Question about HP Office Equipment & Supplies
My photosmart printer says that there is an ink failure gives error #0xc18a0001. Have cleaned cartriges and still get the same error. What is the problem and how do I fix it?
  • 3 Answers
Yes, it is a known problem & if what I say next doesn't help then take it back for another one. --- The ink system has to pump up or be primed to work & yours just did not complete it on its own. Have you inserted all 6 inks ? They need to be in to have ink to prime the machine. Try holding down the ok -- cancel -- black -- color buttons with 4 fingers while at the same time powering the unit off. Keep them held down till it is off. Then turn it back on normally & it should try to do "Maintenance" & you hear a whirling noise --- that is the ink pump spinning to try & pump in ink to the print head.
Posted on Dec 05, 2010
MY HP PHOTOSMART D7100 IS HAVING A PROBLEM ERR 0XC18A0001 IS IT FIXABLE?
The error means
PrintHead Failure / Ink system Failure
Hardware error
Try removing the printhead (If removable) and clean the contacts on it, if it doesn't works there are no ways to fix this error
ADCSFXworks Printing Center <3
Nov 29, 2014 | HP PhotoSmart Office Equipment & Supplies
ERROR 0xc18a0001 Ink system has failed Quite new
Try the link below. This error is related to air in the lines between the print head and the cartridges. It is quite common and HP are very aware of this.
http://fix-your-printer.blogspot.com/2009/03/ink-system-failure-on-hp-photosmart.html
I hope this helps. Regards GM
Apr 16, 2011 | HP Photosmart D7360 All-In-One InkJet...
Ink system failure
This is a very common problem if you use refilled cartridges or let your ink run really low. The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com , click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 05, 2010 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart D7460 problem
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
/Putte
May 15, 2008 | HP Photosmart D7460 Printer
417 people viewed this question
Seeker5211
Seeker5211
