Question about HP Pavilion dv4307CL Notebook
Keyboard and touchpad
The keyboard and touchpad to my notebook stopped working. i am now typing with an on-screen keyboard and connected a usb mouse. what is wrong with my notebook?
Describe your compaq presario cq60 touchpad not
after rebooting my Compaq Presario CQ60 laptop the touch pad does not work and I have to use a plugged in a mouse
Mar 09, 2010 | HP Compaq Presario CQ60-249US Notebook
Problems with keyboard/touchpad
here what you need to do, disable your keyboard/touchpad because its grounded and soon will not usable anymore... due to this problem, you can use USB keyboard but if you can find the same replacement on it... buy it. Good luck!
Jun 20, 2009 | ASUS Eee PC 900 PC Notebook
Acer aspire touch pad not working
There are many possible fixes. To do some forensic work it would be best to know what was going on when the touch pad stopped working. It could very easily be the driver. You can see if that's it in device manager. Locate your touch pad device there and right-click on the device, choose "update driver".
Some laptops, my Toshiba for instance, have an option to configure the touchpad to disable when it senses a USB mouse or keyboard connecting. I have mine set to disable because when I'm typing on the onboard keyboard and I accidently slightly brush the touchpad, it sends the cursor all over the page and usually I lose everything I just typed.
The problem might also be a matter of a bogus setting in the Service Manager. There are a number of services that are related to your touchpad or mouse.
Feb 21, 2009 | Acer Aspire 9300-3716 Notebook
Cannot connect mouse to the usb port
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Nov 18, 2008 | Computers & Internet
Toshiba satellite touchpad & keyboard stopped working
As I understand your keyboard is now working and your usb mouse. But the touchpad does not work.
Have you or someone opened up your laptop recently? If so it is possible the touchpad was not connected properly.
Can you please post the exact name of your laptop. I'll see what else I can figure out for you.
Oct 03, 2008 | Computers & Internet
Acer Extesa 6601 Keypad & Touchpad Problem
you need the drivers for the touchpad and keyboard, click on the drivers and utilities section, then allow active x when the pop up appears
http://support.acer-euro.com/drivers/notebook/ex_6600.html
Aug 23, 2008 | Acer Aspire 5100-5022 Notebook
Keyboard,sound,touchpad all not working keyboard, touchpad and all usb ports stopped working
kINDLY CONNECT A USB KEYBOARD AND/OR MOUSE TO TROUBLESHOOT THE NOTE BOOK IF USB KEYBOARD/ MOUSE (EXTERNAL NORMAL USB DESKTOP KEYBOARD MOUSE). THEN WE WILL BE ABLE TO TROUBLE SHOOT
Feb 29, 2008 | Acer Aspire 5100 Notebook
Have you attempted to use an external mouse? - USB - if so does that work?
if it does - Click on START - Control Pannel - Keyboard (& Mouse Respectively) - Click on the hardware Tab - Select the relevant Key Board, Click on Properties - this will give you a device status - if is is not working properly - click Trouble shoot & follow the onscreen instructions. - If is "Working Properly" click on Drivers - check your driver is updated, or roll back.
If you happend to be on a server and the keyboard and/or mouse have stopped responding - you will need to restart (The Server). Ensure that the Keyboard and mouse are on PS2 connections and not USB - the Severs do not like USB Connected Comms Devices. I have found if there are wireless mouse's &/or Keybourd's &/or any USB connected Mouse/Keyboard, they tend to somehow interfere with each other (i.e. the sever with one of the terminals) - only remedy I have ever managed to make work is restart.
Hope this helps
Feb 04, 2008 | Toshiba P25-S670 Notebook
HP Pavilion dv4307CL Notebook Logo
118 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
