As per the previous troubleshooting forum, if there is no input available to select, how is that easy if everything is highlighted in red, except the language and one other option that allows you to select movies, news, sports and manual. By selecting manual, it allows you to change the tint, color, etc.
-   my sanyo ds31590 has blue screen and the word video in the corner. I don't have the original remote just a universal one when we pushed the menu button on the tv it would only let us choose language and one other options the others were all in red .-   Guest
Nov 24, 2007
-   I have a comcast cable provider and this tv wont respond to Chanel change. I only get reception on one chanel.-   Guest
Nov 24, 2007
-   still only get reception to one channal , I've tryed reprograming with no luck-   Guest
Nov 10, 2007
-   Controls on TV & remote not working. Stuck on DVD mode. Can't change source. DVD was stuck in TV, but was able to watch cable TV. After taking out DVD, the source remains on DVD and can't watch TV channels.-   PTBootsy
I do not know your original problem. If you are inputting video by the Scart connector the television will automatically read that input because the Scart has a priority, pin 8 I think, which will be at 12 volts when the video is not in standby. Unplug the scart lead and the TV should revert to Recieved channels. If this is cable connected, ie. not via an aerial, then I have not an answer, try the cable company.
have tried 2 coaxial cables but do not get a sharp picture. Could it be an internal cable pin TV...
(More)
have tried 2 coaxial cables but do not get a sharp picture. Could it be an internal cable pin TV issue? This happened many years ago with a TV I gave up only to find out the problem was with the end of the cable coming into the house & connected to the TV. This time that cable as well as the cable connecting the setup box to the TV worked fine on the TV that the Sanyo 27" replaced. I tried another cable ( that works fine on my 13" Sanyo) but get the same not sharp picture. Naturally, I have tried adjusting the picture.
Hello. I have a universal remote for my Sanyo DS27800 although I am running into a problem not...
(More)
Hello. I have a universal remote for my Sanyo DS27800 although I am running into a problem not having the original remote because on the menu screen on the tv, the button will not take me down to channel search which is what I need to do for cable. I have no cable box, just the cord plugging into the back. What can I do?
