New canon pixma printer mx 300 is flashing check printer at step 7 for easy set up instructions.do i have to set up fax connections or ca i by pass that ?
    Genius:
  • 1,913 Answers
If u need to use fax u must setup
Posted on Nov 15, 2008
How to recieve fax from canon pixma-mx 330
You will need to plug in a phone cable to the back of the printer. Then enter the printer's set up page by typing in the IP address of the printer into a browser and walk through the fax setup steps.
Mar 01, 2011 | Canon IP5200R Colour BubbleJet with...
I have the machine fax Canon Pixma MX 300. It writes "Recommend new C-CRT". Please, explain me what it means.
If the machine is a color printer it may mean Recommend new Color Cartridge. The color cartridge may be low on ink or defective.
May 18, 2010 | Canon MX300 Office All-In-One Printer
Computer says Orinter is Offline but is connected. Has the Fax button highlighted. Only have Copy, Fax, Scan, Memory Card to select from, which one should be highlighted for printing from connected PC
In order to print from PC you should choose COPY function. To check the connection between PC and your printer perform these steps:
  • Right click on printer driver name (Canon PIXMA MX 850 in this case)
  • Choose Properties
  • Click on Maintenance tab
  • Click View Printer Status: the status should ONLINE in order to print or scan
If still Offline,please recheck USB cable,reinstal it,or compare with another cable.
Source: Inkjet Forum
Oct 11, 2009 | Canon PIXMA MX850 Multifunction Printer
Printer keeps defaulting to fax option
You have set the default printer to the Fax option.
Firstly, you could use the drop down menu where the Printer is displayed (when you go to print), and select the "regular" printer as opposed to the 'fax printer".
To set the default permanently to the laser printer....go to "printers and faxes" in 'control panel'. You will see a "check mark" next to the 'Canon MX 300 Fax' (or whatever it is called) identifying it as default. You want to put the 'check' next to the "regular printer" (whatever it is called)....'right click' on it, then "left click' on "set as default". Now when you go to print anything, it will just print.
Please rate me:)
May 01, 2009 | Canon PIXMA MX300 All-in-One Printer
Cannot recieve or send faxes
Check out the Easy Setup Instructions available here. If you can neither send nor receive faxes, you may not have the phone line connected to the correct port, see page 34 of the guide. Also check what receive mode the machine is set for. Pages 42 and 43 explain the different options and how to change the receive mode.
Mar 16, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon pixma mx 300 won't send or receive fax
Dear friend,
it's very important to connect your MX 300 with the telephone line the right way! Please read once more the part "Preparing the machine for fax" in the chapter "Faxing" of the MX 300 User's Guide and mind the hint "Important: Do not connect the machine and external devices in parallel to the same telephone line using a splitter (A). The machine may not operate properly."
Greetings from Cologne (Germany) to the UK!
Dec 02, 2008 | Canon MX300 Office All-In-One Printer
251 people viewed this question
jasbo
jasbo
