Question about Sony KDSR50XBR1 50" Projection HDTV
REPLACED LAMP IT SEEMS THE LAMP DOOR HAS A MICRO SWITCH AND ITS NOT WORKING I GET 3 RED FLASHES" BULB NOT INSTALLED CORRECTLY OR DOOR NOT CLOSED" CAN I BY PASS IT OR JUMP THE CONNECTION? ANY THING I CAN DO BESIDES ORDING THE SWITCH WAITING 2 WEEKS AND HOPING THAT WAS THE PROB ??
  • bioguard65 Nov 16, 2008
    thank you, i bypassed the door micro switch and still 3 flash, im going to remove the entire back cover and attempt to bypass the interior switch, before i do that my question is could it possably be some other malfunction than what the indicator 3 flashes tell me >?
    ok ill take your advice. one final concerne, the front micro switch i beleve that is the source of this disaster is where i un pluged the connector from the tiny board the switch rests on and the end from that comes from the set i went 1.5 inch up and cut and then connected the two ends " i did this as a by pass" is this a valid procedure or is there another or better way??
  • 320 Answers
The switches (there are two of them) can be bypassed but it isn't a fun job. There are 3 connections on the switch boards and if you connect all 3 together, that should bypass the switch. There is one switch on the door and another located on the lamp socket board. You can bypass on the door but there is no way I can describe how complicated it is to get to the one on the lamp socket. So, try jumping the one on the door and see if helps. REMEMBER THAT THE LAMP IN THIS SET CAN CAUSE BURNS, VISION DAMAGE AND OTHER PROBLEMS SO AFTER YOU HAVE JUMPED THE SWITCH, PUT THE DOOR BACK ON AND MAKE SURE YOU HAVE THE CORD UNPLUGGED WHEN YOU WORK ON THE TV.
Posted on Nov 15, 2008
  • 1 more comment
  • Any Guy
    Any Guy Nov 16, 2008
    Bioguard,
    To get to the lamp safety switch is a major teardown involving disassembling thel amp chamber and removing the lamp socket. I REALLY don't recommend you try this as it is very easy to damage the set when making this repair. The entire set chassis has to be removed so you can get access to what you're looking for and should only be attempted by someone who has training on the set. Believe me, if I could walk you through this safely I would, but it's not something that I can describe easily, I had to be shown and even then when i did it by myself the first time it took me 3 hours to get everything back together and working.
  • Any Guy
    Other than a connector for the safety switches being unplugged, I have never seen anything else cause a 3 flash shutdown except bad or broken switches
  • Any Guy
    My advice would have been to bypass the connections on the switch board itself rather than cutting any wires. Your Sony tech, whoever you get might want to replace that harness you cut due to the heat produced in the set and the fear that it might cause you problems in the future. Those switches are supplied on the circuit board as an assembly.
Sony grand wega 3lcd light is flashing red 3 times
Three flashes is lamp cover/lamp position error, it means the lamp cover is not set right, or the lamp is not in the right position. There are two micro switches to detect the lamp position, and lamp cover. Please reset the lamp and the lamp cover (door).
Aug 01, 2017 | Sony Televison & Video
Kdf-e50a11e diagnostic codes
3 blinks is indicating the lamp has burned out. Aftermarket lamps tend to fail quickly. Only use oem replacement lamps for your sony. You can get replacement lamps from www.tvrepairworld.com
Feb 07, 2012 | Sony KDF-E50A11E TV
I replaced the projection lamp and the light flashed red 3 times after researching i found it was the projection door now the light just flashes red non stop
There are usually several micro switches (little metal levers) inside the projection tv - most commonly by the lamp assembly and behind the lamp door.
It's possible either:
a) the lamp is not fully seated into position - ensure the lamp assembly is locked into position and that all screws have been secured, which will correctly close the micro switch.
b) the lamp door is slightly misaligned - ensure the door is aligned properly (do not force it) and all screws MUST be secured into place, which will correctly close the micro switch.
If the above items are in their correct positions, then you may need to test the 'continuity' of the switches (open & closed) using a multimeter, to determine whether you many have a faulty micro switch.
Hope this helps..
Oct 31, 2011 | Sony KDF-50E2000 50" HDTV
I was given this model tv. The green and red lights on the front are flashing. Says to replace bulb and close lamp cover correctly. I am missing the lamp cover. Is that going to be a problem?
U mean the Lamp door cover?Yes?Tv might work,might not.Don't know never tries to turn the tv on before without a Lamp door cover close before.There is a blue safety switch though must be press down when the Lamp door cover is close.Test it out.Why don't u just take a piece of tape and tape that blue safety switch down tightly,than turn on the tv.If the tv message that said close lamp cover correctly disappear.Than yes the tv will work,without the lamp cover closed.Now u just needed to do a replacement of the tv projection lamp only that all.
Sep 24, 2011 | Toshiba 62HM95 62" HDTV
I have a Whirlpool side by side fridge freezer with ice maker and water dispenser which is about 3 years old. Model number I think is WSC5533. Recently I had an interior lamp bulb blow in the fridge which...
HI,
You may have a failing door switch which is causing this problem, if you remove the bulb and close the door, the the red light out? If so, its possible you bulb is fine, you door switch has failed.
I hope this helps
Jul 26, 2011 | Whirlpool Refrigerators
I replaced the bulb on th SONYKDF-50E2000. I broke the right arm off the outside lamp cover. The bulb seems to be seated well but I get the 3 red lights when I tun it on. The green light lasts 2 seconds...
Yes this arm on the lamp cover is essital .. this arm push a switch close that tell the set the door is closed.. the three blinks is the error code for the door not being closed. can u glue the peice back on.... or else you might have to get another cover
Mar 18, 2011 | Sony KDF-50E2000 50" HDTV
I push the power button standby light turns red & blinks 3 times 7 THEN TURNS OFF
If the standby light is flashing 3 times. (your post says 3 times 7) I was unclear... A error code of 3 blinks inidicate that the door covering the lamp is not secure oer the lamp is not secure. Make sure the lamp door is seculy screwed down. ussally the door push a little switch closed. If this doesnt work the next thing to try is to remove the bulb carefully(dont touch the lens) and replace it making sure the bulb is in place securely. let me know if i can help any further
Mar 04, 2011 | Sony KDSR50XBR1 50" Projection HDTV
Just replaced the lamp after 2 years. TV worked
Make sure that the lamp cage is seating well .. then make sure the door is closed properly. there is a door switch and if the door dont close right the switch may be telling the set the lamp is out.
Oct 23, 2009 | Mitsubishi WD-62531 Projection Television
I replaced bulb on pt60lc13 and did steps to reset timer, however screen won't come on so don't know if it reset. Power button flashes for about a minute then flashes red continuously. Lamp light flashes...
Make sure that your lamp is install correctely or that the door closed properly. After a proper lamp installation you should get a blue screen with a sign prompting you to reset lamp timer, follow up instructions and reset it.
Sep 24, 2009 | Televison & Video
I replaced the bulb in my sony kdf-46e2000 tv but it still shuts off after about 2 min. the red light flashed 3 times which means the lamp door is not secure, I have tried the procedures to fix it but it...
have you tried to temporarialy by pass the lamp door switch, or checked the switch to see if its working when the switch is in the closed position?
Jun 13, 2009 | Televison & Video
Open Questions:
Sony KDSR50XBR1 50 black screen, no faults! Lamp working, fans OK Sony KDSR50XBR1 50" HDTV: The light engine was working fine before the fan quit starting on it's own. After disassembly, cleaning and lubrication of the fan, I have no errors but the input display or menu options will not post on the screen. The lamp is on but seems to either be projecting a solid black picture, or not be at full brightness and there are no faults. I have a solid greed LED on top, but can get no picture. Sound is fine. What should the lamp voltage be at operating mode? I have tried reseating connectors and pushing on the wires to make sure the connectors seat. This is baffelling because the lamp fired fine for 1 second before the stuck fan issue was corrected and I have no faults now after lubricating the fan. I'm going to check connectors again today as a triple check; as I did remove the power supply. The TV has been reset per instructions in the book. Any advice would be much appreciated but I cannot believe it's the OB as it worked fine before the fan quit and it's about 14 months old. I'm thinking something may not be assembeled correctly, but everthing seems to be pretty idiot proof for re-assembly. Also the menu or input banners will not post. I have 2 new lamps, so it's not that.It seems to be stuck in somne black screen mode. The large fan does start by itself now after cleaning and lubrication, therefore no fault blinks. Please help!!!
Mar 01, 2017 | Sony KDSR50XBR1 50" Projection HDTV
Sony KDSR50XBR1 50" Projection HDTV Logo
429 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
