Question about Vizio L6 20.1 in. HD-Ready LCD Television
My 37'' Vizio LCD TV has a green haze and lines on the TV
When dark colors appear on the TV, instead of being black they are green as well as some of the faces have a greenish tint to them.
  • 3 more comments
  • Anonymous Nov 23, 2008
    exactly the same as mine very annoying
  • Anonymous Dec 10, 2008
    I have the same problem after 6 months, Walmart wont take it back, Vizio is simply flat out garbage, cheap junk they push into the market like companies did back in the 80's. Stay with the "S's" Sony, Samsung, Sharp.
  • Anonymous Mar 09, 2009
    I have the same problem, they came out and replaced my main board but it did nothing. I finally took my TV apart and there are what looks to me some sort of electrical shielding under the small board on the left side of the tv. I removed the board and reset the shielding, once I put it back together the lines were still there but very low. I then tapped the cover over the board over the shielding the the lines immiediatly went away. Hope they stay away. Could be an electrical sheilding problem. Good Luck!
  • joel_aaron8 Mar 20, 2009
    thanks phongnv, could you tell me where I can find that cable, and about how much it will cost?, is it easy to replace?. I have the same problem with my vizio gv42l
  • Anonymous Mar 16, 2014
    green pixels on dark colors on vizio tv
    New Friend:
  • 56 Answers
It is a very simple fix. Replace the LVDS cable will fix it. This cable connect the mainboard to the panel.
Posted on Feb 18, 2009
VIZIO Tv E422VA picture showing red or green color on dark areas of screen.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 29, 2015 | Vizio E422VA 42-inch Widescreen LCD TV -...
Vizio e500ar
If any colors (red, green, or blue) are missing, check the video cable to make sure it is securely connected. Loose or broken pins in the cable connector could cause an improper connection.
Connect the LCD display to another computer.
Aug 01, 2014 | Vizio E500Ar 50 Class Lcd Hdtv - 1080P,...
Color problems vizio lcd hdtv
If your tv has a custom settings area, first turn all color down on set so picture looks black and white. Now in color settings look for red blue and green color bars. Use the bars until the picture looks as true to black and white as possible. Also, try changing color temp.
Dec 21, 2013 | Vizio VW37L 37 in. LCD HDTV
Vizio TV has purple haze and colored stripes on the sides of the picture.
You possibly have a failing hi-voltage module or fly-back transformer going bad. If it has a fly-back transformer, It's not worth the trouble. Some repair shops will sell you a module. Call a repair shop for help.
May 09, 2017 | Vizio Televison & Video
I have color vertical lines instead of a picture on the screen
color vertical lines means the lcd PANEL is gone bad. it is a costly part which can cost more then 70% of the total cost. you need to replace it.
Sep 26, 2011 | Vizio E370VL 37 in. LCD HDTV
The TV has red and green lines, I touched the
you willl need an LCD panel replaced the buzzing sound you hear is the broken floresent bulbs arching
Nov 30, 2009 | Vizio VW37L 37 in. LCD TV
How do I get rid of purple and green wiggly lines? The black screen that appears when switching between channels was green a couple of weeks ago, that problem stopped after I unplugged the set for a while....
You have a bad LCD control board,It overheats and causes colored lines,screen to darken,or the color go floresent. Also check the power supply for bad caps.
when you have it apart.They usualy go bad on these tv's. It will cause the tv to take longer to come on.Or you have to hit the power button several times to get it on.
Oct 26, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Vizio 42"LCD Red Dots when warm
sometimes changing from hdmi to composite inputs solves it.
Jan 01, 2018 | Vizio Gallevia GV42LF 42 in. LCD...
Picture has a red "haze"
the color in my tv is a little faded when theres dark scenes on cant really see picture. Red and Blue really fade into picture
Feb 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
Vizio L6 20.1 in. HD-Ready LCD Television Logo
2,248 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
