Cyber-shot dsc-w50
I transferred pictures from the camera to my computer, Now I want to
transfer some back to the memory stick duo pro (512mb) in the camera.
I got one of those electronic picture frames that shows slideshows in the picture frame and takes the memory stick. I thought it would be easy to transfer the photos back to the memory stick in the camera and then use it in the picture frame. I opened windows explorer and used copy and paste to move the photos to the memory stick after connecting the camera as usual and it showed the transfer in explorer but when I use the camera to view it says the file is empty so the pictures are not transferring to the memory stick
SOURCE: flash symbol flahing with flashing number E9101 but does not flash only infer red light
Try this........
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
Hope it will solve your problem....
SOURCE: Sony Cyber-Shot DSC -W50
NO PROBLEM. RIGHT NOW YOUR DSC-W50 IS COMPATIBLE WITH MAC OS9.1 AND MAC OS 9.2.
YOU NEED TO POINT TO SONY-eSUPPORT DSC-W50-SOFTWAREUPDATES AND DRIVERS.
THIS SHOULD SOLVE YOUR PROBLEM. IF NOT, REPLY TO: ARCLIGHT1217 AND I WILL DO SOME MORE CHECKING ON THIS SITE. THANKS AND GOOD LUCK! JUST A QUESTION- AREN'T THESE TWO OF THE OLDER MAC OS SYSTEMS? I THOUGHT THEY WERE USING LEOPARD AND 10.0? THEY WERE THE ONLY ONES LISTED SO FAR.
SOURCE: Sony Cyber-shot DSC-W50 issues
Great explaination.
I tried this reset, but the error came back. Read in other posts that it is a "flash capacitor" problem.
SOURCE: sony cyber-shot dsc-w50 problem
When “FLASH error” (Self-diagnosis Code E : 91 : ** ) occurs, to prevent any abnormal situation caused by high voltage, setting of the
flash is changed automatically to disabling charge and flash setting.
After fixing, this setting needs to be deactivated. Flash error code can be initialized by the operations on the Setup screen.
Method for Initializing the Flash Error Code
Initializes the setting to the default setting.
1 Select [OK] with v on the control button, then press z.
The message “Initialize all settings Ready?” appears.
2 Select [OK] with v, then press z.
The settings are reset to the default setting.
• Make sure that the power is not disconnected during resetting.
SOURCE: Sony cyber-shot dsc-w50 problem
Hi!
It's a flash error. Could be flash fuse or flash board. If you have a multimeter and you're ready to open it, contact me at [email protected] or contact your local Sony service center.
I work in a Sony service center.
Tom
