Question about Kenwood KAC-9152D Car Audio Amplifier
Won't turn on
Information: -2x Rockford Fosgate HX2's in 4ohm load wiring -Kenwood KAC-9152D Amp -4ga. Power/Ground -16ga. remote Problem: Alright, this amp WAS working for a good while on my old setup, which the only difference was a box. At some point, one of the wires on the sub's coils came loose (due to someone not putting it in the clip properly), and it started making a fuzzy noise, but still worked ok. Up until one day, my amp just wouldn't turn on. Eventually, the box just fell apart (shoddy construction, this was a second hand box), so I pulled the system out, pulled the power fuse from the wire, and just had the components floating around in my room. Eventually, I got a new box, rewired everything, and hooked it all back up into my car, only to finally remember that my amp will not turn on. I pulled out my trusty DVOM and my power probe. Full battery voltage in, ground is good, and the remote wire is also sending 12.6v in. So everything is in order. I checked the amp fuses again, JUST in case. All good there. I've opened up this amp before just to do a trace check when it first went. All the traces are good, no burns on the components. What in the world could be the issue?
  • 2 more comments
  • mikerocsuall Mar 16, 2008
    Got the same problem with my Kenwood KAC-8102D, the amplifier has gone into "protection function" its in the manual. I can not get my amp. out of this function and neither can this other guy, any help out there?
  • Clint Bruck May 01, 2008
    I actually ended up rebuilding this amp. It now works perfectly.
    I rebuild this amp. It now works fine. :D
  • Anonymous May 21, 2008
    on, wont put out sound.
    Genius:
  • Kenwood Master
  • 1,689 Answers
The output devices (IC's), and their respective drivers are damaged. It is very likley that some of their support components may also be damaged.
When there are intermittants and or shorts on the output of these amplifiers, they are very easily damaged.
The amp will require proper shop service done by an experienced tech.
Jerry G.
Posted on May 01, 2008
What is the p. con on the back of the kenwood 9105d?
Power control wire - tells the amp to turn on, usually connected to the blue/white or blue wire when blue/white is not present on aftermarket radios. On factory systems you usually want to hook up this connector to an acc source on the car
Jun 13, 2010 | Kenwood KAC-9152D Car Audio Amplifier
My kenwood kac-929 amp is melting my ground cable help
That amp needs 4 gauge power and ground wire minimum. Too small of wire is just like using too small of a water main to a house....it's just not gonna work out
Jun 05, 2010 | Kenwood KAC-9152D Car Audio Amplifier
I have a kenwood kac-9152d running a 10 inch rockford fosgate power t1 and the amp keeps going into protect but i have a smaller kenwood kac-8102d running on another t1 and i have no issues with it why...
either the wiring your running is short circuting,or the amp is shot, or the subwoofer is shot, try hooking the same speaker up to the other amp. along with the other speaker to the other amp, see if the same thing happens.
Feb 04, 2010 | Kenwood KAC-9152D Car Audio Amplifier
920 Watt Kenwood Amp wont power on
Connect the remote wire to an accessory wire on your stereo.
Jul 08, 2009 | Kenwood KAC-9152D Car Audio Amplifier
I have a kenwood kac-9152d amp i fried it opened it and the inner ground wire was fried in half now it just blows my fuses????
Dang! That's a class D anp! How did you fry it? If you "replaced" the internal ground wire and now it just blows fuses, I would say that the amp is direct shorted at the power supply if the fusesblow instantly when you put the fuses in.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Dec 26, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood kac 9152D
Usually, protection mode is caused by one of these conditions:
  • Shorted speaker outputs.
  • Speaker output shorted to ground.
  • There is an internal issue, causing DC voltage to be present on the speaker outputs.
  • Amp overheats.
  • Ground connection is insufficient for amp or HU.
I'm not sure of the history or symptoms of your amp, but those are the reasons why the amp could go into protection mode.
Mar 13, 2008 | Kenwood KAC-9152D Car Audio Amplifier
My kenwood amp
you need to check your wiring and check your rca wires to see if they are giving your amp a signal to put out
Mar 11, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Rockford P550.2 going into protect mode
Does it shut off for a couple of minutes or a couple of seconds? Is the amp hot when it shuts off? Are you sure you have the speakers wired to an acceptable ohm load for the amp? Have you measured the voltage at the amp (across the B+ and ground terminals) to make sure it's not dropping too low on hard bass notes?
Oct 08, 2007 | Kenwood KAC-9102D Car Audio Amplifier
Kenwood KAC-9152D Car Amp
use a multimeter to check for power on the +ve wire, could be your fuse, it only rus a sec when you jumper the remote to +ve because the remote cannot give out the nessary current to run the amp.
Sep 13, 2006 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood KAC-9152D Car Audio Amplifier Logo
102 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
