Question about Dell Inspiron 1200 Notebook
Dell 1200 Inspiron OS boot problem
When I boot the laptop, everything seems to run. I get the Windows XP prompt on the screen, then screen goes black as normal before Windows loads. I can hear the start sounds when it usually comes up but a black screen.
I've check the video screen bios, it passes.
I've run diagnostics, it seems to pass.
Can you help me?
Thanks ahead of time.
  • beckiroyce Apr 12, 2009
    my Dell 1200 Inspiron is running fine it would seem however it is black. it is difficult to do anything to fix it as you can't see what you are doing. I am trying to work on it using remote access. I have tried drivers and all of that and I have tried the F8 fix but when you get in there, there is no VGA setting......
    makes you want to just scream!
  • 4 Answers
Two things you should try to resolve this issue: -
  • Check that the FN button on the keyboard to switch from the Laptop monitor to external monitor has not been enabled - these are usually 3 state switches (Laptop screen ON, External screen ON, Both ON) it is really easy to accidentally hit this without realizing.
  • If this works there is no need to try the second option.
OR
  • Try booting to safe mode - as the laptop boots up and you see the Bios summary screen depress the F8 button and you should receive a screen containing several options.
  • Select the option to Boot to safe mode.
  • If the laptop boots up ok then login to XP, don't be alarmed at the change in screen resolution.
  • Right-click My Computer on the desktop and select Properties - Hardware - Device manager
  • In the tree-view containing the different hardware select Display Adapters you should see your graphics card in there
  • Right-click and select Scan for Hardware Changes if it is ok the close and reboot as normal
  • If there is a problem here it implies the driver is somehow corrupted and may need re-installing from the disk that came with the laptop.
Posted on Nov 15, 2008
    Problem Solver:
  • 6 Answers
When you first turn on the laptop, hit F8. Choose VGA mode. When it boots up, you should be able to see the screen. Right click on the desktop, choose settings, change the resolution to something you think it should be and then reboot. It should load up. My guess is that the resolution is too high. One other option, is that you may have the picture set to a secondary display. Choose Fn and whatever F key your keyboard uses to switch screens between the keyboard an monitor.If this is the cause, you should be able to hit the right key combination and get the picture back.
    Genius:
  • 1,913 Answers
Try to run in safe modewhen u power up the syustem press F8 key then enter in safe mode.
or enable vga mode
Cannot get into safe mode dell inspiron 5720
Try booting from your OS (operating system software) CD,i.e. Windows XP, Vista or 7. If that works then you will need to to reload OS.
Mar 15, 2013 | Dell Inspiron 1501 Notebook
My Dell inspiron 6000 laptop stopped working. It shut off while I was online and when I try to restart it goes to the very first screen (black, says dell in blue letters) then the whole screen goes blank...
If the Dell Diagnostics passes then the issue is in the software part of the computer.. You may have to reinstall the OS inorder to address this issue.. Dell has a default partition on the computer and you can install with the same..
If you have windows vista on the computer then tap F8 when the computer turns on and then you will be able to see the advanced boot options.. Select repair my computer.. In the repair my computer screen select the dell factory image restore...
Your computer will go through the installation and it will be up and running...
If you have windows Xp then you have to turn on the computer and when the dell logo appears you have to simultaneously press control and the F11key.. You will be able to reinstall the OS in this way..
If this option is not available then reinstall using the disc The issue will be fixed
Nov 23, 2010 | Dell Inspiron 6000 Notebook
Can't factory restore dell inspiron 531 (windows xp).
You might want to try going into setup and setting your boot drive options to DVD drive as your 1st, HD as 2nd and Floppy as 3rd. Put your windows disk in the DVD before boot and run the program from DVD.
Jun 23, 2009 | Dell Inspiron 531s Desktop Computer
Inspiron 1200
Sounds Like a Bad Harddrive. First try to Format it out or even Better, Delete the Partition if you can. Then Go With the Fresh Install. Hope This Helps!...
Feb 10, 2009 | Dell Inspiron 1200 Notebook
Will not boot up!
Windows has probably become corrupted,,,try using you restore cd,,,or starting in safe mode.
Dec 23, 2008 | Dell Inspiron 1200 14.1 XGA LCD...
Inspiron B130 won't boot
plz try to boot through safe mode, if you can then log in normally.
if you cant boot from safe mode then you have to reload or repair your os.
Dec 23, 2008 | Dell Inspiron B130 Notebook
Dell desktop running windows XP
You should be left-clicking when the option for safe mode comes up...
Dec 15, 2008 | Dell Inspiron 8500 Notebook
Black screen dell inspiron
simple, insert the CD XP boot it on using it, then repair wait for a moment, then it give you options which is either to repair your OS or install it again. thats it
Dec 14, 2008 | Dell Inspiron 6400 Notebook
Black screen
Try to reinstall XP again, when prompted to partiton, select to do so.
You will lose everything on the hard drive and will need to reinstall all of your programs.
Hope this helps.
Good Luck.
Nov 28, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 monitor display problem
Well it is most likely a issue with the Video driver as you are able to boot to the safe mode.I would suggest going back to the safe mode and deleting the present driver for the video from the device manager.before you restart the system just download the latest version from the support.dell.com so that you can reinstall it.Also check in the graphic properties which screen is set to be the defuat.Incase still not working i would suggest reinstalling the operating system before replacing any hardware.
Jan 03, 2008 | Dell INSPIRON 6000 CENTRINO...
Dell Inspiron 1200 Notebook Logo
512 people viewed this question
Alun Cox
