dec 17, 2007 | LG 52SX4D 52" HDTV
Turn off
this happens to my tv as well it simply will just shut off and turn itself back on and then shut itself off every 2 - 3 minutes...can someone help??
May 24, 2007 | Polaroid FLM-2011 Television
Pt 56tw53 picture trouble
I had the same problem with my TV, It seems the high voltage trasnformer blew which in turn casued the pin cushion?? to blow. It then shuts the tv off to prevent more damage to it. $500 with service charges to get it fixed!
Nov 05, 2005 | Panasonic PT-56TW53 56" Rear Projection...
Pioneer PRO-200 60" Rear Projection Television Logo
192 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
