Question about Nor-Lake Norlake Refrigeration 4' x 6' Kold Locker Walk-In Cooler - 6' 7'' High w/Floor
Movers dropped the fridge 4 steps going to basement now it is hot
I have a kenmore elite fridge model# 9651884 & it was moved to the basement but dropped 4 steps
Since we put the power on it is really very hot to the touch at bottom sides of fridge where the bottom freezer is..
Is this normal or not?
    President:
  • 1,462 Answers
Heat in this area is normal especially when just switched on
Posted on Nov 16, 2008
Kenmore elite he4 moder 110 won't heat
In terms of likelihood, here is what's wrong:
1) The heating element has failed.
2) One of the several "overheat thermostats" has overheated and failed.
These are found in the back or the bottom of the dryer in the rear.
3) One of the wires to something, like the heating element, has burned in two.
4) The panel where the electric cord attached to the back of the dryer has failed. This will be inside the back of the dryer, usually behind a small plate.
5) The circuit breaker for the "heating" circuit wire of your dryer is popped and needs to be reset. (That is the circuit breaker found in your hall, or basement, or garage, or wherever.)
If you decide to fix it yourself, a question to "fixya" might get you step-by-step instructions.
Be blessed
4)
Feb 11, 2013 | Dryers
Kenmore elite model#5059903 the divider between the freezer and fridge gets extremely hot.
Refridgerators have coils than run thru then body of the fridge. They are there to reduce moisture and condensation. It is normal for tham to get warm and sometimes they do get hot it happens when the coil is too close to the body. Normally it only happens periodically. If it is so hot it burns or if it stays hot and dont stop than you have two options. #1 move contents of fridge to another location (back up fridge) and unplug for 24 hrs leave doors slightly open and have some towels near bottom there will be a little bit of water. Plug back in if this does not work. Contact the manufacturer and let them know. There may be a defect in the design.
Jun 05, 2011 | Kenmore Side by Side Refrigerator
Re:Model W210RWO Serial # LA23214707 Repairman told us compressor on this fridge is defunct. Fridge was in our basement and when we moved into this house, the movers had great difficulty getting it...
once you reclaim the freon the only thing left will be the oil if the fridge has been upright all the oil will be in the compressor cut the lines going to the compressor and crimp them off then remove the compressor and some fridges have whats called an accumulator a small tank near the compressor cut the lines and crimp them off before removing it and you will be ok to demo and move.
Nov 16, 2010 | Westinghouse Refrigerators
How do I replace the water line in the door?
Find your route to the water line. Drill a hole in the floor behind the refrigerator and thread the copper tubing into the basement. Go to the basement and find the main water line and pull the copper tubing to it.
Step 2
Attach pipe to refrigerator. Go back up to the kitchen and attach the end of the copper tubing to the water pipe of the refrigerator. You can use a nut and ferrule to connect the tube to the fridge. Make sure to leave a little bit of copper tubing coiled behind the fridge so as to not disconnect the tubing when moving the fridge.
Step 3
Turn off the water. With the fridge all hooked up, go back to the basement and turn off the water. Find the cold water pipe and drill a 1/4-inch hole to accommodate the copper tubing.
Step 4
Attach valve to pipe. You need to attach the water valve to the main pipe. This allows you to control the flow of water to the refrigerator. Make sure you have a gasket to seal between the valve and main water pipe.
Step 5
Connect the copper tubing. With the valve connected to the main water pipe, connect the copper tubing using a clamp. This should be everything you need. Turn on the main water and you should be able to get a glass of water, but it will take an hour or two for the ice cubes to freeze.
Take care..
Aug 08, 2010 | Kenmore 53092 / 53094 Side by Side...
Washer vibrates alot
The following link may give you some pointers on what to check on your kenmore Elite to resolve the vibration problem:
http://www.fixya.com/support/r3633026-front_loader_excessive_vibration
This could be a matter of the legs becoming unlevel during the move, a shock absorber becoming damaged, or it could be the new location. These front loaders need a good firm and level foundation. Read through the link provided and let me know if you have any questions. I hope this helps you solve your problem.
Dec 18, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Drawer Dishwasher leaking
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
ppi
Jun 29, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Fridge is hot, freezer is working properly
The temp control damper solenoid is frozen closed - or the solenoid itself is failed.
CLICK HERE
for the part
#13 in THIS DIAGRAM
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 17, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite side by side: hot divider
This is normal. There is a heater in this panel to stop condensation sweating between the doors.
Feb 23, 2009 | Kenmore Refrigerators
Kenmore Elite Oasis Dryer top removal
there should be 2 clips you kind of press and then it should pull off. if not look to see if there is a leg that also go's into the bord if so you need to move it in to reles it from the bord and then it should pull off.
Jul 27, 2007 | Kenmore 67082 Electric Dryer
Refrigerators Logo
82 people viewed this question
Top Nor-Lake Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
Are you a Nor-Lake Refrigerator Expert? Answer questions, earn points and help others
