Question about Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor
Usb ports on monitor
I am not able to use a flash drive and charge my bluetooth on the usb ports on the monitor. What is wrong with the two ports on the monitor
All you have to do is connect the monitor to the CPU using a USB cable in addition to the usual installation ( check the slots available on the monitor for the type of USB cable you need ), then all your USB slots on the monitor will come alive. Its just like a USB extender ( except that this is included in the moniter).
Enjoy
Posted on Jan 01, 2009
I had similar problem after Windows Update. Instead of Generic USB HUB I had HX2LP Kit (3.03.0000.2). I update driver using old Generic USB HUB driver from Windows. After this everything in back to normal.
Posted on Jun 28, 2009
    Genius:
  • 1,913 Answers
Check in your computer cpu back dside u see usb option.
Posted on Nov 15, 2008
How do I connect NEXT7P12-G to bluetooth keyboard?
It looks like your tablet is not Bluetooth-enabled, in which case you cannot connect the Bluetooth keyboard to it. You may try to connect a regular keyboard via the USB port on the tablet (although I believe that USB port may accept only flash drives).
http://www.nextbookusa.com/pdfs/Next7P12-8G%20Tech%20Spec%20102412.pdf
Sep 07, 2014 | Nextbook Next7P 7" Tablet
How to insert sandisk cruzer force usb flash drive into computer?
Usb sockets are all same. Haven't changed. There are other sockets that look similar. HDMI, eSata, display port. I would look very closely to make sure you are attempting to install in the correct port. You might first want to take a look at the flash drive end to make sure that there is no damage. Shouldn't be unless you really tried to force it into wrong port. Other than that, it will fit.
Aug 02, 2014 | SanDisk Cruzer Force 16gb Usb 2.0 Flash...
How do I trouble shoot my usb port?
Quote from the manual:
The USB port provides power only, and will not playback music from a USB device.
You can download the manual here:
http://www.dualav.com/support/manuals/xd250.pdf
May 07, 2014 | Dual XD250 CD Player with Auxiliary Input...
How do i activate my usb ports
Most USB ports are on by default.
If you are using a USB mouse / keyboard and they both work.
Your USB ports are working.
If somehow these were turned off, it is most likely in the bios.
Reboot and go into the bios screen. F2 or the Delete key are the most common keys. Usually the monitor will flash these one of these quickly during the boot up process. Hold down the appropriate key till the bios screen opens. Navigate to the USB section and be careful not to change anything else. Wrong setting here and the machine may not boot up. Check to make sure the USB is on Auto, enabled or whatever the bios is for enabling the usb ports. You may have more than one selection. you can experiment a little here. Just note what you select and under which category should you have to return and make another selection.
If your using a Windows machine you may have to reload or update the USB drivers. Slimdrivers is a good update utility found here >>
Download SlimDrivers MajorGeeks
You can update other areas but for now just focus on the USB drivers.
It is not a good idea to update everything at once and then wonder what happened if something goes horribly wrong. :)
Good luck and hope this helps
Mar 19, 2014 | Electronics - Others
Usb malfunctioning
which USB are you referring to? if usb cable connection , try with a different cable, if USB port for flash drive, try usb port with another functional flash drive or test your flash drive onto another device to test for functionality.
Feb 22, 2014 | Dell UltraSharp 1905FP 19" LCD Monitor
I have a voyager pro+, about a month old, and now the red light does not flash on when I press the 'on' button, or plug the charger into it. Any ideas?
If your are charging through the USB port, and you have put it in wrong at all at any time, the connection will be shot and it will not charge. If this is still under warranty try to see if you can get it replaced.
Good luck from Headsets Direct!
Dec 31, 2010 | Plantronics Voyager PRO Bluetooth Headset
HOW TO COPY AN BLUETOOTH DRIVER ON FLASH DRIVE
Hi to copy bluetooth drivers to your flash drive you need to plug the flash drive into the computer USB port locate the drivers you want to copy select the drivers then right click on the drivers and select copy, Locate the flash drive icon on your computer double click it and then right click on paste to put it on the flash drive.
Aug 08, 2010 | Computers & Internet
I was given a Xenon flat screen monitor. The back has 4 usb ports and 1 usb input and an analog rgb port. It came with no cables. Can I just use a usb cable or do i need the analog rgb cable? Also when I...
The USB hub/connections cannot be used for driving the monitor... It is only an extra feature so that you can connect USB devices (such as a mouse & keyboard or flash drive) at the monitor instead of the computer ports.
You must use the RGB/VGA connection to use the monitor.
When you turn ON the monitor, it should "announce" itself with a logo...
When you were given the monitor, were you told that it works?
Please connect the monitor and comment back...
Thanks!
Sep 10, 2009 | Computers & Internet
What can I use the 2 USB ports on the stand for?
This is a simple HUB that has two type A receptacles and one type B receptacle; you use a printer style plug to connect the Type B receptacle into an available USB port on your computer. Then one port becomes two. It's not a powered hub from what I can see (the ports are on the base, which isn't wired to the monitor, so no power), so that rules out most external hard drives. I don't know of any monitors that use USB for anything, but printers, flash drives, cameras, and the standard small gadgets should work fine on it.
Mar 17, 2009 | LG L1910B (Silver) 19" LCD Monitor
USB Port problem?
sounds like just how it is call sony
Feb 14, 2008 | Sony Playstation 3 (PS3) Console
Open Questions:
Dell UltraSharp 1704FPT 17" Flat Panel LCD Monitor Logo
305 people viewed this question
Alun Cox
