Question about Weather King Heating & Cooling
Finding the cooling contactor on weatherking acclaim II gas furna
I have a Weatherking Acclaim II gas furnace (model wgph-05eauer) and The integrated furnace control is model 1028-928. I want to know where the "cooling contactor" can be found. It's a single stage operation. I am verifying the wiring between the thermostat and the integrated furnace control
  • 3 Answers
The "y" terminal sends the hot leg of the 24 volts and the "c" terminal sends the common leg to the condenser..
Posted on Dec 07, 2008
My weatherking acclaim furnace was working well, but started blowing cold air and would not shut off. I shut it off via fuse box and waited 15 min. and tried it...now it starts blowing cold air right
Usually when there is a problem with a unit in the heating mode it default to the blower running. Could be one of the limit switches need to be reset - or it could be some other issue related to the heating circuit.
You probably need to get someone to check it out.
Oct 04, 2014 | Heating & Cooling
What is the door switch on the weatherking acclaim II Furnace that allows it to go on and off?
When you pull the panel off the blower compartment there is a switch that verifys this panel is place. Its called a door switch although you are putting the blower panel on. Its usually black and has the hot incoming line voltage that runs through this first. Thanks Happy Heating
Dec 11, 2010 | Heating & Cooling
Igniter keeps breaking
Wow, this is a new one on me! Are you using true OEM parts for your source? If not, you may be getting sub standard parts. There are some companies that use generic parts and this isn't a good thing to do sometimes. Weatherking is a Rheem/Ruud product.
Apr 10, 2009 | Weather King 12AJA4801AH Air Conditioner
WeatherKing Acclaim II
  1. The sensor that tells the furnace whether the gas is lit has got build-up on it and is giving the furnace bad information.
  2. The flame sensor is often a single wire or rod that sticks up in the center of the flame.
  3. You can shut off the furnace and the gas and clean the sensor with some sandpaper.
If that still doesn't work, the sensor may need to be replaced.
Please rate this solution.
Jan 16, 2009 | Heating & Cooling
Where can I find weatherking acclaim II filters
Your best option is to contact your nearest wheather king/Rheem dealer. They may have replacements. The filter store online, they offer any size and cheap too!
Nov 30, 2008 | Weather King 12AJA4801AH Air Conditioner
not only the jets but you need to change the spring in the gas valve and cut the pressure WAY back to prolly 3.5"wc
Nov 22, 2008 | Weather King 12AJA4801AH Air Conditioner
Weatherking control board
the fan comes on only after the burner fires. so no stat voltage is expected. it is not powering the blower, the elec board is. only after burner lights will fan be energized due to heat build up. usually on older weatherking there is a heat sensor on the bulhead above the burners. it is stuck sounds like to me. try a sharp rap on the right side about four feet up the side and a foot back . if fan stops you know the switch was stuck . probably needs a new fan switch.
Oct 20, 2008 | Heating & Cooling
Heating & Cooling Logo
278 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
