Question about Philips 55PW9383 55" Rear Projection Television
Color going the tv is lossing the color it is all one color and not a good one at that
  • panchoelpesc Dec 07, 2008
    the image is too brillant and i can't adjust,.i used the cable service but i don't now if i need the hd service or e regular service is good. thanks
  • Philips Master
  • 3,459 Answers
Your TV most likely has one of two possible problems.
Problem #1 - Failure in the convergence circuits. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
TV set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on May 22, 2009
Philips 20pf5120/28 Calibration for gaming using DVI Input
lololol HD to standard video - standard video back to HD is going to cause some issues. Go straight HD to HD with a hdmi to dvi instead. Even if your tv cant do HD theres a loss of information and signal for every adapter you put in and the length of the cord.
Dec 25, 2014 | Philips Televison & Video
No red on my toshiba 65hm167 tv
not good, check all inputs etc, the model is a Dlp set so if loss of one color etc a Bad Optical Light engine is likely.
Dec 23, 2012 | Toshiba 65HM167 65" Projection Television
The color red wont work on my tv
If Dish is providing signal via the COMPONENT input on the set look for a loose or bad red cable--hint in this case swap red cable to green or blue and if loss of color is now different--bad cable or output connection from the box.
Set (we are fond of saying this) does not know what is hooked so if one color missing and good with DVD etc it is a problem in the hookup.
I got paid triple to go to one house (nearly 80 miles each way) as set was under extended warranty for exactly this issue---red plug (component) coming out of the box was part way out.
Apr 18, 2012 | Televison & Video
Poor picture no color
OUCH! LARGE DARK SPOT IN CENTER IS NOT GOOD FOR PROJECTION TV. YOU BURNT THE TUBES. THE LOSS OF COLOR IS THE ROOT CAUSE SOUNDS LIKE A DEFLECTION CIRCUIT PROBLEM. THE TIMING FEEDBACK IS USED TO SYNC THE COLOR CIRCUIT. IF THE TUBES LIGHT WITHOUT DEFLECTION THEY BURN THE CENTER PHOSPHOR COATING INSIDE.
Dec 24, 2009 | Televison & Video
Screen keeps losing colour and ends up with a blue tint
On this model there tend to be two problems. One is that the power supply capacitors fail early and often. While this typically caused no power or slow power-on, it can cause other issues as well.
Loss of color typically means the 'Main Scaler board', which is the main board where all the inputs are attached, is having an issue.
There are some problems reported with a faulty crystal on the board causing loss of color, although most techs would just swap the board as these TVs are meant to be serviced at the board level, not the component level.
I assume that this loss of color happens on any input source, including when using the internal setup menu of the TV? This would help to confirm that the loss of color is not related to a faulty input signal caused by a bad cable.
Oct 16, 2009 | Philips 32PFL7332D 32 in. LCD HDTV
DVD player only plays in black and white on Soniq 42'' Plasma TV. (Have tried 3 different players all have the same problem)
The color loss is most likely due to a NTSC/PAL compatibility issue. If you bought the players overseas in a PAL region (http://upload.wikimedia.org/wikipedia/commons/0/0d/PAL-NTSC-SECAM.svg) and the TV is NTSC or vice-versa, there will be a color loss. Thiss because the different regions have different formats and when you go from one to the other, the color does no transfer over. You can buy a PAL to NTSC or NTSC to PAL converter to fix this issue.
Oct 06, 2009 | Televison & Video
TV COLOR WENT BROWN IN COLOR
It could not be the playstation that would cause the fault. The set was probably going to fail anyways.
A brown casted picture sounds like there is a loss of the blue colour drive in the set.
Some TV sets have colour temperature adjustments in the user menu. Check to see if your TV has that option, and that the colour temperature is properly set up. You can refer to the TV's instruction booklet for details.
A loss of blue drive can be from failed components in the video path, or in the bias circuits that control the CRT's cathold current.
It is also possible that the CRT is going defective, and is losing emission from the blue colour electron-gun.
You will have to bring the set to a service center that has an experienced TV tech who can make proper diagnostics, and give you an estimate for the cost of repair.
Jerry G.
Apr 29, 2008 | Philips 55PP9352 55" Projection Television
Loss of Color
Have two basic colors blue and yellow or green as the combination all other colors are grey. What are my options...The Boston Celtics Colors are Grey. All others colors are good.
Jan 24, 2008 | Maxent MX-26X3 Television
Tv proview hv207 problem
DON'T EVER BUY PRO VIEW!!!!! THEY SELL JUNK AND THEN CHARGE A TON TO FIX IT...................
I called customer support and they said it is the receiver. I can't find one and they want $190 to fix this 1 1/2 year old TV. Mine is not digital so I can't receive broadcast in a year so mine is going out in the trash.
No they want sell parts. You can cut your losses or give them them more money. Good luck.
Sep 29, 2007 | Proview HV-207 20 in. HD-Ready LCD...
RCA F31317 lost blue in picture.
this symptom is characterised by the loss of one or two primary colours. this symptom can be classified into three cases: 1) loss of red colour, 2) loss of colour blue,3) loss of green color. this symptom may be caused by a trouble in the colour demodulator, in the color amplifier or in the colour subtraction amplifier circuit. in your case loss of blue colour. this is a very complicated problem that you need some special test equipment like oscilloscope and color pattern generator in order to trace the signal. tune the receiver to a color broadcast station(a colour bar generator can be used to transmit a colour signal to the set). check the Z-axis demodulator, z-axis amplifier and the B-Y output circuit for the chroma signal. observe the signal process with an oscilloscope. if the color signal is not present use a VOM to locate the defective component in any of the above circuits. check the transistors and the resistors in the collector circuit. good luck!
Feb 14, 2007 | RCA F31317 31" TV
Philips 55PW9383 55" Rear Projection Television Logo
122 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
