Question about GE GSS25JEM Side by Side Refrigerator
Freezer works, fan works, fridge side not getting cold
I have a GE GSS25JEMC side-by-side. This morning we opened the fridge to notice that everything was much warmer than normal. The freezer side is working fine, the fan comes on fine, too. There didn't seem to be anything blocking the vent from the freezer to the fridge. What are some other possibilities? p.s. I don't have a manual for it and can't seem to find one online. Thanks for any help.
  • Clay Whipkey Nov 26, 2006
    We had a guy come look at it and it was a defrost issue. They quoted $450 for the parts and labor to replace the defrost components. It was time for a new fridge anyway so we bought a new one. However I would like to sell the GE if I can fix it. Was $50 a fair price? Any guesses on what the parts alone would cost me?
    oops. I meant "Was $450 a fair price?"
    President:
  • 878 Answers
Whip, make sure the condensor fan is running in back. It should be running anytime the compressor is running. Check to see if you have a buildup of frost on the back of the freezer panel, this could indicate a defrost issue. This refer is controlled by one main mother board in back. Check these things first and post back. You may have to do some tests on the board...Catriver..post back.
Posted on Nov 25, 2006
  • Ron Marek
    Ron Marek Nov 26, 2006
    Whip, all depends on what they were charging you for. Usually the heater assy. is what fails on the defrost for this unit. It's a glass heater, you can see it here.http://www.repairclinic.com/0080.asp
    It's usually not necessary to change out the board if just the heater failed. Tests can be made on this board to determine that. The bimetal for this defrost is only a back-up incase the evaporator thermistor fails to end the defrost. So in your case, without being there, could be a 5.00 thermistor and a 49.00 heater. Did the service company do any tests on the board? If it was a GE technician, he should know his business...Catriver..post back.
Kelvinator cyclic 410 Upside Down Fridge Freezer. Fridge not getting cold. Freezer is working fine.
Is the fan in freezer compartment working? Is the damper fully open to allow cold freezer air into fridge section?
Sep 23, 2017 | Refrigerators
My Whirlpool side by side fridge and freezer not working
Most likely, if you can hear the compressor running, the fan inside the freezer is not working. When the compressor is running, open the freezer and listen for the fan running. If you don't hear it, locate it and, with a voltmeter, test for voltage across the terminals. If you have voltage present, replace the fan. You can buy replacement fans at a local appliance parts store, internet parts suppliers, even ebay.
Jan 29, 2010 | GE Refrigerators
FRIG DOEN'T GET COLDER THAN 49, WHAT COULD BE THE PROBLEM,FREEZER WORKS GREAT (GE PROFILE) ABOUT 2 YEARS OLD-
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp control. Make sure the fan is running when the compressor runs. Make sure the vent(damper) opens and closes as you adjust the fridge temp control.
Jun 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Side by side refrigerator not working
THE FREEZER FAN BLOWS COLD AIR TO THE FRIDGE SIDE, TO ACCESS THIS FAN YOU NEED TO EMPTY THE FREEZER SIDE AND REMOVE THE REAR PANEL SOMETIMES A WHIRL OF IT WILL GET IT SPINNING AGAIN BUT YOU MAY AS WELL CHANGE IT
Apr 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge and freezer not getting cold
  • You have 2 fans Make sure your top fan is working ,its located inside the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked.With out a fan you have no circulation .Also if you can move everything out unplug it turn it off w/ doors open 12 to 24 hrs this will free up any clogged tubes. Good luck.
    Len West
Feb 19, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Maytag MSD2655HEB cold in bottom, no air flow
No air flow at all means Fan is not working. Also check damper between freezer and fridge.
Oct 11, 2017 | GE (GTS16BBS) Top Freezer Refrigerator
GE side by side fridge/freezer. Fan in fridge is not spinning.
Replace that fan that blows the cold air into the refrigiator.
Jan 06, 2009 | Refrigerators
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore Side by side model # 25357682790
is the freezer fan working?is there frost in the freezer on the walls?can you find the defrost timer?let me know and we can go from there-mike
Oct 15, 2008 | Kenmore 53542 / 53544 Side by Side...
GE GSS25JEM Side by Side Refrigerator Logo
162 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
