Question about MTX Ford Explorer/Mercury Mountaineer/Mazda Navajo 1991-2001 Thunderform Loaded with 10 Inch Woofer and ... Car Speaker
Rough idle on 1991 mazda navajo
I have a 91 navajo with 105,000 miles on it I have already replaced the following.....IAC,MAF,IGNITION COIL,PLUGS/WIRES,O2 SENSOR, AND YET I CONTINUE TO HAVE ROUGH IDLE, it runs great has good power but idle is bad , at this point it is driving me crazy any one got any ideas....thanks
It is the throttle positioning sensor about 40 dollars at your local parts store.
Posted on Jan 08, 2009
I have a 99 mazda 626 runs and starts fine but stalls when coming to idle i already changed maf sensor
check and or clean the (IAC) idle air control, this is what controls idling on most of todays cars and light trucks. if iac is removed for cleaning. clean out where it mounts to engine or fuel injection unit. good-day !
Jan 31, 2012 | 1999 Mazda 626
2003chevy pu dies at stop lights, low idle whats wrong?
yea id definately try cleaning ur throttle body 1st. My 03 1500hd had the exact same bad idle after my battery went bad it would die at lights unless i kept foot on gas i cleaned throttle body runs perfect now took 30min cost 8$ for cleaner at autozone and theres how to videos on you tube
Aug 13, 2011 | 2003 Chevrolet Silverado 1500
Car has been tuned still idles rough and at speed of 40mph is it the oxygen sensors
try cleaning the IAC (idle air control) sensor and check the hoses going to the MAF (mass air flow) sensor, i have found both causing me problems with erratic idle. the IAC was totally gunked up with carbon on the pintle and i had found that the screws holding it down were loose ( but only clean this with throttle body cleaner, not carb cleaner it might damage the sensor, and replace the vacuum hose to the MAF sensor, i found mine was cracked and old and brittle, a car that has been run poorly for a long period of time might also cause a problem with an oxygen sensor and this would lead to poor fuel economy also, try to clean that up or just replace it. Also have the transmission fluid serviced, i have seen this problem lead me to think i had an engine idle problem or rough perforamance when accelerating. can you rate this!
May 08, 2010 | 1991 Chevrolet Corvette
98 explorer 4.0 missfireing and rough idle 147000 miles changed plugs and wires and coil pack no change tried sea foam injector cleaner and ran for 50 miles nochange code says #4 cylander misfire what...
Check/change the #4 plug. Make sure the gap is right, ceramic not broken, and that the plug wire is on correctly.(both ends) Did you use dielectric gel when you installed the plugs? Good idea to use it.
Apr 01, 2010 | MTX Ford Explorer/Mercury...
2005 Mazda 3 idles rough at stop light and sometimes dies
The ignition coil should be fine at that mileage. If spark plugs do not fix it suspect a faulty MAF sensor. If the MAF is sending a bad signal it will affect with the idle as the ecu is trying to compensate for the MAF.
Apr 22, 2009 | 2005 Mazda 3
Rough idle ON 97 FORD MECURY
the problem may be a buildup of carbon or fuel varnish deposits in the idle speed control valve (also called the idle air control valve or IAC valve). The cure for this condition is to clean the valve with some aerosol throttle cleaner or engine top cleaner. disconnect the air ductwork from the throttle body. Start the car and run at about 1500 rpms spray the cleaner directly into the throat of the throttle body. Turn off the engine and let sit for a few minutes. Then repeat the process a couple of times. if that does not work, you can remove the IAC and clean it by spraying into the two holes on the underside of the valve. If not, then you need to replace the valve.If that does not work , then check for a code. the throttle position sensor may be the problem. you can have it scanned at an AutoZone or other parts store.
Nov 28, 2008 | MTX Ford Explorer/Mercury...
Coolant leak 1991 mazda navajo
if you smell antifreeze ,and belive me youll know its antifreeze ,inside the car or the windshield will fog up when defrost is on ,you have bad heater core
Aug 26, 2008 | 1991 Mazda Navajo
Misfire and rough idle
It may be the Ignition module. This is the little thin circuit card that tells the Coils to fire. Trace the small electrical wire from the 1,3 coil back to this module.
Dec 11, 2007 | MTX Ford Explorer/Mercury...
Car Audio & Video Logo
166 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Mark Skinner
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
