Question about Sony Handycam DCR-TRV245 Digital-8 Digital Camcorder
Jammed tape / tape not "recognised" by camera
Upon loading a new tape, my camcorder (already a few years old) started to go wrong: it did not seem to recognise a tape had been inserted and would therefore not record. Tried changing the tape / topping up the battery / playing an old tape but only managed to jam the tape case and now I cannot even close the body of the camera and the tape just juts out. Anybody had the same problem please? J
JoeO700
  • 80 Answers
SOURCE: not reading Hi8 tapes
Fidus, I am not sure where you are located but the camcorder you're trying to use now is a PAL version of Sony's 8mm camcorder. If the tapes you recorded earlier were recorded in D8 (digital 8) or 8mm/Hi8 format NTSC, they will not play correctly in this unit. The NTSC and PAL formats are different and not compatible. Hope this helps you. Joe Weibel customelectronics.org
Posted on Mar 01, 2007
SOURCE: Tape Won't Load
this sort of helped,,... slam it against the wall... pick up the pieces, throw em' in the trash, buy a new camera!
Posted on Feb 07, 2008
Bubbabear64
  • 2794 Answers
SOURCE: tape loading
You should take it into a camera shop and have them inspect it. Those assemblies are pretty detailed. They have the tools to fix the problem.
Posted on Aug 12, 2008
welcomejee
  • 10594 Answers
SOURCE: sony dcr-pc101e camcorder / vista laptop
Please download Sony USB Driver from Sony Support so your computer will recognize your camera DCR-PC101E.
Posted on Oct 05, 2008
SOURCE: My USB device is not recognised
i want to usb device in my computer.so please give me the idea for download it.
Posted on Oct 14, 2008
Sony HVR-A1U "Reinsert Cassette" Error pops up frequently
I have had this error on my 3 year old Sony A1E and it has resulted in glitched picture and audio, despite not showing a poblem whilst recording. It came up with C:31:23 error. Start of the tape seemed ok and the end seemed to get pixellated. A friend said the PD170 had the same issue and had to have her tape heads changed. I've tried cleaning mine but problem still there. I'm looking at getting new NXCAM as I've spent a lot of money last year getting it fixed.
Jan 06, 2010 | Sony HVR-A1U Camcorder
Have a 1993 Sony CCD-FX420 camcorder that I have not used for a few years. The tape deck opens and closes fine without a tape, but when I insert a tape it won't completely close. How do I fix this? Thanks....
It is more than likely that during the period of prolonged storage in less than ideal conditions, some moisture has entered the camcorder and rendered it useless. This camcorder is also some twenty-four years old, and all consumer electronic devices have a limited life, even if well looked after. I feel your only choice is to replace it, and keep the replacement in optimum storage conditions - maybe in a dry cupboard indoors.
Apr 03, 2017 | Sony Video Cameras
Tape jammed in jvc camcorder
The way I can get a tape unjammed on my Sony camera is to remove the battery, plug the camera into the AC charger that is plugged into the wall outlet. Then power the camera on, wait a few seconds. Then unplug the charger from the outlet, wait a few more seconds (camera still in "on" position) and then plug it back in. I have used this method at least 3 times to get the camera to release the tape.
Sep 08, 2009 | JVC GR-D250 Mini DV Digital Camcorder
Tape loading
Aug 11, 2008 | Sony Handycam DCR-TRV38 Mini DV Digital...
Sony DCR-HC40E Tape Holder Mechanism load failure
Your camera needs Mechanism replacement.
Software CD is available on charge basis.
Apr 30, 2008 | Sony Handycam DCR-HC40E Mini DV Digital...
Playback
Recording and playing a new tape worked for me too. Thanks!
Mar 17, 2008 | Sony Handycam DCR-TRV103 Digital Camcorder
How to switch from sp to lp mode when playing back?
Did you try setting the rec mode to SP in the playback menu?
a54f98a.jpg This is from the D250 manual.
Dec 18, 2007 | JVC GR-D250 Mini DV Digital Camcorder
DCR TRV320
That is the "LOAD" error code.
However, to service the C:31 code, Sony recommends you do the following:
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
If your camcorder still shows the same error code, then you'll have to send in your camcorder for service.
Oct 25, 2007 | Sony Handycam DCR-TRV320 Digital Camcorder
Tape jammed??
Maybe your blaming the wrong people? Maybe your camcorder has a problem? with the power off, try pushing the eject button and the power button down together for a few seconds, but push down the eject button before the power. If that does not work, you will need to have the camcorder service and ask the servicer to please be kind to the tape as it is important. Good Luck
Jun 12, 2007 | TDK DVM60 60 Minutes Mini DV AY-DVMCLC 5...
Sony Handycam DCR-TRV245 Digital-8 Digital Camcorder Logo
44 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Jose Ma DM.
Jose Ma DM.
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
