Question about Kenmore 25614 / 25615 Progressive Bagged Canister Vacuum
KENMORE pROGRESSIVE WITH DIRECT DRIVE SUCKING NOISE
Makes sucKing sOund in back of vacumn cleaner through a port behind flex hose, is there a part that came out. noise only when flex hose attached to unit. with accesories no noise heard
I had the exact same problem. The port is a relief valve to prevent the motor from burning out if the hose/bag are clogged. Check the main hose from end to end after removing the 3 screws that hold it to the body of the vacuum near the handle. If that's clear then it's almost certainly clogged in the short tube that goes from the beater bar housing to the hose extension (where the flex tube attaches). There are two ways of going about this.
Option 2
(the way I did it) -- Lock the base on the upright position and turn the unit over. Unscrew the 12 or so screws in the black base. You'll need to depress the release pedal when removing the screw at the end of the pedal. Once you have all of the screws removed carefully wiggle the base loose. You do not need to remove it completely to access the short flex tube. Clean it out and replace everything in the opposite order from how you removed it.
Option 1 (what I would do next time) -- Cut a wire coat hanger and make a small 1/2" hook at the end. Bend the straight section into about a 4" radius arc leaving plenty to handle at the end opposite the hook. Carefully snake the hanger down the tube and pull out the giant clump of hair and dirt that's clogging the vacuum.
cheers -- eric
Posted on Dec 19, 2008
    President:
  • 1,673 Answers
You may have a clog in the hose or in the wands/power head.
Posted on Nov 15, 2008
Manual for Kenmore Progressive Direct Drive Upright Vacuum
can some one show via picture of the location where the micro switch is where the hose attaches to the progrssive direct drive vacuum cleaner to get the start brushes rolling again,
Sep 28, 2010 | Kenmore 31913 Progressive Direct Drive...
Our kenmore progressive with direct drive makes real loud noise when using and i am sure we have the bag on the right way
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
heatman101
Aug 29, 2010 | Kenmore 31913 Progressive Direct Drive...
I have a Kenmore upright progrssive intell clean. For some reason it isn't sucking when I use it to vacuum. When I use attachments they work fine, but when I plug the hose back in after using the...
You have the answer and just don't know it. You are there so keep looking. Somewhere between where the suction hose connects with the lower hose and the power-head. There is a blockage, you may need to turn the unit upside down and look there or try using a wire with a hook on one end, to extract the blockage. but something is blocking the tube from letting air and debris from traveling up the tube.
May 01, 2010 | Kenmore 31913 Progressive Direct Drive...
Kenmoore Intellivac w direct drive suddenly started making internal sound like something was stuck. Hose is clear, and sound is made when hose is detached from main unit. Vacuum sounds find at lower...
Shut off the vac and open container and remove the bag. Try dropping a coin into the hose, then raise up to see if it falls thru to the bag area. If it does check the throat of the vac where the dirt is sucked upward to dump into the bag itself.
Sep 05, 2009 | Kenmore 35912 / 35913 Progressive Upright...
Kenmore model 116. 35912401 very very load
This could also be a problem with your direct drive. These machines have a gearbox instead of a belt. (a system they quickly went away from) You may want to first take off the bottom plate and make sure there is nothing in the brushroller compartment as a paperclip can make a machine sound like an aircraft engine if in the right spot.
My best advice would be take it to a vacuum store that does warranty service for panasonic vacuums (they're made by panasonic for sears) They should be able to tell you for free in most cases after listening to it for 30 seconds wether its the motor or the gear drive and how much the parts are.
Best of Luck!
Jun 08, 2009 | Kenmore 31913 Progressive Direct Drive...
Flapping noise behind where hose wraps up/suction but junk sticki
you have a clog in the hose take the screws out of the hose retainer and take a yard stick and run it into the hose to get the clog out
Jan 24, 2009 | Kenmore 31913 Progressive Direct Drive...
Kenmore Progressive Direct Drive Upright - noise and bad suction
Had the same problem tonight. Took the entire thing apart only to find there was a much simpler solution. Check the small hose that runs from the brush rollers where the longer hose (on the back) attaches to the side of the vacuum. Easiest way to do this is to lay the handle down and stick something (coat hanger worked good) through it until it comes out of the head. I found a pretty good sized fuzz plug in mine. As soon as I removed it, everything worked great again - and no noise!
Mar 15, 2008 | Kenmore 31912 Progressive Direct Drive...
Loss of Suction
Thank you for this solution, it saved me $$$ and a trip to the repair shop.
Feb 23, 2008 | Kenmore Progressive Bagless Upright with...
Getting suction to use attachments
When the vacuum is in the upright position, it should give you suction thru the hose.
Dec 02, 2007 | Kenmore 31913 Progressive Direct Drive...
Kenmore 25614 / 25615 Progressive Bagged Canister Vacuum Logo
526 people viewed this question
Top Kenmore Vacuums Experts
Roger Potts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
