Question about Garden
Alto Force Kew washer stopped working.
I have an Alto Force Kew washer that has simply stopped working.
It is about 3 years old and was working fine, befrore it stopped.
I have tried changing the fuse, leaving it to reset and etc but to no avail.
Can you help me?
Thanks
Brian Smith
  • 1 more comment
  • theatreking Dec 05, 2008
    I have the same problem fine one day not working the next.
    Where about is the fuse I cant get the blue cover off to even find it.
    Thanks,
    Brett
  • expertgas Mar 29, 2009
    The pressure switch contains two springs and I initially found that one had rusted (the inner) so I found a replacement that suprisingly cured the fault..... two days more use and it failed again. This time it was the SECOND spring that had broken in two. Maybe I'll be able to find one but I think that the tension is more crutial on the main spring, so not too confident. (They are torx screws holding the case and brackets together, by the way) It seems that spares for these units are either unavailable or extremely hard to source. Built-in obsolescence they call it don't they???
  • ANN BENJAMIN Apr 25, 2009
    Ours was working fine about half hour ago. Had a cup of tea and now it will not start. Can anyone help please
  • 555 Answers
To remove the cover, undo the two screws holding on the equipment tray on the handle. Then turn upside down and undo the two screws on the bottom. You will need a very long handled screw driver to reach into the deep recesses. I think they may to TORX screws (working from memory and has been a while since I pulled one apart). The blue cover will now pull off. The only trouble you may have is that the bolts are ordinary black steel ones and may have rusted through
Most likely fault is that the pressure switch has failed open. A combination of dirty water leaking past the seals and rust will eventuall jam the switch. The switch assembly is the white plastic part directly bolted onto the pump. A plunger is pushed by the pump when it is up to pressure which trips a micro switch and turns the power off. You will need to replace the complete pressure switch which is about $60. If you take care the micro switch assembly can be removed and then put back onto the new switch. If you break it, then another $40.
Posted on Jan 12, 2009
I pulled mine apart before I read this (it would have saved a heap of trouble if I had read this frst, as it took ages to find the two screws underneath, which are torx). Like others I found that the pressure switch was jammed up with rust. I cleaned it up and got it moving, but managed to break off the two tiny lugs at the top of the switch, so it will now cut out, but not cut back in. Trying to source spare parts in Australia, but only found one company here (have sent an email to see if they have any) and one in England, who seem to have them. Check out http://www.chamjet.com/product_image.asp?P_ID=216 for a picture of the problem part (marked part 14 in the diagram)
Posted on May 31, 2009
Part number 14 can be purchased from Diane from GreyMac in Australia as she has stock, Part number 13 is on order as well 'greymacptyltd@bigpond.com'
Posted on Jun 03, 2009
  • dave gillie
    dave gillie Aug 09, 2014
    If you live in the UK the part can be found here.http://www.sparesgiant.com/cleaning-equi...
Kew 1640H with display flashing A 2 fault code
Hi really hope someone can help as I couldn't find a manual for my kew alto 1640hot and cold diesel pressure washer, problem is when I turn it on from been stood over night !i press on button and I see a f then a 1 flashing on the display ,anyone know what it means or we're the fault is,
Sep 18, 2011 | Garden
Where can I obtain a manual for the alto L-12 mixer
You can download the manual using this link:
http://www.directproaudio.com/images/products/alto-l12-manual.pdf
Please rate my answer if this helps.
Many thanks,
Chris
Mar 03, 2011 | Alto L-12 12 Channel Passive Compact Mixer
Hi I have an Alto Force and it it has simply stopped operating. Fused changed etc but still no luck.
Try the machine without the high pressure hose on. if that fails you will need to check that you have power to the switch on the machine.
May 21, 2010 | Garden
My Hobby88 pressure washer stopped working, now I
Could be just a faulty capacitor that helps the motor to start. You will find this next to the motor if you remove the top cover.
Mar 28, 2010 | Garden
Kew Alto Force X-TRA cold water supply pressure sensor problem
Have the same p-washer (5-6 years old) and the same problem. Opened it and the pressure switch is the crook. A plastic pin has an inner and an outer spring on it (two consentric springs). The smaller inner spring is completely rusted away so the switch no longer operates correctly. Obviously the spring was of a too low quality. The service office say a new switch cost around 400NOK (50 euros) - so the washer is too expensive to mend. But I will try to get it working without the inner spring. Doubt if I succed. So will have to dump the washer.
Mar 19, 2010 | Garden
Water pouring out of the pump on my kew powerwash
Hi, You can get this seal set for a 1502v from nilfisk alto or any alto dealer.
Dec 27, 2009 | Garden
Kew hobby 80-1 instructions
I have a kew hobby 70 with little use. The nozzle wont spray, it just sends a weak jet of water. how can i fix it? I have hardly used it. It has been
in a shed for years . thanks
Sep 29, 2009 | Garden
Alto Kew pressure washer stopped working!
Hi Steve, In 3 years of repairing pressure washers I've only ever seen one of these, and am having a hard time remembering much about it, except that it was really awkward to work on! Strictly speaking, many small pressure washer repairs are uneconomical, because the labour time involved costs almost as much as the machine is worth. However, a "motor won't go" problem does narrow things down a lot. To state the obvious, we're looking at an electrical problem. The challenge is to find the cause! Did the motor stop while you were using it, or did it fail to start when you got it out of storage? If you are in the UK you should first check the plug-top fuse and the full length of the flex for any damage. If you have any kind of low-voltage electrical testing device, you can test for continuity between the live and neutral pins of the plug (with the machine switched on you should have continuity). If you have no continuity (and the fuse is OK) there may be a problem with the switch on the machine. Unfortunately, unless you are a really keen DIY person, there's not much you can do by way of self-help. A repair centre may be able to help you, but beware of costs spiraling beyond the cost of a replacement machine. I hope this will be helpful - if you can give more details I'll help further if I can. Good luck!
Aug 14, 2009 | Garden
ALTO FORCE KEW COLD WATER POWER PRESSURE MACHINE STOPPED
Hi FRANK,
The answer of "Firehead" is correct. You have a start/stop valve with springs (springs = maybe broken by the rust). Kew sells a kit to repair. If you want i'll send a diagram to you.
JJ (Brussels)
Jul 04, 2009 | Garden
Garden Logo
6,478 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
