Question about FIC (51-81677-00) Motherboard
K7MNF-64 MB is no longer showing any display even at boot up
There is no vid showing when I turn computer on. Vid card is onboard. I have tried different monitors and diferent vid cards, still no picture. If I turn the monitor off while the computer is turned on I receive a constant tone and a red light on the upper right corner of MB.
  • 22 Answers
You shoould try a different video cable. If this does not work, you should make sure that the video card that you are installing to check are compatible with the system.
Posted on May 03, 2010
Monitor (no signal) after replacing mother board and CPU
try only connect Monitor and keyboard, and check for booting (disconnect all the rest (HDD, CD DRIVE, Sound Card, Network Card, ....) then try connect one by one and always off to change hardware config.
If dont work with monitor and keyboard, try reset bios(jumper),check again, then replace memory modules (must be compatible to new motherboard), evan dont work, send back the motherboard for defective motherboard.
Jan 14, 2010 | Gateway Intel (El Paso 2) Motherboard P4...
I have hooked everything up and the monitor shows " no signal".
are you using the onboard? video... or a seperate vid card? if it was working and then suddenly quit? the onboard vid chip is out! cant replace that either try adding a seperate vid card and reboot
Jan 13, 2010 | E-Machines eMachines Desktop PC
What is max memory for fic k7mnf-64
Supports up to 2 GB RAM 266/333/400 (aka: PC2100/PC2700/PC3200)
Sep 11, 2009 | FIC K7MNF-64 nVidia nForce 2 Socket A mATX...
Constant tone when operating
A constant beep usually indicates that there could be a loose card in the case, check that memory is seated properly, also check your graphics card and any PCI cards that are inside the case are seated properly.
Good luck
Jun 15, 2009 | FIC K7MNF-64 nVidia nForce 2 Socket A mATX...
MOST LONGER VIDEOS ARE SLOW AND "STUTTER' ALONG AS THEY PLAY
A video card with more onboard RAM would help cure the stuttering but it also depends on what you have running in the background. Hope this helps.
Feb 04, 2009 | Compaq Presario 5000 PC Desktop
Need Network adapter
Install the nForce 2 motherboard drivers. The onboard network controller drivers are part of the package.
Jan 29, 2009 | FIC K7MNF-64 nVidia nForce 2 Socket A mATX...
Can u fix this?
That means that ur CPU is shot. That means ur CPU is no good.
Dec 18, 2008 | FIC K7MNF-64 nVidia nForce 2 Socket A mATX...
Fic k7mnf-64 motherboard socket 462 amd 3000+ When I plug the computer in all that happens is a red light on the board comes on and a buzzer goes off.
Power is not going to the board. Check the power supply cables going to the board; most use a big 20 pin connector & a 2nd 4 pin connector. Make sure both are plugged into the proper spots then retry boot. Should see a green light on motherboard if power is properly set up. Hope this helps.
FIC (51-81677-00) Motherboard Logo
150 people viewed this question
Top FIC Computers & Internet Experts
David
David
John Anderson
John Anderson
Are you a FIC Computer and Internet Expert? Answer questions, earn points and help others
