Not only does it have the error codes, it won't unlock. First can you tell me how to open it, then how can I take it apart before I take a sledge hammer to it.
Poroblem may be the door lock mech. Please check on the other solutions on this site where it said to check for loose wire connections to the CCU unit. This worked for me.
Here are the steps to unlocking the door manually 1.Unplug machine 2.remove bottom panel 3.Reach up along the inside of the front panel and locate the botttom of the door latch assembly 4.Located on the bottom of the door latch assembly is a tear dropped shaped tab 5. Gently pull down on the tab about a 1/4 inch or until a click is heard. 6. You may now open the door.
This code means the door lock mechanism has failed or the central control unit has failed. Replace the door lock mech. first. This should fix the problem. (before replacing anything make sure there is no obstruction around the switch or in the switch.) After the machine has been unplugged it may fix itself. if not replace door lock mech.
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
The usually reason the door remains locked once the cycle is over is because the filter screen on the drain pump is blocked so not all the water could drain out...the door lock is tied into the pump and until the pump tells the control board that the wate r is out the door will not unlock. This tip i wrote will show ya how to take apart the washer to clean the filter on the pump. http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier. 2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose. 3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located. 4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
F/dU error means --------- Door Unlock Error A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error. -------- to resolve the error --------- Door Lock Mechanism broken.Check Door Lock/Switch Assembly for foreign objectsCheck Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)Door Lock/Switch Assembly Failure
Open the lower panel and look on the right side panel inside the washer. You will find a service manual telling you what the codes indicate. Our Duet does not have a F-1 code, F-H, F-2...., but no F-1
