Question about Inverter Pure Sine Wave 1500w Inverter
2400 watt inverter in alarm
Inverter got backfed through the bypass relay for a split sec but now fried something inside inverter
  • tintedout21 Nov 15, 2008
    is it fixable or preventable
  • 118 Answers
Are you using the correct by-pass relay. These are specially made to be a break-before-make just to prevent what your describing.
Posted on Nov 29, 2008
It is most likely the low voltage alarm. Suggest connecting when the car is running with no load (110 volts not connected). If the alarm continues turn the unit off and on to reset.
Hope this helps?
Inverter Protection Features
• Short Circuit Protection. The inverter will automatically shut down until short is removed.
• Low Voltage Alarm. An alarm will sound when the voltage from the battery discharges to 10.5 +/- 0.5 volts DC. This is an indication that the battery needs to be recharged.
• Over Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input exceeds 16.5 +/- 1 volt DC.
• Under Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input is less than 10.0 +/- 0.5 volts DC.
• Overload Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the continuous draw of the equipment being operated exceeds 1200 watts or the surge draw of the equipment exceeds 2400 watts.
• Thermal Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the circuit temperature exceeds 150° F
Sep 13, 2016 | Electronics - Others
How many 12v batteries are needed to run a 15000w inverter properly
It is normal to use only half of the capacity of a battery and this is called 50% depth of discharge (DOD) so the watts of a battery is volt X amp hours eg a 12 volt bat @ 200 AH would be 2400 watts but you can only use half of that other wise the battery will be stuffed, so all you have is 1200 watts, if you have a 400 AH battery you would have 2400 watts, you also have to know the capacity of the battery and this is call the C rating of the battery once you have that you can work out how many hours it will run for.
On an of grid system I would not use any less than 6oo to 700 AH @ C100
It is normal to size the batters to energy demand in KWHrs per day of (AC load )
Hope this help.
Feb 07, 2016 | Inverter Electronics - Others
I bounced the "H" out of my generator. When i plug something in it goes straight into overload and quits.
You may have knocked something loose inside. Take off the generator end cover and look for anything obvious. There is nothing to loose at this point.
Jul 22, 2014 | Yamaha 2400is Portable Generator 2400 Watt...
Crafsman 2400 watt generator star ok but only run for 45 sec.& it won't star again the motor is a briggs & stratton 5.0hp
I have a Craftsman Snow Blower with a Briggs & Stratton Engine. I had the same problem. I searched online and read a little bit about this run and stop problem. One solution was to put something over a piece of metal that separates the hot engine part from the other part of the other side of the engine. I used a piece of heat resistant cloth from Lowes in the plumping area where the torches are. It fit and worked. Engine keeps running. I ran it for over an hour last spring prior to storing it.
Nov 01, 2012 | Electrical Supplies
I have a duracell 800 watt invertor which i hooked up backwards to the 12 volt battery. sparks flew and it will not work? help
Any particular reason for hooking it up backwards? most likely something inside is fried and you will prob have to purchase a new unit.
Good luck
May 04, 2011 | Duracell 1500W Power Inverter (D1500)...
My Motor Trend Inverter 400 watt give's me a fault light upon start up. The fuse is good
Sadly replacement is the best option. It is just not cost effective to get the inverter repaired.
The cost starts out about 150.00.
Best option is to take it back to where you purchased it and hope you can get a new one.
Hope this tip helps.
Am a seven each power inverters owner.
Recommendations: Purchase a Pure sine inverter 1500 watt. We have had one of these running 24 seven for almost a year now.
Feb 15, 2010 | TREND Motor Trend Inverter 2400 Watt ...
Power drop
Hey, Question: Is the 2400 watt the peak rating or the continuous rating of the unit, and what is your power source for the inverter. If 2400 is the peak, the 1200 is probably the continuous. Your 75 watt fridge will draw probably 150-170 watts to start up, which will load the inverter to draw 15-17 amps of load on your 12 volt power source. If the battery supply is weak, the current draw at startup will cause the voltage to drop and set off the alarm. Getting the start up out of order may work for a while, but will eventually blow the internal fuses on the inverter, or possibly blow out the capacitors. Check the condition of the battery supply, and make sure the bar fridge is in good working order to resolve this problem.
Jul 18, 2009 | RoadPro RPPI-2500W Inverter
2000 watt cobra inverter keeps saing olp, overload
2000w means is out off rang load 2000w plus then alarm beep have running.
Mar 24, 2009 | Cobra CPI 1000 DC to AC Power Inverter
Motor trend 2400 watt inverter has 147 VAC from both hot and Neut
Assuming you are testing alternating current and not direct current that sounds quite normal. Plug with confidence. You are using equipment designed for 110v-120v and you're getting 113.8v where it matters most. Higher voltage to ground is nothing unusual, that's just how this inverter is designed.
Jan 10, 2009 | TREND Motor Trend Inverter 2400 Watt ...
Inverter Pure Sine Wave 1500w Inverter Logo
188 people viewed this question
Top Inverter Electronics - Others Experts
ray gallant
Tom Chichester
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
