Question about Rinnai Water Heaters
My rinnai has build up in the heat exchanger
The code that shows on the control is LC. what can I do?
Is there a chemical that I can flush through it?
  • you have a lime controll issue , you need to flush the unit using food grade vinegar. go to the rinnai web site for instructions. it is a pretty simple solution they make a kit to flush your unit if it was installed with an isolation kit.
Posted on Jan 10, 2009
Whiterussian is speaking without product knowledge. The first answer is correct, to follow the manufacturers instructions and flush with vinegar.
One of the most basic and simple things "professionals" miss is to always read and follow the instructions. They probably won't ask for directions when they're lost either.
Posted on May 05, 2009
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 167 Answers
Not really, commercial boilers are cleaned with concentrated surfuric acid which takes a trained professional with knowledge in organic chemistry to control that kind of dangerous reaction. CLR might remove some of the calcium deposits; but I have never tried using it. I usually buy a new heat exchanger and recycle the old one. Unfortunately without a water softener supplying the tankless it will just happen again; that's why in the fine print of your warranty it is void if you don't have a water softening system installed.
Posted on Nov 28, 2008
Er3 flashes hot water will not reach set point
Had this happen to me before, if you have hot water from the boiler going in and out of the boiler mate and the temps are not rising within the hot water means more than likely you may need to remove exchanger and clean sediment off element, basically sediment creates a blanket over the heat source causing poor thermal conductivity. Things to check before removing heat exchanger
- outlet temp of boiler water to aquamate -inlet temp of boiler water to aqua mate= 20-30'F if low then bad thermal transfer or poor water movement
-make sure sensor is reading properly
- get boiler temp higher to speed up thermal gain in water heater
Jan 19, 2014 | Amtrol 2704E76 41 Gallon WH-7C BoilerMate...
What is the gray gravely discharge coming from my PowerStar AE125 when using the hot water? It plugs up the faucet and shower heads within minutes and almost completely blocks the water flow.
Heating water can peculate chemicals out of water, such as metals and organics.
Especially above 138 degrees.
Have well water tested.
Turn down thermostat temperature.
Or reasonably harmless well-water bacteria can react with anode rod, or other reaction in softener, to produce colored water, and smells.
Different water can produce different sludges, brown, red, gray, black, yellow.
The sludge can also combine with deteriorating pipe flakes to clog water flow.
Sludge can accumulate over years in low spots in pipes, or at elbows and constrictions.
Have plumber flush pipes.
Or run new pipes.
Also delime tankless yearly, and flush with white vinegar as shown in product manual, and treat bacteria with H2O2 hydrogen peroxide.
http://waterheatertimer.org/pdf/Bosch_Descaling-heat-exchanger.pdf
Oct 29, 2012 | Bosch PowerStar AE125 AE125 Whole House...
WE bought the water heater in 2006. It has a continuing problem of the potassium harding in the heater, causing it to not function. The installer cleaned it out the first time with much work. How to we...
1) Post question on pro water heater forum.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
2) Tank temperatures higher than 140 cause chemicals to distill from water.
3) Flushing tank each 6 months is good idea for all water heaters.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#flush
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 25, 2011 | Northstar Water Heaters
Rinnai is buzzing and reads 130 LC
Sorry to read about your problem, I hope this helps you out.
The 130 is your temp setting
Scale Build-up in Heat Exchanger (when checking maintenance code history, "00" is substituted for "LC")
Flush heat exchanger. Refer to instructions in manual. Replace heat exchanger. NOTE: The LC code is the only code that will allow the unit to keep running.
The display will alternate between the LC code and the temperature setting.
The controller will continue to beep. The LC code will reset if power is turned off and then on.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 30, 2010 | Rinnai Water Heaters
Thermostat flashes IL ? Model PTG-53PVN
http://www.palomatankless.com/owners/homeowner+trouble.lasso#28-11
The Controller displays error code "1L."
There is a build-up of lime in your Paloma.
Contact your plumber to service the Paloma by flushing out the lime.
Also search u-tube for flushing lime out of tankless.
Dec 29, 2010 | Rheem Paloma Tankless Water Heaters...
Rinnai tankless water heater
LC is the error code that you get when you have limescale buildup in the heat exchanger. You need to flush your heat exchanger. If you have the manual for your water heater, use it. The manual to mine is attached. The procedure for flushing it is covered on page 12. I suggest that you have a certified Rinnai plumber perform this task as it requires a ciruclating pump and some hoses that you need to connect to your water heater. If you don't perform this task, it is possible that you will need to replace your heat exchanger and this is not something covered by Rinnai's warranty.
Sep 21, 2009 | Rinnai Webstone The isolator EXP tankless...
Code LC, I cleaned the filter, won't stop beeping
you need to flush out the rinnai. to do this you will need 4 gallons of white viniger & a circulating pump. #1 disconnect the power. #2 close both incoming & outgoing water valves under the unit. #3 conect a drain hose to the out going flush valve ( flush valves are under the unit & have brass caps) #4 connect pump outlet hose to ingoing flush valve. #5 put pump incoming hose & drain hose from outgoing flush valve in a 5 gallon bucket. #6 pour 4 gallons of vinager into the bucket. #7 open both flush valves. #8 turn on the circulating pump & let viniger pump in the incoming flush valve through the rinnai & out the outgoing flush valve back into the bucket for 45 min. #9 disconct pump from incoming side & close incoming flush valve.( don,t close outgoing vaves at this time) #10 put out going hose in empty bucket. #11 open incoming water to flush viniger out of unit. # 12 disconct outgoing hose , close outgoing flush valve & open outgoing water valve. #13 clean filter & turn on power.
Jul 08, 2009 | Rinnai Water Heaters
My rheem umc-117 controller flashes an IL code.
it means that you have lime build up in the heat exchanger and it needs to be flushed out ASAP!!
Jun 27, 2009 | Rheem Tankless Water Heater Main Remote...
Vinegar flush
You should not have to flush unless the code LC comes up. but here is the flushing diagram.
Dec 19, 2008 | Rinnai Webstone The isolator EXP tankless...
Water Heaters Logo
1,092 people viewed this question
Top Rinnai Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
jdthefixer
Are you a Rinnai Water Heater Expert? Answer questions, earn points and help others
