Question about Husqvarna Designer I
Internal flopppy problem with Designer 1 embroidery machine
Just started having problems with my internal floppy drive in my viking designer 1 embroidery machine. It reads the disk sometime and other times I get a message, no disk, error, etc
It is out of warranty and I was wondering how much it would be to fix or to put an external floppy or usb port on the machine.
Thank you for any help. I appreciate it.
    Scholar:
  • 110 Answers
Dear bjdouce,
Push the floppy drive lid inwards and do the following:
First of all, check for any visible thread or dust inside the floppy drive.
Secondly clean the drive by blowing it with compressed air.
If this does not help, it is time to upgrade your machine to USB. Great to work with. Cost: plus minus $500.00.
Good Luck
Posted on Nov 17, 2008
EXTERNAL FLOPPY DRIVE FOR DESIGNER 1 ?? HOW TO
Sorry, an external floppy drive will not work for a Designer 1. You would have no where to plug the cable in to. The internal floppy drive is quite expensive. You might want to look around for a used Designer 1. You can probably find one for $400-$500. Replacing the floppy drive on yours would cost you almost $400 depending on the local dealer pricing.
Jun 27, 2014 | Husqvarna Designer I
Replace floppy drive with USB on a Designer 1
Check with a Viking dealer whether Viking offers a conversion kit. My guess is that rather than offer such a kit, Viking would rather sell replacement floppy drives or a newer model of machine.
Dec 21, 2012 | Husqvarna Designer I
Intermittent floppy disk drive for Husqvarna Viking Designer 1
Could need a new drive, could need a new cable, could need a new floppy disk.
Try the disks that came with the embroidery unit. If you put the same disk in 5 times will the machine respond the same way to it each time?
Oct 04, 2011 | Husqvarna Viking 1
These 3.5-inch floppy disk drives are never produced by the manufacturer of the device, but by one of a few floppy disk drive manufacturers (usually Sony) and as such, should your disk drive start to fail, you may be able to disassemble the case of the Viking Designer 1, remove the floppy drive, and insert another standard floppy salvaged from a tower-type PC, thus fixing the problem.
Since 3.5-in. floppy drives are becoming more and more scarce in modern computers (in favor of CD-RW drives) you may have a obsolete tower computer (remember Windows 98?) in your basement (or your friend's basement/yard sale/flea market/www.Craigslist.org/www.eBay.com) that could supply a useable FDD (floppy disk drive).
Oct 04, 2011 | Husqvarna Designer I
I the floppy discs that control my Designer 1 embroidery machine
You can have replacement discs ordered from Husqvarna Viking. Visit an authorized Husqvarna Viking dealer for them to order the replacement discs. However, you might luck out and they have some already on hand from a scrapped machine or a trade-in. You can find your nearest dealer by visiting the Husqvarna Viking website - http://www.husqvarnaviking.com and clicking on dealer link down the left side of the page.
Good luck.
Dec 29, 2009 | Husqvarna Designer I
Viking D1 error message file not found
You need to use either Organizer or Disk Manager to put designs on the floppy disk. Both of these are Husqvarna programs, not part of your computers operating system. If you copy shv file directly, the machine does not have all of the information that it needs to read the files. If the folder containing your original shv files that you purchased contains additional files, you just need to copy EVERY file within that folder to the floppy disk and it might work. Don't attempt to move individual files to the floppy. You will need them all.
Apr 10, 2009 | Husqvarna Designer I
Husqvarna designer 1 floppy drive to usb
First you need the USB upgrade kit that has the connectors and parts to change the cover of the machine.
Next, you will need a new main circuit board if your machine was made prior to about 2006.
At this point, the cost of parts is about $489. If you can get someone to install these for $10, you can get this done for under $500.
Otherwise, go to an authorized Husqvarna Viking dealer and check into trading your Designer 1 in for a Designer SE. You will then be able to plug in an external 3.5 floppy drive to read your old disks, a USB stick, or plug directly into your computer and read them from the hard drive (an upgraded Designer 1 can read ONLY from the stick). Used Designer SE's are very reasonably priced since the introduction of the Designer Diamond as the new top of the line and you may be able to get a full manufacturers warranty on the gently used machine.
Apr 07, 2009 | Husqvarna Designer I
Husqvarna Embroidery card reader/writer
Hi - I think you have a Viking Designer 1, which has a slot for a floppy disk on the side of the machine. If so, you need to purchase embroidery software that supports file type .sv1, and you will need to buy floppy disks.
You can buy embroidery software from Viking that will allow you to write design files onto floppy disks, but you can find other embroidery software packages that support the D1 which cost quite a bit less - make sure that file type .sv1 is supported before you buy.
Viking does sell designs that come on a D1 floppy disk. You can just pop the floppy into the machine, select you design, and go. You can find Viking designs online from time to time, but before you buy, ask if a floppy is included - the newer Viking design packages come with a DVD but might not include the floppy for the D1.
Hope this helps, Ginny
If you have a Viking #1+, you won't be able to use floppy disks with your machine. Please repost and I'll tell you what to look for.
Jan 30, 2009 | Sewing Machines
Probel with Embroidery disc
I am pretty sure you can download Disk 100 free from the Husqvarna Viking website. This has all the embroideries that came free with the machine, plus the alphabets (I think!). You can download this direct to your PC or to a set of floppies, depending on what your Designer needs and what support software you have (or have not) got. If you have no Husqvarna software at all, your PC will not be able to read the floppy. It is in .shv format which PCs are unable to read, being an embroidery machine language only.
If you are trying to open the faulty disk in your Disk Manager software, I always found it worked better if I didn't put the disk in the floppy drive of the computer until after I had already opened Disk Manager.
Hope some of the above is useful to you.
Jun 17, 2008 | Husqvarna Designer I
Sewing Machines Logo
469 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
