Question about Cannon Canon i960 Photo Printer
Need help setting printer to print regular size
Need help with setting the correct paper size and font for printer to print correctly on paper. right now lettes are tono small and its not printing on th whole page like it should.
  • 2thmanfl Jan 25, 2009
    I have the same problem - have been printing normally and suddenly fits like 30% of page - use vista now, used to use xp - can't remember if it started with new computer change - - maybe a driver problem?
On your printer, there might be a button saying Enlarge/Reduce. Keep hitting it until you get 100%. Good Luck.
Posted on May 26, 2009
Can't get small envelopes to print correctly on hp laser jet pro MFP M127fw
Go to printer setting options and choose paper size and font size, according your size choose it. I share a more help full links.
Read More Help...
Scale document to fit on different paper sizes
Resize the page or paper
And HP Printer Support
Thanks,
Aug 27, 2014 | Office Equipment & Supplies
Error Number : 71 The selected paper size and the paper source are not compatible. Turn the Photo Paper Tray handle to the right, load paper of the correct size in the auto feeder or change the paper size...
This is probably a software settings issue, please check in the application that you use for printing if the default paper size is the correct one (A4 on Letter)
Also check in Control panel, under printers Properties, that the correct paper size is selected.
Try printing again.
Regards,
Katharsys
Mar 31, 2011 | Office Equipment & Supplies
Printer printing text very small
1. On the computer:
- go on Print Preview, if document looks normal go to step 2. If it's small in Preview, read on.
- make sure you are writing in a font of at least size 10
- make sure you don't have ticked "Shrink to fit", but adjust to 100%.
- size of the paper is printing preferences is set up to A4 or Letter, depending on your region
- there is a known issue with Outlook printing in small font, you need a hotfix for that
2. On the printer:
- You have to go into the menu of the printer and see if there is an option for the font, if there is increase the size of it
- In the menu, make sure the paper size is correct
- If none of these worked, you may want to reinstall the drivers of the printer
- If that does not work, you may have to put a new firmware on the printer. You can download drivers and firmware from manufacturer's website
Dec 13, 2010 | Lexmark Z33 InkJet Printer
The printer changed to small print
Make sure paper size you set is correct...For example if you take the print on A4 size paper and page size you set is "Letter" the the font will be small.
May 07, 2010 | Brother HL-2040 Laser Printer
A3 prints - printing on A4 - Ricoh C4500. When users print to our Ricoh C4500 using RPCS the print comes out as a cut off A4 print, so it does not seem to be detecting the fact that it is needing to use...
Enter on the computer the follow path:
1. enter start menu
2. enter printers and faxes
3. enter by right click into properties
4. enter paper size settings
5. set the paper size for the tray or trays and press update then apply and ok
after thet it will work
Also see on the printer menu enter the same paper tray settings and set the trays by size but more important is to set the compute settings
Jul 08, 2009 | Ricoh Aficio SP C410DN Laser Printer
Printer will not print, keeps rejecting paper saying it is too narrow. the paper is the correct size. i nee help immediately please
OK there is three places you have to check for correct papersize,-
1)In the settings on the machine
2)On the driver of the printer ,ON your computer -Start,Control panel,Printers and faxes,Right click on driver- Properties,Then you enter the correct paper size.
3)In the page setup in the program you are printing from.File, page setup,set the correct paper size.
Normaly the settings for 1and 2 you enter once and it stays there ,except if some one change it.
Every program have it's own paper size defauld settings.Check them before you print.
Let me Know
Nov 06, 2008 | HP Office Equipment & Supplies
HP 1220C Printer
BE SURE THAT YOU ARE USING THE CORRECT SIZE OF PAPER AS THE DOCUMENT YOU ARE TRYING TO PRINT,ALSO CHECK THAT THE PAPER SIZES ARE SET CORRECTLY ON THE PRINTER DRIVER
Oct 21, 2008 | HP StorageWorks E1200 (271666001)
Printing settings
Hi,I have a doubt, whether the perview is good and only the print out is bad or both are bad.
Anyway i am giving solutions for both.
The Statement or Report Looks Fine When Previewed, but Looks Bad When Printed If the appearance of the statement or report when printed differs from its appearance when previewed, this may indicate a problem with the printer driver (such as corruption of the driver files). Make sure you are using the most current version of the correct printer driver for the operating system on your computer. For example, a printer driver for an OkiData MicroLine 390 for Windows 98 may not work well at all when printing from Windows XP.
  1. If you need to check for a different printer driver, begin by checking the installation disk or CD-ROM that was provided with your printer.
  2. If you can't find the driver you need on the installation media provided by your printer's manufacturer, check the CD-ROM from which your operating system was installed (i.e., your Windows CD-ROM).
  3. If you can't find the driver you need on your Windows CD-ROM, or if you need to try an updated version of the driver you are currently using, check your printer manufacturer's Web site.my.okidata.com/pp-ML521.nsf/openingdrivermenu?OpenFrameSet
The Statement or Report Looks Bad Whether Previewed or Printed There are many factors that can contribute to undesirable printed output, such as margins, fonts, and custom paper sizes. Use the following steps to troubleshoot this problem.
  • Try using a different font size. See if there is a separate font size available for the same font family (e.g., 15 cpi vs.10 cpi).
  • Try adjusting the page margins and printer offset adjustments in the Page Setup window.
  • Check the printer driver properties to determine if a custom paper size is specified. If not, you may need to specify one. For example, when printing checks that have only one stub, you may need to set up a custom paper size of 8.5 inches wide by 7 inches tall. Conversely, if a custom paper size is incorrectly selected, printed output of reports and statements may be adversely affected.
  • In the Advanced Printing Features window, select the Optimize for Print to File check box and clear all other options and check boxes.
  • Try temporarily renaming the STI.INI file and restarting the Tabs3 or PracticeMaster program. The STI.INI file holds all of the printer settings. If this helps, you may have to recreate the margins, font selections, and other settings used for printing since that information is stored in the STI.INI file. If this does not help, delete the new STI.INI file and rename the original file back to STI.INI.
  • Is the printer configured to emulate another type of printer? Consult the printer's manual and/or the printer manufacturer's Web site to determine if the printer is able to emulate another type of printer such as an IBM Proprinter. If you have tried all of the internal fonts available in the printer's current configuration, it may be beneficial to configure the printer to emulate a different type of printer and then install the corresponding printer driver. Then you can test each of the internal fonts available in the new driver.
  • Once your printing issue has been resolved, check the printed output to ensure that lines are not wrapping or breaking when they should not. Make sure the margins all appear correct.
  • When you are satisfied that the printed output is completely correct, be sure to look at a preview of the same print job, to ensure that the preview is legible. For some printer drivers and fonts, it may be necessary to make a second installation of the printer that uses TrueType fonts. This second installation would then be selected whenever you need to preview reports or statements, and the original installation would be used for the actual printing.
Hope my info solves your problem,
Thanx for using fixya.
Oct 01, 2008 | OKI MICROLINE 521 Matrix Printer
Need to enlarge printer font too small to read
Dear Sir/Madam,
At the left side of ur printer there is adjustment for the font settings or u go the printer settings (Go the Control panel ->Printer and faxes -> right click of properties -> select printing preferences -> adjust paper and font size
Thanks
Good luck
"Don't forget to rate the solution"
Jun 09, 2008 | Office Equipment & Supplies
Problem getting the printer to print with the correct alignment
is the printer connected to the your PC ?? ARE YOU PRINTING THIS SIZE directly from the PRINTER ?? AS soon as i get an answer from you , Ill tell you what to do next , thanks AJ
Apr 22, 2008 | HP PSC 1210 All-In-One InkJet Printer
Cannon Canon i960 Photo Printer Logo
105 people viewed this question
Top Cannon Office Equipment & Supplies Experts
Greg Cann
Greg Cann
Iqbal Husain
Iqbal Husain
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
