Question about Whirlpool GEW9250 Electric Dryer
Lights on but no one's home.
A soccer pad somehow got stuck between the wall and drum. Now the lights light up and control system appears to be working but drum will not start spinning. I do not hear a motor turning so I do not think there is a drive system problem but possibly the motor????
Is there a fuse that protects the motor in such cases or a thermal overload sensor?
I have tested the wall socket and have 210VAC.
Thank you.
  • eudroma Nov 15, 2008
    Nevermind, I let the system sit unplugger for 15 mins. and now runs fine. There must be a Thermal circuit that needed to reset.
Let system sit for 15-30 mins. system cooled down and reset.
Posted on Nov 17, 2008
Why is brake warning light is on
It can be issue with master cylinder or the problem is there is still some air there in the system,that has to be bleed.Or else the parts replaced are not aligned properly/.I suggest everything back.
There are few help links mentioned below to troubleshoot the issue.
Click the link below and follow its procedure:-----
2002 Ford Windstar: Brake Warning Light ON dash?
http://schematicsdiagram.blogspot.in/2012/06/2002-ford-windstar-brake-warning-light.html
Battery and brake Warning lights on Dash
http://alltypesofpartsreplacing.blogspot.com/2012/10/battery-and-brake-warning-lights-on-dash.html
ABS & Brake warning lights remains steady on dash? http://schematicsdiagram.blogspot.com/2011/12/abs-brake-warning-lights-remains-steady.html
Brake warning light comes on and car will not start intermittently? http://repairhelpcenter.blogspot.com/2011/12/brake-warning-light-comes-on-and-car.html
------------ When the car stops, abs pump turns ON? http://howtobyme.blogspot.com/2011/12/when-car-stopsabs-pump-turns-on.html
----------- Where is Power Brake Booster located on 1995 Lincoln Town Car? http://howtobyme.blogspot.com/2011/12/where-is-power-brake-booster-located-on.html
----------- Sometimes ABS light comes on while Driving?
http://howtobyme.blogspot.com/2011/12/sometimes-abs-light-comes-on-while.html
All types of brake problems and repairs http://howtobyme.blogspot.com/2011/11/abs-and-service-light-comes-on.html
Brake Fade Issue? http://whoisbyme.blogspot.in/2012/07/brake-fade-issue.html
Brake System Troubleshooting? http://technoanswers.blogspot.com/2011/11/brake-system-troubleshooting.html
Car Brake lines have no pressure? http://schematicsdiagram.blogspot.com/2011/12/car-brake-lines-have-no-pressure.html
Car Brakes Dragging? http://repairhelpcenter.blogspot.com/2011/12/car-brakes-dragging.html
Car Brakes grabbing? http://repairhelpcenter.blogspot.com/2011/12/car-brakes-grabbing.html
Car Brakes Making Noise? http://repairhelpcenter.blogspot.com/2011/12/car-brakes-making-noise.html
Car Brakes Pulling? http://repairhelpcenter.blogspot.com/2011/12/car-brakes-pulling.html
Pulsating Brake Pedal? http://repairhelpcenter.blogspot.com/2011/12/pulsating-brake-pedal.html
Spongy brake pedal? http://repairhelpcenter.blogspot.com/2011/12/spongy-brake-pedal.html
Hard Brake Pedal? http://repairhelpcenter.blogspot.com/2011/12/hard-brake-pedal.html
Fading Sinking Brake pedal?
http://whoisbyme.blogspot.in/2012/06/fading-sinking-brake-pedal.html
Feels Like Brake pedal Pulsating http://repairhelpcenter.blogspot.in/2012/06/feels-like-brake-pedal-pulsating.html
What is Brake Drum Bar? http://repairhelpcenter.blogspot.in/2012/02/what-is-brake-drum-bar.html
ABS light stays on but brakes work fine?
http://howtobyme.blogspot.com/2011/11/abs-light-stays-on-but-brakes-work-fine.html
Vibrations while braking On Chevrolet Van? http://technoanswers.blogspot.in/2012/04/vibrations-while-braking-on-chevrolet.html
Dragging brakes? http://howtobyme.blogspot.in/2012/03/dragging-brakes.html
Brake pedal stuck? http://howtobyme.blogspot.in/2012/03/brake-pedal-stuck.html
After replacing brake rotors and pads, brake pedal remains on floor? http://technoanswers.blogspot.in/2012/02/after-replacing-brake-rotors-and-pads.html
How to replace Brake Power Booster? http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-brake-power-booster.html
1997 Chevy Tahoe Brake lights not working? http://technoanswers.blogspot.in/2012/02/1997-chevy-tahoe-brake-lights-not.html
How to service Drum brakes? http://repairhelpcenter.blogspot.in/2012/02/how-to-service-drum-brakes.html
What type of problems usually noticed on Drum brakes? http://repairhelpcenter.blogspot.in/2012/02/what-type-of-problems-usually-noticed.html
How to test Drum Brakes? http://repairhelpcenter.blogspot.in/2012/02/how-to-test-drum-brakes.html
Brake Bleeder Screw Function? http://repairhelpcenter.blogspot.in/2012/02/brake-bleeder-screw-function.html
Toyota Tundra: Parts diagram to replace Brake Drums?
http://technoanswers.blogspot.in/2012/06/toyota-tundra-parts-diagram-to-replace.html
---------- Squeak and grinding sound is heard when brakes are applied?
http://technoanswers.blogspot.in/2012/02/squeak-and-grinding-sound-is-heard-when.html
Brake Pads Inspection on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/brake-pads-inspection-on-acura-integra.html
How to remove Brake Pads on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-brake-pads-on-acura.html
How to remove Brake Disc Rotor on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-brake-disc-rotor-on-acura.html
Brake Caliper OVERHAUL on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/brake-caliper-overhaul-on-acura-integra.html
How to remove Brake Caliper on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-brake-caliper-on-acura.html
How to remove Parking Brake shoes on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-parking-brake-shoes-on.html
How to remove Parking Brake Cable on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-parking-brake-cable-on.html
Brake pedal is pulsating and vibrating? http://repairhelpcenter.blogspot.com/2012/01/brake-pedal-is-pulsating-and-vibrating.html
These details will help.
Nov 23, 2012 | 2004 Ford Expedition
No power light at controller no lights at key pads
What is the solution?
I'm having the same issue.
Nuvo has been installed about 3 months.
Nov 11, 2012 | Nuvo Simplese D 4-Source 4-Zone Audio...
2006 Cobalt. ABS and TC dummy lights appear once in a while. Seems like it happens more when temperatures are hot outside. Doesnt come on when its cool during my morning commute
There are no dummy lights on a vehicle
Any light you get on your dash is a warning to
direct you to at least check for codes in a day
or so, & decide if continuing to drive it is a good
idea
Almost every time your get any light you have a
failure in some system & the lights are not going
away until the car is repaired
The ABS & Traction Control System is explained in your
owners manual & any repair shop can diagnose those issues
The system should no be temp sensitive unless the electronic
abs module was somehow the problem
Oct 11, 2012 | Cars & Trucks
My svt's rear brakes never fully releases? You can
Try removing the drums and checking the mechanism. It could be that dust from the brakelinings is preventing free operation of the brake pads.
Clean out the drums and if the brake pads appear to be stuck a light thump with a hide mallet should release the sticking.
Apr 27, 2012 | 1998 Ford Contour
How to connect 2 lights from wall unit to wall plug
the electrical department in Home Depot or Lowe;s have double , triple adapters for outlets. BUT You need an Electrican to rewire wall switch for a switch control of an outlet....just like in a living room when you enter from outside.. it turn your lamps on.
Dec 04, 2011 | Pioneer Audio Players & Recorders
Light and lock buttons nonfunctional
There are certain models that had only a door bell type wall control and didn't have the lock and light functions. You may have one of these and someone has replaced the wall control with the three button model. If it did work in the past and has quit it is most certainly the logic board and is expensive to replace.
You say it is STILL stuck in the "lock" mode. If you cannot use your remotes you need to program it. Find the smart/learn button just to the left of all those white wires. Press and hold the button on a remote while you press and immediately release the smart/learn button. Do this for each remote.
Aug 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
HTS3164 doesn't react to any controls
found the service manual here :www.2instructions.com
Jun 29, 2009 | Philips HTS3450 System
2002 Dodge Van towing a Rock Climbing Wall. No
I would think that the wires from the RCW (rock climbing wall) that control the running lights are wired to the interior dash lights of the van, and a fuse blew, killing the above mentioned lights. Check the fuse block for a bad fuse, probably labeled inst lights or inst lgt. Did you make the trip there in daylight, and trip home at night? The fuse for the dash lights couldn't handle the extra drain of the RCW running lights.
Mar 25, 2009 | 2003 Ford F250 Super Duty Crew Cab
Abs lights came on after replacing pads
try bleeding the system including the master cly,if that doesnt work then discnnect the battery for 5 min too reset the computer
Mar 04, 2009 | 2002 Honda Accord
Sunbeam Heating pad will not reset
I have a Sunbeam heating pad with the SW204 controller that the High light blinks when it is plugged in. I called Sunbeam and the first thing they said is it cannot be plugged into a surge protector. Next, to reset it unplug it from the wall, then unplug the controller from the heating pad. Wait 30 seconds, then plug the controller back into the heating pad and then into the wall. It did the trick. However, when I move it to the bedroom plug it does the same blinking. Sunbeam is sending me a replacement heating pad. They appear to be very good with Customer Service since it is more than a year old.
Mar 21, 2008 | Heating & Cooling
Whirlpool GEW9250 Electric Dryer Logo
47 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
