Question about Car Audio & Video
Bose delco cd radio for 97 pontiac
Radio works cd does not E20 shows up on the display when cd is inserted can It be recoded to work or is it NG. cant find codes to unlock it if it is locked.
  • 43 Answers
I don't know your experise when it comes to repair. This problem is normally a bad laser or spindle motor. You can clean the laser and spray a Cleaner/Lubricant into the openings on the bottom of the spindle motor. This is a common problem I see with this stereo when it comes to repair.
Posted on Nov 17, 2008
My 2000 chevrolet z71 radio comes on and does not have sound i have changed the radio out with another delco radio recoded it turn it on has the same problem
If this is a BOSE system the BOSE systems have self-powered speakers. In other words, they have a small amplifier built in with the speaker system to produce the sound. They are a "bear" to diagnose and expensive. Check to see if it has the BOSE symbol on the speakers and radio...
Aug 28, 2014 | Ac Delco AM-FM Radio Cassette
Tip
Delco Radio displays and climate control displays remain dark, all GM
Symptom is radio diplay or controls don't light up, Delco CD radio's and Bose preminum sound radio/CD players. Models all GM cars and trucks 1990's to presnt.
This problem is caused by two tiny burnt out bulbs behind the LCD display thay are soldered to the circuit board behind the radio LCD display and can be replaced, this requires the radio be removed and the housing taken off and the front display un-clipped, you will need a low temperature solder pencil and thin strand solder the bulbs are available from Radio Shack, the part number is 272-1092, this is a 2 pack of miniature 12 Volt 60Ma bulbs. This radio display bulb is used in may car models, this bulb also repairs climate control displays as well as other low light displays like switches
on Jan 31, 2010 | Pontiac Grand Am Cars & Trucks
I put a 1997 pontiac delco cd player in my 95 pontiac and when i put a cd in it ejects and says E20
Make sure you are using a original CD and not a copy. Some of the older CD players and some new also have problems with a copy CD.Try a original CD and if that does not help then try cleaning it with a CD cleaner and if that wont work then i would say its time for a new one.
Apr 22, 2012 | Pontiac Cars & Trucks
E20 on cd player when I insert a cd into the player it reads E20...and just played a cd ...took it out and started another, then tried others and they all read E20
your cd player is unable to read the discs. may want to try some of the computer cleaner spray/ duster. spray the computer duster into the cd slot and it may clean the laser to let it work again.
Aug 01, 2011 | 1999 Pontiac Grand Am GT
CD player has no sound - Bose wave radio/cd player
Amplifier chip/circuit is kaput. Unless you are familiar in fixing electronic equipments better to give it for repairs................sodeep
PS. Buying a new one will not be cost effetive unless you need a change!
Jun 28, 2009 | Bose Wave radio/CD remote control -...
What does E20 code means on a delco cd player?
Hi E20 mean's
The CD player cannot focus on the disc or there is an internal focus problem.
try a known good CD and if it still displays E20 then you will have take it to a radio repair shop
May 10, 2009 | 1997 Pontiac Sunfire
Error on cd
Could be a number of things. Some of the older GM CD players don't work too well in very cold weather. Also, some of the older CD players won't play burned CD's. If it's not cold weather related, and you're using a regular production store-bought CD, then it is most likely an internal radio problem. Cheapest solution is to buy a cheap aftermarket player.
Mar 11, 2009 | 1999 Pontiac Sunfire
Need to get unlock code for 1998 Grand Am
you need to goggle the year of the car and the problem an you should find the code that is were I go to find radio codes
Mar 04, 2009 | 1998 Pontiac Grand Am
Car Audio & Video Logo
201 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
