Question about Philips Magnavox TS3260C 32" TV
Where should i connect power cord in philips magnavox smart series tv
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 56 Answers
Don't understand the question, but the power cord sure goes in to a regular AC outlet.
Posted on Nov 23, 2008
I have just been given a hand me down Philips Magnavox Smart Plus Series TV, but it is giving me a code, ,and I do not have a remote control, how do I get to channel 3
You may have to purchase a programmable remote control as a replacement and use its code search feature to find a code that will control your Magnavox TV.
Feb 05, 2015 | Philips Televison & Video
Can't find install code for philips magnavox smart series plus
Universal remote codes for Philips Magnavox TV are: 0062 0204 0207 0183 0226 0288
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Sep 27, 2012 | Philips Smart Plus TP3285C 32" TV
No sound, no picture. tried unplugging and plugging back in...same problem. the green power light just keeps blinking 14 times over and over again. tv is around 11 yrs old...philips magnavox 32" smart...
check your h-out transistor, in high voltage area, capacitors and resistors, need reservicing and resoldering....hope you can do it, or check out with qualified tech
Oct 25, 2009 | Philips Magnavox TS3260C 32" TV
Philips magnavox smart series pr1920c601 turning off itself!
well let me ask ya something so it is coming back by its self then going back out may be solder connection okay call tv shop good luck shad
May 03, 2009 | Zenith B27A11Z 27" TV
HOW TO REMOVE CLOSE CAPTION FROM SMART SERIES TV
on your remote go to cc push that until it sayes closed caption off not positive but pretty sure
Jan 11, 2009 | Philips Magnavox 20MS233S 20" TV
Need Unlock channels
I called Philips Magnavox at 1 888 744 5477 and they told me the default ACCESS CODE number is 0711. It works on my TV though it didn't solve MY problem of the TV defaulting to Chanel 9 every time I turn it on. Drats. Hope this helps.
Jan 01, 2009 | Philips TP2784C TV
Need codes to unlock the smart block on my phillips magnavox tv
do you have a 3 digit code for RCA TV for the philips universal remote?
Dec 30, 2008 | Televison & Video
DVD input with signal access
IF I understand you correctly, the VCR, Satellite, etc is connected using an RF modulator/coaxial cable wire going into Antenna in
IF this is true, then you have an AV IN port (red, yellow, white) free on the back. Just connect the red, yellow, white from the out of the DVD - you can use 1 or 2 - just remember which one you used; and connect it to the AV IN on the back of the TV.
THEN press ch down on the TV remote until you get to "AV1" - it is below channel 2; double check DVD player to make DVD is playing and voila!
Jun 22, 2008 | Philips Magnavox 27MS343S 27" TV
Philips magnavox won't turn off and stay in demontration mode
Hold both volume buttons at the same time for 6-10 seconds and that will reverse it. This has been proven to work!!!! YEAH
Mar 03, 2008 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox TS3260C 32" TV Logo
78 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
