Question about GE WSXH208A Front Load Washer
BIG LEAK!!!!!! The rubber gasket around the front of my washing machine has completely came off. It also has an metal elastic-like band that came off with it. Is there any way to repair this myself. Being a front loader, without this rubber, water goes EVERYWHERE!
Were you able to replace the rubber gadket yourself? richfield
Posted on May 17, 2007
If you haven't torn or otherwise damaged the gasket or metal band, you can put it back on. It's a bit of a workout, as the metal band is pretty tight, but that's what they do at the factory. I think you might be able to do it more easily with the front removed.
Posted on Feb 01, 2007
Whirlpool Front load washer - the grey round rubber came out. I put it back on and now all th water leaked out of the machine all over the floor
I don't know what model you have, but mine has a big spring that goes all the way around the rubber gasket. If that is not in place it will leak. I wonder if the spring in yours is under the gasket and didn't get put back on properly.
Dec 14, 2016 | Whirlpool Washing Machines
Front seal came off
Sometimes when the load get tangled during the cycle and you try to pull all the load out in one go, you can dislodge the seal and retaining spring. Remove the wire around the door seal, repositioned the seal around the edge of front panel porthole. There is a folded metal edge around the metal frame and the grey rubber gasket lips over this, once in position, offer up the metal retaining band and use a pair of long nosed pliers to stretch the spring so you can get it to sit around the seal. Sorry this a little long winded but very difficult to articulate properly, so I hope you get the gist. Cheers
Mar 26, 2013 | Bosch Washing Machines
I have water draining from the bottom of my front loader washing machine. It doesn't happenned every time. I have had the local repair man out cannot find the problem. I know its the machine because...
ok ,,take your time and get a flash light,,check the rubber gasket around front of tub for pen hole...giood luck,,if you dont find leak repost..and we will got to another step..pull on rubber tub gasket while searching..
Sep 09, 2011 | Maytag MAH8700A Front Load Washer
Our Fisher and Paykel clothes washing machine, model # WL26CW2 has a clear colored elastic band that attaches from the top frame of the washer to the tub that came detached. I see there are several spaced...
this usually happens when the load is one sided for a short time if the rubber has not split then you need to take a 5mm steel bar with one end turned at 1 inch to 90 % so you can push or pull it back to the hook or angled piece of bracket eric
Dec 22, 2017 | Fisher and Paykel WL26CW2 Top Load Washer
The rubber gasket around the drum opening is leaking and rusting
You can replace it by lifting the lip of the rubber around the edge and finding the wire where the springs connect there you can stretch the springs apart, remove the wire and pull off the rubber. Just make sure first that is where the leak is, sometimes a leak in the soap dispenser water tube can seem like door gasket leak.
May 16, 2011 | LG WM2277H Front Load Washer
The loading door gasket-- the big rubber liner doesn't drain
Some front loaders have a door boot drain hole, most do not and it is normal for some water to accumulate at bottom of boot. To help with mold and mildew use a washing machine cleaning solution, follow directions. Also a bleach solution of 2 parts water 1 part bleach sprayed on area helps. If mildew is really bad, nothing will completly remove it. Make sure you use only a high efficiency detergent.
Feb 03, 2010 | Washing Machines
Rubber ring ripped
You can buy and fit a new door gasket if you have the required mechanical knowledge
Take the power off , the top off remove the fitting band take off the old gasket and re-assemble in the reverse order
Jan 03, 2010 | GE WSXH208A Front Load Washer
My Whirlpool Duet front loader is ripping my clothing. It looks like it is being pulled, the area they are ripped looks like they are being pulled! I checked inside the machine to see if there was anything...
My washer ruined 2 king sheets 3 shirts and brand new jogging suit, so I know what you mean! The rubber gasket ...it had 2 metal bands..one on the inside which is a wide one and a small thin one on the outside of the gasket. You really can't see the wide one unless it has started to slipped off or break. or by taking the ting one off,..my wide band came loose which caused the screw to be exposed just enough for something to catch on it, tearing the material, it kept wrapping around and around untili eventually the band came completely off. I hope this helps.
Linda
May 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How to replace the rubber gasket around door and drum
open the door around the front of the door seal you will see a lip under the lip you will see a metal band will a spring. get a screw driver and push in on the spring and pop it out. this will remove the front of the seal next is the same thing exept the band looks a little different locate the part that you can unscrew sometimes they have a socket head and sometimes it will have a phillips screw. when you are putting it back on it may be time consuming and you may start to cuss a little. you have to make sure the rubber goes on the right way so that the band seals and doesn';t fall off or you will have a leaking issue. also when taking the seal off you have to take the part that the water comes in off. just peal the rubber away from that plastic shoot. let me know if you have any more questions
Apr 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water Leaking from pre-wash and main wash cold water solenoid
We had the small leak problem. It was a cut in the bellows at the door. Lower side. We could see it if we just spread the gasket just inside the door.
Jul 14, 2008 | LG WM-2277HW Front Load Washer
GE WSXH208A Front Load Washer Logo
107 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
