Question about JVC HX-GX7 CD Shelf System
CD tray stuck
One of the CD trays is stuck halfway open. It will attempt to close but it appears to hit something. I can not open any other tray while that one is open. Any ideas?
4 Suggested Answers
SOURCE: cd player opens when turned on and will not function
I have brought my system to a JVC service center in January. They kept it for 2 months, trying to find the problem.... Finally, they told me that they would need to replace the whole CD player section (drawers + reader assembly). The cost of this repair would be more than the cost of a new system !!! I now have a large, expensive RADIO TUNER in my bedroom, without CD player :-(. I hope someone will find a solution. This is the last JVC system I purchase, EVER.
Posted on Apr 17, 2008
SOURCE: JVC Stereo won't open cd tray
take off the cover and get whatevers jamming it out mine did the same thing
Posted on Jul 30, 2008
SOURCE: cd shelf
The hx-z10 mini stereo system is giving me the same problems again.
Posted on Sep 06, 2008
SOURCE: CD player ate a CD!!
I fixed the same issue by forcibly pulling individual trays to their open position.  I removed the casing to gain better access (tons of screws) but you can probably gain clear access to the shelfs without removing the casing if you have good needlenose plyers.  I found a stuck CD within one of shelfs, wedged WITHIN the moving components of the shelf.  It works perfectly now.
Posted on Mar 07, 2009
0 characters
1 Points
Disc Tray will not open . There are no Cd's in the player. It looked like a tray came loose and before I could keep it open it closed. Now the disc tray door is stuck
The unit will need to be dis assembled and repaired by a technician. One of the plastic gears may be broken or misaligned. If you are mechanically inclined you could attempt the repair yourself but be careful not to loose any of the parts.
May 04, 2010 | Panasonic SC-AK600 CD Shelf System
Cd changer loading problem (panasonic sa-pm53)
Have a Panasonic SA-PM53 pulled a CD trays out to get stuck CDs out. So how do I get the 5 CD trays back into the carriage and in sync?
May 24, 2009 | Panasonic SC-AK78 CD Shelf System
Deneon UD M50 - Tray jam
It sounds like the cd tray has been forced shut and has been damaged when you got the CD's out. If it was me I would of unscrewed the casing and retrieved the CD's that way instead of trying to force the try open which I'm assuming you have done.
It could just be a simple matter of just slightly adjusting the internal CD mechanism so that it can open and close properly without jamming. The error message comes up because the tray cant eject properly. The worse case scenario is that the CD mechanisam would need to be replaced. Not a hard job for a service engineer, if you dont fancy taking the thing apart yourself then a service centre is your best bet.
Nov 01, 2008 | Denon D-M50S CD Shelf System
Cd tray not staying closed
gently push the cd door back in while pushing the door closed button , untill it closes if it still comes out then the cd laser mechanism is not lifting or something else has happened , then it will need to be tested to determine the exact cause
Oct 16, 2008 | Memorex MKS5001 Shelf System
CD tay won't open
If you had any cds inside, you can open the case and see whether there's any cd jammed, with the power switch off! If you didn't have any cds inside, open the case anyway and check if the tray opens or not!!!
Hope it goes well!!
Apr 04, 2008 | RCA RS2653 Shelf System
hi, there must be a disk previously inserted which has stuck in the tray or something, open the cover and check if anything is preventing the tray from ejecting.. let me knoiw
Dec 28, 2007 | Philips MCM530 CD Shelf System
CD tray stuck
Problem is very simple, Switch off system, unplug from mains. Open the Cover panel, and remoove CD. Close machine. Plug into mains. Open Tray, put in anothrer CD, enjoy your music.
Mar 05, 2007 | JBL Harmony Shelf System
FW-R7 displays "Locked" when attempting to open CD Trays
You were close, but didn't explain it very well. If you push on the 'DISPLAY' button (left side of machine as you are facing it, about half way down) when the unit is off, it will say something like "DEALER MODE", push it again to return it to regular mode. You may have to press and hold the button to get it to display 'DEALER MODE', then when everything is normal, "DEALER MODE" just goes off and isn't replaced by anything. Hope I explained it well.
Feb 09, 2007 | Philips FW-R7 CD Shelf System
CD player problem
Seems like the Timingfor the Tray Open / close has got disturebed. Could be a bad drive gear, or as simple as a loose Drive belt. Get it checked by a professional.
Sep 19, 2006 | Sony MHC-RX70 Shelf System
JVC HX-GX7 CD Shelf System Logo
Top JVC Audio Shelf Systems Experts
Are you a JVC Audio Shelf System Expert? Answer questions, earn points and help others
