Question about Sunbeam Hot Shot Electric Kettle
Sunbeam 3211 hot water dispenser at a mile high
Water boils at a lower temperature at higher altitude. Sunbeam must of forgotten this fact since I get 30 seconds of steam before the light goes off. The water sprays out from the heavy boiling action. Is there a way to adjust the high temperature limit?
2 Suggested Answers
  • 145 Answers
SOURCE: Rust coloured spots on insie of kettle
We buy DeBruce Polish at debruce, this stuff really works.
Posted on Aug 18, 2009
  • 245 Answers
SOURCE: What's your problem?After the water has boiled the water tastes funny
try another pan.
Posted on Feb 15, 2012
0 characters
1 Points
How to clean inside it
Boil Vinegar water or lemon juice water (liquid, not fresh lemon) to remove calcium buildup.
Mar 12, 2014 | Tayama N-25A Air-Pot Hot Water Dispenser
No water coming out of hot side of dispenser, only cold
Like most coolers that have "hot" works of a "preheat" if you are not pumping out anything there is an obstruction that needs to be cleared.
Oct 23, 2013 | Sunbeam Hot Shot Hot Water Dispenser...
Hi, I have a Bosch Private Collection Kettle. It is over a year old and has until recently been working fine. However, lately I do not feel that it boils to a high enough temperature for a long enough...
Some types of kettles use a separate power base to heat up the kettle jug. If this is the case with yours, turn the jug upside down and look. Also look at the parts on the base that touch the kettle jug contacts. If you can see the electrical contacts; mine were built on spiral rings for differing temperatures; try cleaning them with Brasso and a Q-tip (cotton swab) wiping the contacts several times to remove any tarnish and then use clean swabs to remove all traces of Brasso metal cleaner. Fill the kettle jug up to the maximum fill line and put the boiler on the maximum setting... boiling water. If the water doesn't boil... you have a more serious problem. Buy a new boiler as it isn't worth having someone fix it. Mine worked like new after I cleaned the contacts. Never immerse the jug contacts in water!!!
Nov 25, 2012 | Bosch Private Collection Jug Kettle steel...
The water does not cool
the problem is in the compressor cooling unit, if you have no knowledge of electrical this is beyond your ability to service, it is of refrigerator technology, if so contact me and i will try to help you.
May 18, 2012 | Sunbeam Hot Shot Hot Water Dispenser...
The switch does not automatically turn off when the water boils. If left alone all the water will boil out.
The switch has to turn off when the water boils as the heat generated must cut off the switch. If this wont work the bimetal is not working and the switch is not responding.
You will need to replace the switch. Please contact the dealership for the spare.
check this link for spare:
Sep 21, 2011 | Oster (3211) Electric Kettle
Does not seal when water is added. Water drips out
Filled Hot Shot with vinger, let it flow through at 15 minute intervals for a couple of hours.
Apparently the water here had lime and removed the buildup that was causing the leak.
Nov 18, 2009 | Sunbeam Hot Shot Beverage Maker () 2...
The plastic liner that holds the gasket in the water tank area where you place the 5 gal bottle over the spigot and spigot screw down to hold this plastic lid onto plastic gasket is warped and lets water...
you will have to get the parts to be replaxced if the gasket is cracket or the inner plastic is cracked you will have to first check out and order that particular part as this parts are not very costly but its not repairable.many users face the same problem of leak when the gasket gets pushed in the plastic and cracks .this creates leak when water passes through that area. -------------- you can get the required parts from -- ------ just click the link directly. ---------- you can also click this link directly and contact sunbeam service center to replace the parts ---------------- this will help.thanks.please do rate the solution.thank you for using fixya.keep updated.
Oct 13, 2009 | Sunbeam Hot Shot Hot Water Dispenser...
Mar 19, 2008 | Sunbeam 3211-2 Electric Kettle
Purchased at Canadian Tire mid December 07.....great sale....still more than I expected to spend on a kettle. EE and nothing.....same as previous customer comments.
Nov 07, 2007 | Bravetti EK119H Electric Kettle
Sunbeam Hot Shot Electric Kettle Logo
Top Sunbeam Electric Kettles Experts
Mike Cairns
Mike Cairns
Are you a Sunbeam Electric Kettle Expert? Answer questions, earn points and help others
